It is currently Sat Jun 24, 2017 10:19 pm
Post new topic  Reply to topic  [ 347 posts ]  Go to page Previous 119 20 21 22 23 24 Next
PostPosted: Mon Aug 18, 2014 2:53 am
i posted this topic: http://weightweenies.starbike.com/forum/viewtopic.php?f=3&t=127234
another solution is to find a new battery with firmware older than v3.0.5, and then never update it.
the ones coming from shimano now have the new FW, so you'll need to find one in a shop that has the older FW. i have a few.
PostPosted: Tue Aug 19, 2014 1:19 pm
Thanks for this note. I went ahead an ordered an FD 6870. Buying a battery with the old firmware just feels like I'm putting off the unavoidable. :(
PostPosted: Thu Sep 18, 2014 11:16 pm
All right, finally read through the whole thread.
My bike has a full 6770 system with EW67 junction, external battery, and charger BCR1. I want to update the firmware.
1. Is the way to go about this swapping the junction to a EW90 (with 2 SD-EW50 wires)?
1b. Are the 300 mm wires what everyone recommends?
2. Is the SM-BCR2 necessary for the PC connection?
PostPosted: Mon Feb 02, 2015 3:41 am
Using 8.4V headlight battery as backup, and adapter cable for SM-BCR2 -
PostPosted: Wed Feb 04, 2015 10:51 am
I've recently done the upgrade to an internal battery for my 6770 di2. It was purely for looks but I did like the idea of being able to upgrade firmware, set-up multi shift and save a few grams.
It turned up to be slightly more extensive than I'd initially thought. Unfortunately I didn't have the guts to take a mallet to my bottom bracket to remove the press fit shells and bearings so I opted to be my LBS to do the upgrade.
After a bit of research I required the following items
3 port junction box
Internal battery & charger
2x Cables to shifters and 1x Cable to new battery
So the spares are now on ebay!
My new junction box
My new internal battery
Some frame protection tape covering the di2 battery holes
Overall I'm pleased with the results and I know if I want 11 speed I'm going to require both the FD & RD. At the moment I'm content with 10 gears with a spare cassette with 28t for the hills.
PostPosted: Wed Feb 04, 2015 10:59 am
You can upgrade the firmware by purchasing a SM-PCE1. They are pretty expensive although you can apparently do more with them. I opted for the internal battery which allows you to connect via the EW90 junction box. You can upgrade firmware and set-up multi shift but but it lacks the diagnostics you get with the SM-PCE1.
I suppose your best option, if you're happy with the battery, is to get your LBS to upgrade the firmware.
PostPosted: Wed Feb 04, 2015 2:53 pm
Nice thing about sticking to 10 speed is that you can run the Ultegra 12-30 cassette on the regular Ultegra Di2 RD, no problem. So if it's REALLY steep, you have a good low option. Or, if you run a standard double crankset but only occasionally go to the mountains.
I have a friend who used that setup on his road tandem that has Di2.... loves it.
I keep a couple of the 12-30 cassettes around for our 10 speed Di2 CX bikes. We do 2 races a year where the 30T really comes in handy.
PostPosted: Wed Feb 04, 2015 4:56 pm
I have no desire to go 11 spd as all wheels etc are 10...but god forbid I trash my rd as it appears that I'd have to go to ebay. I can't find a reliable source for 6770 rear derailleurs, I presume that Shimano has suspended production?
PostPosted: Fri Feb 06, 2015 7:22 pm
Putting together Dura ace Di2 all 9070 with internal battery except for rear deraileur which will be 6770. I anticipate everything should work as long as I don't do an update past version 2.5. Can anyone confirm this is correct ?
I have several bikes with 10 speed wheels like glepore , hence the 6770 rear.
Tmtevo, did you use the 2.5 update or the most recent feeling safe that everything was 10 speed ?
PostPosted: Sat Feb 07, 2015 1:15 am
I have 44 cm bars and had to use 350 mm etube cables to make it work.
Sent from my SGH-I337 using Tapatalk
PostPosted: Tue Feb 10, 2015 6:10 pm
18 month old internal battery died on me suddenly on Sunday. On downhill (of course) in 52 15 with a big hill and 15 miles to go. Not fun. New battery ordered, hoping that's all it is. No warning, just poof. Etube sees it, all connections ok, but it won't charge.
It had fallen from seatpost and was in frame, but it wasn't rattling around. Not sure what's up, stay tuned.
PostPosted: Wed Feb 11, 2015 3:41 am
Ultegra warranty is valid from 2 years, Dura-Ace 3
PostPosted: Wed Feb 11, 2015 8:47 am
Bit lost here on compatibility, can I do the following on the 10 speed Ultegra DI2:
1a. Install the internal seatpost battery and hook it up the internal junction
1b. charge via the shifters port for satellite shifters
2. If 1b won't work, install a 3 or 5 port junction with new wires to the shifters to charge
3. Not update the firmware on any of the components so that I can change derailleurs to 11 speed in the future
4. Enable multi-shifting via the internal battery charger
Any help is greatly appreciated :)
Oh I wish Shimano would make all this stuff compatible... would be so nice if we could just run all combinations imaginable :(
Edit: obv. I meant compatible
PostPosted: Wed Feb 11, 2015 1:00 pm
pls see replies below
yes
yes, but you have to improvise and it is not official -
viewtopic.php?f=3&t=107887&start=300#p1116607
that is the official method
yes. If you are really concerned about firmware update, disconnect your internet connection while using e-tube software. I am not sure about downgrade though if the component(s) are already at a newer version
yes, for further info -
http://e-tubeproject.shimano.com/
Oh I wish Shimano would make all this stuff incompatible... would be so nice if we could just run all combinations imaginable
i guess you meant compatible. i won't hold my breath on that ;)
PostPosted: Wed Feb 11, 2015 1:15 pm
Some additions to the above. Shimano has disabled the automatic updates on their site, so etube no longer auto updates-you don't need to worry about the internet connection part. You can find 2.5, the latest firmware without the need for compatibility on the web if you want. However, if you purchase a new internal battery, it'll have the new firmware already loaded.
Also, you can go 11 spd with 6770 shifters and latest but you'll need to buy both derailleurs rather than just the rear, that's the firmware issue.
You can't backdate the firmware.
Thanks for the warranty suggestion. Bought the group on ebay, and idk whether Shimano will hassle me about not going thru authorized channels, suspicion is that they will. Since the di2 bike is the only bike I want to use on my Computrainer at the moment, it needs fixed like yesterday, so I just bought a battery. If Shimano will warranty the old one, I'll ebay the replacement.
There are no new unread posts for this topic. Need schematic of rd 6770
yumseyo
Mon Jun 05, 2017 8:59 pm
yumseyo View the latest post
There are no new unread posts for this topic. Dogma F8 hydro disk brakes/ Di2 Ultegra vs Cannondale SuSix Di2/Ultegra
bikebike
Sat Oct 29, 2016 4:41 am
bikebike View the latest post
There are no new unread posts for this topic. Next Gen Ultegra...
Conradsleight
Thu Jun 30, 2016 9:46 am
jeffy View the latest post
There are no new unread posts for this topic. New Ultegra (Di2) ???
stormur
Thu Mar 23, 2017 10:42 am
stormur View the latest post
There are no new unread posts for this topic. Attachment(s) Ultegra update?
[ Go to page: 114 15 16 17 18 ]
AW84
265
42368
Sat Jun 24, 2017 7:02 pm
mattr View the latest post
Users browsing this forum: 2lo8, 3Pio, arthurf, hlvd, jlmcabral, Mockenrue, spud, tonytourist, WeightySteve and 40 guests
