Post new topic Reply to topic  [ 47 posts ]
Go to page Previous  1, 2, 3, 4  Next
PostPosted: Sat Aug 18, 2012 10:11 pm
NWSAlpine wrote:
stock bearings are fine
Nice ! :D ....!
PostPosted: Sat Aug 18, 2012 10:14 pm
Any idea on how to find the washer that comes with the crank bolt....? (i have the black bolt) :up:
PostPosted: Sat Aug 18, 2012 10:49 pm
The man to contact is Starnut. He's the guru on Dale cranks; and Dale just about everything.
PostPosted: Sun Aug 19, 2012 4:28 am
if you bought everything new in package, the bolts should come with the washers.
bearing shields, preload spacers, wavy washer usually come packaged with the bb30 bearings and circlips. if you have the bearings already in the frame, the other stuff is available separately.
if youre in the us, check http://www.cannondaleexperts.com/
PostPosted: Sun Aug 19, 2012 6:09 am
The (2) tiny washers that fit behind the crank arm fixing bolts can be hard to find. Cannondale Experts.com doesn't stock them.
The owner of Lonesome Mountain Outfitters has them for sale.
http://www.manta.com/c/mr53qly/lonesome ... itters-inc
He uses the same co. name on The Bay and he will respond if you message him there.
Here is the Hollowgram Owners Manual / Parts List;
http://cdn.cannondale.com/Manuals/2008_ ... ent_en.pdf
PostPosted: Sun Aug 19, 2012 3:04 pm
http://www.manta.com/c/mr53qly/lonesome ... itters-inc" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;
http://cdn.cannondale.com/Manuals/2008_ ... ent_en.pdf" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;
I bought it use but in real good conditions . :lol: .... i just contact the seller hopefully he will reply and i can buy the tiny washers :beerchug: once i get all the washers and things i will post a picture of the crank...... :smartass:
PostPosted: Mon Aug 20, 2012 3:44 pm
I'm still trying to justify purchasing these cranks. I really want them :cry:
PostPosted: Mon Aug 20, 2012 4:18 pm
:D First i was like that ..! However i saw it on ebay, i bid it and won it .! :D for only $466 including shipping ... the crank was not beat up at all(this baby is new !) i checked the crank more than a 10 times to check for cracks or other defectives things but it was all good ! :mrgreen:
PostPosted: Mon Aug 20, 2012 5:52 pm
Especially after you drop one of them on the floor in the workshop. :shock:
PostPosted: Tue Aug 21, 2012 6:09 am
don't worry about trying to justify a set of cranks................or any other high end components. You'll be wringing your hands for forever. Over a span of (3) years I built up (2) new rides and each time I told myself I didn't need Hollowgrams. I didn't. About a month back I bought a set and I finally satisfied that craving I had had for years.
Sweet upgrades include a hot frame, hot wheels and Hollowgrams.
Q:What is it they say about amateur racers running SRM Powertap gear?
A: It's like someone hiring an accountant to tell them how poor they are.
No justification for amateurs running power meters, can't justify it, but if you want it then get it.
Enjoy cycling and the cool gadgets while you still can.
PostPosted: Wed Aug 22, 2012 5:49 pm
[quote="skinnywellfed"]Q:What is it they say about amateur racers running SRM Powertap gear?
No justification for amateurs running power meters, can't justify it,[/quote]
I got my Hollowgram SRM for less than the typical cost of the SiSL cranks alone. Is it ok to use them? I am an amateur...
PostPosted: Tue Aug 28, 2012 8:00 pm
Finally all the washers are here ..! 8)
what i have is this:
1-crankset (arms, spindles, lockring and chainrings and their bolts as well)
2- bolts and their tiny washers
3-wavy washer
4-black spacers
5-cir-clips.
Now lets install this sweetie pie ! :D
PostPosted: Wed Aug 29, 2012 11:02 am
3-wavy washer
4-black spacers
5-cir-clips.
Good luck and enjoy..... best crankset I have ever used :thumbup:
PostPosted: Sat Oct 06, 2012 1:30 pm
I know that this has kind of been covered before but i have been unable to find any images of a correctly installed crank so here i go.
I am currently building up a sram red evo. The standard red crank was removed, however i left the standard sram PF 30 BB in. I have now acquired a hollowgram crank with evo lockring. Installing the spindle seemed to require a large amount of force, more than I applied to the sram crank to remove it. I installed both crankarms - seemed easy enough but it seems now to be binding, despite being less than 40Nm on the lockbolts. Looking at the bottom bracket it seems like there is still too much spindle on the NDS whereas the lockring seems to sit on the PF cup. I have one shim next to the wave washer. Have i just not hammered it in far enough - it seems like the NDS was in far enough. I just don't want to crack the BB shell hammering the spindle in.
Any advice would be appreciated.
Photos
Evo 5.63kg SL3 7.045kg viewtopic.php?f=10&t=110579" onclick="window.open(this.href);return false;
PostPosted: Sat Oct 06, 2012 1:57 pm
the instruction manual supplement that came with the frame should have info about the spacers/bearing covers that sit on the outside of each of the pressfit bearings, and which ones to use. the ones that were installed from the factory on my frameset seem to have been for the sisl, and since i was installing a red crank, they did not work (every time i put the red crank in and torqued it, it would not budge). i took the existing bearing spacers out of the bearings and replaced them with the others (thin black washer type things with a small lip that fits into the bearing - these came in a ziplock bag with the instructions), and the red crank torqued down perfectly.
my guess is that if your frame originally had the red crank on it, it was installed with the shorter spacers in place, and now that you are putting the sisl crank on, there is extra room. hopefully you have the other (longer) spacers and can give them a shot, otherwise your dealer may have some spares.
hope this helps!
Post new topic Reply to topic  [ 47 posts ]  Go to page Previous  1, 2, 3, 4  Next
Users browsing this forum: Bing [Bot], cyclistcong, totoboa and 44 guests
There are no new unread posts for this topic. Cannondale SISL crank on Scott Foil
Kingston
15
1306
Thu Dec 27, 2012 6:43 pm
Elrey View the latest post
This topic is locked, you cannot edit posts or make further replies. cannondale si sl crank install
logy
Sat Mar 30, 2013 11:55 pm
There are no new unread posts for this topic. Help me indentify this Cannondale Hollowgram crank
Ufgators
15
1271
Wed Nov 28, 2012 3:49 am
There are no new unread posts for this topic. 2012 SRAM Red Crank on Cannondale EVO - Chainline question
motorthings
Tue Nov 13, 2012 1:50 pm
motorthings View the latest post
There are no new unread posts for this topic. how many spacers going from SiSl to SiSL2 axle
styrrell
Sun May 19, 2013 4:16 pm
styrrell View the latest post
It is currently Mon May 20, 2013 4:31 am
