Post new topic Reply to topic  [ 27 posts ]
Go to page 1, 2  Next
PostPosted: Tue Oct 09, 2012 12:02 am
I've been looking for winter clincher tires that are as close to my veloflex carbon tubs. Having been on high tpi tires for a while now, I'd prefer not to go back to the rubbery feel of ultremos or contis.
I've searched the forum quite a bit however seems there is no accepted set-up (other then Paves).
I would get the paves but afraid that the greens will clash with the sky dogma blue or the trek madone navy blue (unless one argues otherwise).
So, what is the most supple tire that will behave like the paves?
(I have used the veloflex carbons in clincher when they were marketed as 22mm, quite bad in the wet)
PostPosted: Tue Oct 09, 2012 12:24 am
Go with the Pave.....people "in the know" will get it. Also.....think you can get them in solid black if you look around. Either way, it's the winter.....bring a little Christmas cheer to your ride!
PostPosted: Tue Oct 09, 2012 4:08 am
Vittoria Paves work. Period. Nothing else is the same.
Yes, they were available for a while in an all-black version because Bjarne Riis got so pissed at having that green stripe on the bikes in his team (I believe it was Bjarne; someone correct me if I was wrong). These were 290 tpi tires and honestly were a little slipperier than the green ones because the green rubber really does work better. I keep hearing stories about 320 tpi all-black ones, but each time I hear about them or order some, they turn out to be 290 tpi. Anyone got a photo of all-black 320 tpi ones?
This year Paves are going to 25 mm from 24 mm. They are actually fatter than that seems in the newer diameter. I like them better and the green stripe seems to be wider too. The 24 mm tires will be on clearance so it's a good time to buy them.
It really is winter and if you need a tire like this, get the Pave. There's nothing else like it. The green stripe gets much duller as soon as it gets dirty so it's only on the first ride that you have to deal with it.
PostPosted: Tue Oct 09, 2012 4:30 am
The Vittoria website actually has new 2013 Open Pave listed as 25c (240gm) and 27c (280gm) ...very interesting, and exciting that they are going to offer in 27c. Look slike the tread profile is differnt and they dropped the green center stripe and went back to two green side stripes. Has anyone seen or tried these yet?
EM3
________________
My 2011 Cervelo R5
PostPosted: Tue Oct 09, 2012 5:20 am
Seems like these aren't out yet. Its coming up as 'coming soon' on the distributers page.
An interesting change is, yes, the paves have gone up to 25/27mm with the addition of a new model, the CORSA SR 24mm.
These have a similar pattern to the corsa cx but with more defined lines. Vittoira markets all their high-end tubs and opens as wet/dry weather tires. But we all know how they handle in the wet.
Only the paves were marketed as rough road tires (they have a little "!" symbol by them). Now the new model, Corsa SR 24mms also specified as rough road tires.
So, if true to statements, there is a new 'pave' model which is jet black.
the tubular and the clincher versions are both claimed 250g....hmm
PostPosted: Tue Oct 09, 2012 7:48 am
Good god man, don't worry about colour clashes. Are you that much of a bike tart?
The Vittoria Pave are fine, fine tyres, Fit 'em, ride 'em and enjoy 'em .....
PostPosted: Tue Oct 09, 2012 8:37 am
I've almost had my mind made up to use 25mm Conti Comps for the winter, but with all the love for the Pavè here I'm almost having second thoughts. Can anyone compare the two?
Bikes: Raceur, Beateur
PostPosted: Tue Oct 09, 2012 8:41 am
I' ve tried both. Pave is a higher quality tire IME. More plush ride, lower rolling resistance (in practice not in theory), more durable than Conti, way better allround feel.
Wilier Cento Uno
Colnago Master X-light
Wilier 18carati
PostPosted: Tue Oct 09, 2012 10:26 am
I have to agree except for durability. They are very good in that aspect, but not better than Continental.
I use the 24mm clincher every day to work, and 27mm tubular (for the pave of Paris Roubaix).
Both excel.
Bianchi EV3, Master Olympic, Pinarello Asolo
PostPosted: Tue Oct 09, 2012 4:59 pm
FMB Paris Roubaix!?
PostPosted: Tue Oct 09, 2012 6:23 pm
looking at clincher specifically.
although I have been eyeing dugasts/pr fmbs for a while now.
im hopeful of the new vittoria model. and yes, I do like matching appropriately.
if we were discussing tubulars, then the list would be hard to chose from...
PostPosted: Tue Oct 09, 2012 6:45 pm
Duuh, my bad, clinchers it is. Just for the record: You should be eying further down the tubular route though.
PostPosted: Tue Oct 09, 2012 6:48 pm
i ride veloflexs tubulars daily :D
PostPosted: Tue Oct 09, 2012 7:20 pm
You can only get disappointed by any of the clincher mentioned here then :D
PostPosted: Wed Oct 10, 2012 6:53 am
FmB are a bit of a pain because the sidewalls are not sealed
But for Clinchers stay with the Pave, as the first reply said, people who count understand straight away
Post new topic Reply to topic  [ 27 posts ]  Go to page 1, 2  Next
Users browsing this forum: Bing [Bot], Google [Bot], HammerTime2, OrPe and 62 guests
There are no new unread posts for this topic. Vittoria Open Pavè 27mm
wassertreter
Tue Mar 26, 2013 2:29 pm
wassertreter View the latest post
wassertreter
16
1496
Mon Jun 03, 2013 2:57 pm
There are no new unread posts for this topic. alternative of 404s
project3
9
920
Fri Feb 01, 2013 7:18 pm
NGMN View the latest post
There are no new unread posts for this topic. Alternative to Quarq putty
Martin.F
7
386
Sat Apr 20, 2013 1:14 pm
Martin.F View the latest post
There are no new unread posts for this topic. Alternative to Selle SMP saddle options
digitalnorbs
16
499
Tue Jun 11, 2013 1:33 pm
RudyMontana View the latest post
It is currently Wed Jun 19, 2013 8:21 pm
