It is currently Tue Nov 21, 2017 3:14 pm
Post new topic  Reply to topic  [ 354 posts ]  Go to page Previous 15 6 7 8 924 Next
PostPosted: Sat Apr 06, 2013 7:27 pm
This will have already been covered, but I will ask anyway: Can you mate all the ultegra di2 parts directly to the shimano 11 speed cassette (/chain)? Who's actually doing mix and match successfully?
PostPosted: Tue Apr 09, 2013 5:37 pm
Repeat question: Has anyone yet tried the 9070RD with Ultegra shifters & FD???
asv wrote:
Has anyone confirmed that you can add a 9070 rear derailleur to 6770 and it will support 11 speed?
PostPosted: Fri Apr 12, 2013 2:33 am
After getting it all on the bike and updating firmware I can confirm the following setup works with 6770 derailleurs and STIs:
- SM-EW90-A, junction box for shifters and charging point
- SM-BTR2 battery pack
- SM-BCR2 battery charger (and e-tube interface)
- 2 X EWSD50 to connect to the shifters (one to each side) as the SM-EW90-A doesn't have the inbuilt cables of the SM-EW67AE
With SM-BCR2 I was able to run Shimano's e-tube project to update the firmware and enable multi-shift. Couldn't have been easier.
PostPosted: Mon Apr 15, 2013 2:49 am
So who's got the best prices for these parts?
PostPosted: Mon Apr 15, 2013 3:28 am
The RD dictates the number of total speed for the system, so the answer to this question is a "Yes" but it has a contingency. You have to update to the latest firmware (multi-shift compatible) in order for the 6770 shifters to recognize the 9070 RD. Non of this is "officially" compatible, by the way.
Turn down the suck knob.
PostPosted: Mon Apr 15, 2013 3:31 am
[quote="bonafide"]Repeat question: Has anyone yet tried the 9070RD with Ultegra shifters & FD???]
Unofficially speaking, you "can" get it to work but it is not recommended as the 6770 FD does not have the micro-adjust feature to allow micro-trimming of the FD to accomodate the extra cog and added FD cage travel/movement. Again, Shimano is not, will not, and has not suggested this as a compatible combination of components - experiment at your peril/non-compatibility.
PostPosted: Mon Apr 15, 2013 3:32 am
Your local bike shop.
PostPosted: Mon Apr 15, 2013 4:43 pm
Hubert, how about chainrings? Will theh 9-10 speed chainrings work or do we have to buy 11-speed?
Thanks
PostPosted: Mon Apr 15, 2013 5:01 pm
Could be used as a cool 1x11 setup for a CX bike though :)
PostPosted: Sat Apr 27, 2013 7:21 pm
New firmware for Ultegra Di2 6770 just came out. Dated April 9, 2013, description is "enhancement of function" and for the battery mount dated March 26, 2013, "Improved stablility of unit communication, Enhancement of energy-saving".
PostPosted: Sat Apr 27, 2013 11:14 pm
Thanks.
PostPosted: Mon Apr 29, 2013 7:16 am
the best place for putting the battery in the seat post for Ultegra upgrade, is on eBay.
PostPosted: Mon Apr 29, 2013 7:19 am
None of that is needed if you go with this http://www.ebay.com/itm/290894523169?ss ... 1555.l2649" onclick="window.open(this.href);return false;
PostPosted: Tue Apr 30, 2013 10:55 am
Maybe I missed it but can anyone confirm if multi-shift will work if you have the older junction SM-EW67AE.
Or must you have SM-EW90-A to have multi-shift functionality?
PostPosted: Tue Apr 30, 2013 11:12 am
Works with the older junction just fine.
My RCA
There are no new unread posts for this topic. Ultegra 6770 Di2 Auto-trim?
Staffan
Sun Nov 05, 2017 1:35 pm
glepore View the latest post
There are no new unread posts for this topic. Need schematic of rd 6770
yumseyo
Mon Jun 05, 2017 8:59 pm
yumseyo View the latest post
There are no new unread posts for this topic. New Ultegra (Di2) ???
stormur
Thu Mar 23, 2017 10:42 am
stormur View the latest post
There are no new unread posts for this topic. Ultegra brake
Timmy269
Fri Oct 13, 2017 1:08 pm
Timmy269 View the latest post
There are no new unread posts for this topic. Power2max vs Pioneer Ultegra
JBeauBikes2
9
850
Wed Aug 30, 2017 9:22 am
RJKflyer View the latest post
Users browsing this forum: amey, Chris3g, ddsg, dim, L3X, Lewn777, pyrahna, wheelbuilder, Yahoo [Bot], yltman, zerogravitas and 38 guests
