Overall Ultegra Di2 6770 topic
415brian
by 415brian
I also just confirmed that all 11 speeds of a Dura-Ace RD-9070 rear derailleur will work on an otherwise complete 6770 10-speed system. In other words, the rear derailleur alone determines whether a system is 10 or 11 speed.
Video: http://www.youtube.com/watch?v=1ADH7jwGD-M
For those running the 10-speed 6770 group, upgrading to 11-speed would cost ~$355, not including the hub:
1. 11-speed compatible hub
2. 11-speed cassette (CS-6800: ~$70)
3. 11-speed rear derailleur (RD-6870: ~$250)
4. 11-speed chain (CN-6800: ~$35)
Notes:
+ I am running the latest firmware all components.
+ I did not test the RD-6870 since they're not widely available yet. However, I expect them to behave the same as the RD-9070.
+ Starbike just listed the RD-6870 as in stock (180 EU/250 US): http://www.starbike.com/en/shimano-rd-6870/
pataww2001
by pataww2001
415brian wrote:I also just confirmed that all 11 speeds of a Dura-Ace RD-9070 rear derailleur will work on an otherwise complete 6770 10-speed system. In other words, the rear derailleur alone determines whether a system is 10 or 11 speed.
Notes:
this is excellent solid configuration. great to hear and confirmed. I'll be ordering parts. I still need to get the firmware updated
RichieE46
by RichieE46
Yea definitely great news. This flexibility is another great advantage of Di2 :-)
Pretty glad I went the Di2 route despite the slightly extra weight.
Sent from my GT-I9505 using Tapatalk
deltree
by deltree
I'm about to take the plunge into Di2 thanks to a very generous friend. Here's the proposed setup, can anybody tell me if I'm missing anything or if anything is incompatible?
Code: Select all
STIs 6770
v
SM-EW67-A-E
v
SM-JC41
v              v           v
SM-BTR2     RD 6870     FD 6870
Thanks to 415brian I know the STIs will shift all 11spds of the RD but I only want 10 until I either change my wheelsets or upgrade my Powertap freehub body.
Also has anybody "tuned" any of the Di2 STIs? I'm thinking of sanding down the top layer of the lever and drilling a few holes before painting.
rmerka
by rmerka
deltree wrote:I'm about to take the plunge into Di2 thanks to a very generous friend. Here's the proposed setup, can anybody tell me if I'm missing anything or if anything is incompatible?
Code: Select all
STIs 6770
v
SM-EW67-A-E
v
SM-JC41
v              v           v
The number of speeds is dictated by the RD not the shifters. If you use a 6870 RD you'll likely need to have an 11s cassette...
deltree
by deltree
D'oh. Looks like I glazed over that last page.
Well more motivation to sell my Powertap and get a new set of wheels and an SRM instead! Thanks.
DartanianX
by DartanianX
6870 Rear derailleur in the post. Hopefully arriving by Friday. 11 speed cassette, chain and Ultegra 6800 wheel set ordered at LBS so should have 11speed up and running on an otherwise 6770 groupset this weekend.
Sent from my Nexus 4 using Tapatalk
Delfins
by Delfins
Will it work "mtb 1x10 setup"?
EW90 (A/B)
RD 6770
SW R600
BTR2+BRC2 set
+ cables
PS: without shifters
pataww2001
by pataww2001
DartanianX wrote:6870 Rear derailleur in the post. Hopefully arriving by Friday. 11 speed cassette, chain and Ultegra 6800 wheel set ordered at LBS so should have 11speed up and running on an otherwise 6770 groupset this weekend.
Looking forward to see how it goes for you. keep us posted
DartanianX
by DartanianX
Parts are all coming in. Just waiting for the stuff from the LBS to arrive.
DartanianX
by DartanianX
So, do you all want the good news, or the bad news?
SvenNijs
by SvenNijs
DartanianX wrote:So, do you all want the good news, or the bad news?
Go with both, in the appropriate order.... :wink: :)
DartanianX
by DartanianX
Bad, have to wait another day for everything else to arrive from the LBS.
Good, plug and play 11 speed!
pataww2001
by pataww2001
DartanianX wrote:Bad, have to wait another day for everything else to arrive from the LBS.
any updates?
DartanianX
by DartanianX
Yeah, all works fine! No issues whatsoever.
