Post new topic Reply to topic  [ 4 posts ]
PostPosted: Sun Oct 07, 2012 9:35 pm
I want to use the Canyon VCLS post, but I have my Arione pretty forward when using Thomson non-setback post (femur/tibia ratio, not a frame issue. The st is at a standard 73°).
I couldn't find the info on Canyon's site, but it seems as if their post has min setback of 15mm, what I couldn't find is how long the clamp is -- does someone have such a post and could measure it for me?
The reason is as there is no zero offset, I'll need to have my saddle 15mm forward in the clamp relative to the current position in the clamp, and that would put the clamp as backward as it can go on the rails, which is a bit unwanted - but that when looking at Thomson's clamp, which is longer than most (?)
PostPosted: Sun Oct 07, 2012 10:35 pm
I measure the bottom seat of the clamp to be 35mm long.
PostPosted: Sun Oct 07, 2012 11:52 pm
Thanks. Thomson is ~40mm, so I'll have an extra 5mm of usable rail.
PostPosted: Mon Oct 08, 2012 2:18 pm
You may get 5mm more of usable rail but wont you actually be 10mm worse off and so need to know if you can move your saddle 10mm further forward now?
No Setback on Thomson and 15mm on Canyon so you are 15mm further back already then if you push the saddle as far forwards in the clamp you gain back 5 of the 15 due to the shorter clamp on the Canyon (35 Vs 40)
Users browsing this forum: bigkraig, dalex, Google Adsense [Bot], mgrennie, Rob1519, woody55, yourdaguy and 58 guests
There are no new unread posts for this topic. 30.0 seat post clamp for Supersix Evo?
penolo
14
868
Mon Jul 30, 2012 8:58 pm
cezinho View the latest post
There are no new unread posts for this topic. Attachment(s) Trek 4.7 Seat Post Clamp
darth
Sat Nov 03, 2012 2:32 pm
darth View the latest post
There are no new unread posts for this topic. What is the lightest durable seat post clamp?
Ufgators
9
616
Fri Oct 05, 2012 9:39 pm
nosafeHAVEN View the latest post
There are no new unread posts for this topic. 28.6 mm light seat post clamp options (under $30.)
LouisN
Sun Jan 06, 2013 11:19 pm
LouisN View the latest post
There are no new unread posts for this topic. 25mm setback seat post good clamp
digitalnorbs
Fri Sep 28, 2012 12:18 am
digitalnorbs View the latest post
It is currently Mon May 20, 2013 4:37 pm
