Post new topic Reply to topic  [ 132 posts ]
Go to page Previous  1, 2, 3, 4, 5, 6 ... 9  Next
PostPosted: Tue Feb 05, 2013 11:01 am
I assume the etube software isn't Mac compatible :(
PostPosted: Tue Feb 05, 2013 2:08 pm
VMware fusion or parallels will allow you to run it on the Mac.
PostPosted: Tue Feb 05, 2013 5:01 pm
Thanks
PostPosted: Sat Feb 23, 2013 2:17 pm
Let try to sum up and verify some new information.
Multi shifting on 6770 is officially possible with new software
http://e-tubeproject.shimano.com/" onclick="window.open(this.href);return false;
-Adapted multi shifting of RD-6770*
The new SM-BTR2 battery and SM-BCR2 charge are available
SM-BTR2 battery is connected via a regular EW-SD50 wire, so all 6770 owners should be able to use it.
Could someone verify that?
The description for the battery states to use the new SM-BCR2 charge only? This seems as an unfriendly move from Shimano, but it needs to be verified wheter this is an actual requirement or is Shimano just trying to make more money.
The good side of SM-BCR2 charge is that the description states:
The SM-BCR2 is also an interface for the Shimano E-Tube configuration software.
Which is very good news. If that is indeed correct and you can use it instead pf SM-PCE1, the price for it is actually very good.
About charging the new SM-BTR2 battery.
As I currently understand, 6770 owners must still remove the SM-BCR2 battery to charge it, as do 9070 owner who have internal Di2 wire installation. The isn't a 5 port junction box for 9070 nor 6770.
One option to charge it on the bike is to unplug a component and plug the charge there. Needs to be verified.
The new battery is chargeable on the bike only when you have 9070 with extarl wires and are using SM-EW90-A or SM-EW90-B junction.
Scott Foil Di2 2012
Scott Scale 35 2010
PostPosted: Sat Feb 23, 2013 3:19 pm
Have a SM-BTR2 on order, should be here in the next week. Then I can verify if it will work with my 6770.
The SM-BCR2 will charge and work with the E-Tube software, that is verified.
You can charge the SM-BTR2 with internal or external wiring of 6770 or 9770 using the SM-EW90-B or SM-EW90-A. The SM-EW90B is a 5 port junction box and I'm using it with my internal wiring. I have another coming with the SM-BTR2 that will also be setup with internal wiring.
Ridley Noah FAST = 7.38 kg
BMC TM01 = 7.96 kg
Raligh HiLife = 7.46 kg
http://weightweenies.starbike.com/forum/viewtopic.php?f=10&t=104672
PostPosted: Sat Feb 23, 2013 7:33 pm
Interesting updates for 6770.
With 9070 only just becoming available and these 6770 updates is it pretty safe to say the next iteration of Ultegra Di2 is still pretty far off?
PostPosted: Sat Feb 23, 2013 8:16 pm
Thanks for the verification!
As I understand, you don't use SM-EW67A-E when using SM-EW90-B and SM-EW90-A. This would give you an extra port to plug in the charger.
Also, it should work when you use SM-EW90-B instead of JC-40/JC-41. The sizing isn't great and the extra port would be inconvenient to use, but on paper it should work.
Scott Foil Di2 2012
Scott Scale 35 2010
PostPosted: Sun Feb 24, 2013 12:07 am
the charging socket on the 3 port is a separate socket to the standard junction wires, it is the same type of connection as the pc connection interface I believe. I.e. you wouldn't have to unplug any of your switch cable to charge.
____________________________________________________________________________
Firefly FF050
Felt B2Pro
Trek Fuel EX9
PostPosted: Sun Feb 24, 2013 2:00 pm
You are correct that you wouldn't use the SM-EW67A-E when using the SM-EW90-B or SM-EW90-A. I don't know if you could use the SM-EW90-B instead of the JC-40/JC-41 but I don't think you would want to. The SM-EW90 is significantly more expensive and is not meant to be the rear junction box. It's meant to be the front junction and replace the functionality of the SM-EW67 plus add the functionality of charging.
BMC TM01 = 7.96 kg
PostPosted: Wed Feb 27, 2013 6:50 am
Any current 6770 owner can upgrade to the SMBTR2 if they have updated the bike's firmware to the latest version (which include multi-shift functionality).
However, if you retain the SMEW67A, you will need to remove the SMBTR2 to charge it.
Therefore, when you upgrade to SMBTR2 you should also upgrade to SMEW90A or SMEW90B as they both have the micro-USB charging port for SMBTR2.
Turn down the suck knob.
PostPosted: Thu Feb 28, 2013 1:08 pm
Will the SM-BCR2 be enough to firmware update Ui2, nevermind hte charging bit.
It's only half the price of SM-PC1E
PostPosted: Thu Feb 28, 2013 3:01 pm
I'll be finding out early next week.
PostPosted: Thu Feb 28, 2013 5:23 pm
Have a slight indexing issue with my Ultegra Di2 at the moment. It runs fine in every gear except the second largest cog in the cassette. The rear mech clicks as if the chain is catching on a chain link. Other gears have no issue.
Could it be a mech hanger issue?
PostPosted: Mon Mar 04, 2013 10:43 pm
No it won't. I bought one and this new charger uses the additional port in the new junction boxes (the things near your stem). The connector is different so you can't stick it in with the original Ultegra group, but I'll try to hack mine a bit and see if it will work.
PostPosted: Mon Mar 04, 2013 11:47 pm
This document says you need the new junction with the charging port. So, you would have to buy both a junction and the charger. Probably the same or more total cost.
http://si.shimano.com/content/si/sm/english/BatteryCharger_SM-BCR2/_jcr_content/par/sidownload/file.res/UM-7FJ0A-000-00-ENG.pdf
Post new topic Reply to topic  [ 132 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6 ... 9  Next
Users browsing this forum: CarpetFibre, Google Adsense [Bot], showdown, willwork4rice and 60 guests
There are no new unread posts for this topic. Same battery/cabling for Di2 9070 and Ui2 6770?
klingej
Wed Jan 23, 2013 12:05 pm
klingej View the latest post
There are no new unread posts for this topic. Shimano Ultegra 12-30 Cassette With Ultegra Di2?
SpeshK
Tue Feb 05, 2013 5:13 pm
SpeshK View the latest post
There are no new unread posts for this topic. Ultegra Di2 New Firmware
goodboyr
16
3103
Fri Sep 14, 2012 7:27 pm
Toby View the latest post
This topic is locked, you cannot edit posts or make further replies. Dura Ace Di2 from Ultegra Di2
DamoRider
Sun Jan 27, 2013 8:36 pm
DamoRider View the latest post
There are no new unread posts for this topic. Is Ultegra Di2 compatible with the new DA Di2?
limba
Tue Mar 19, 2013 6:15 pm
ms6073 View the latest post
It is currently Mon May 20, 2013 2:21 pm
