It is currently Thu Feb 23, 2017 6:32 am
Post new topic  Reply to topic  [ 341 posts ]  Go to page Previous 112 13 14 15 1623 Next
PostPosted: Tue Sep 24, 2013 12:36 am
For those of you getting into Di2 I have an important advice. I have read about the wires coming out of the shifters if the wires have no slack and are too tight. Mine was professionally built and I didn't take the time to unwrap the bar tape to make sure that there's some slack in the wires. Well today I was on a ride going 25mph when I hit a big pothole. The bike/wheel was fine however I lost all shifting functions front and rear. My first thought was that the battery cable had come undone. I pulled the seatpost and checked the internal battery cable and it was fine. I also checked all cable connections including the ones going into the shifters (they looked OK visually however with the bar tape still on one cannot really tell for sure). I rode home on a fixed (50x16) gear. After I got home I performed a reset thinking that I might have tripped the crash protection system. The gears moved by themselves after the reset however I still don't have any shifting controls. I called up Shimano and they guy said the wires came undone at the shifters. I argued with the Shimano agent and I asked him what's the possibility of wires coming loose on both shifters. He said he was 99.9% sure that's the cause and he asked me to undo the bar tape and check the connections. Well guess what both wires came undone when I hit the pothole. Visually one cannot tell the wires are loose unless you unwrap the bar tape and swing out the triple connection on the shifter. I added a tiny bit of slack and taped the wires to the bar really good. Lesson learned.
PostPosted: Tue Sep 24, 2013 1:22 am
"Professionally built"?
Maybe......but the Shimano manual specifically says you need to leave slack in those cables for that very reason. So I guess they don't read too well at your LBS.
My RCA
PostPosted: Fri Sep 27, 2013 6:03 am
For the internal battery, are you guys doing the seat post install or the wrap in foam and drop into seat tube install?
PostPosted: Fri Sep 27, 2013 7:40 am
I put mine in the seatpost using this nifty accessory from Ritchey Logic:
http://ritcheylogic.com/road/seatposts/ ... ounts.html
PostPosted: Fri Sep 27, 2013 11:46 am
So does anyone have a solid answer as to whats needed to turn my ult 6770 DI2 into 11 speed?
Pat
PostPosted: Fri Sep 27, 2013 11:52 am
A Dura-Ace Di2 9070 rear derailleur and a firmware update.
PostPosted: Fri Sep 27, 2013 12:38 pm
I just wrapped some electrical tape at each end of the battery to take up the gap and stuck it up in the post. Not very elegant but it was simple and a effective.
My Cervelo R5
My Lynskey Helix
My MTB
PostPosted: Fri Sep 27, 2013 12:53 pm
http://ritcheylogic.com/road/seatposts/ ... ounts.html" onclick="window.open(this.href);return false;
Thanks.
Thanks guys. Seems that could be the better route than just dropping it into the seat tube.
PostPosted: Fri Sep 27, 2013 3:21 pm
Only a 9070 rear ? what about a 6870 rear?
PostPosted: Fri Sep 27, 2013 3:35 pm
I think they were responding to if you wanted 11 speed Di2 right now and just wanted to do the cheapest upgrade path to your 6770 setup. Or you can wait for the 6870 RD as you mentioned. But I believe you will be waiting until end of 2013 or first part of 2014 if you want the 6870 RD. Want 11 speed now, 9070 is only option.
PostPosted: Sat Sep 28, 2013 4:36 am
For those that might read this in the future, if you have a CAAD10 Black Inc and want to do internal battery upgrade, you only need two new wires (shifters) and not a third for seat post placement of battery. The stock battery wire is plenty long. I think it is around a 650mm wire length.
PostPosted: Sun Sep 29, 2013 12:25 am
Understood. so a 9070 rear D, obviously an 11 speed cassette and a firmware update. not too bad at all. how can I go about the getting the update?
Pat
PostPosted: Sun Sep 29, 2013 12:33 am
Pat, which junction box A do you have?
If you have the newer SM-EW90 A all you need is the associated battery charger, SM-BCR2.
If you have the older SM-EW67A-E you will need the SM-PCE1 PC interface.
If I am wrong, someone can correct me on that.
PostPosted: Sun Sep 29, 2013 4:13 am
That's exactly right.
My RCA
PostPosted: Sun Sep 29, 2013 1:56 pm
If you are okay with soldering your own adapter, it is possible to use SM-EW67A-E and SM-BCR2. Pls see my earlier posts in this thread -
http://weightweenies.starbike.com/forum/viewtopic.php?f=3&t=107887&start=120#p988819
There are no new unread posts for this topic. Dogma F8 hydro disk brakes/ Di2 Ultegra vs Cannondale SuSix Di2/Ultegra
bikebike
Sat Oct 29, 2016 4:41 am
bikebike View the latest post
There are no new unread posts for this topic. Next Gen Ultegra...
Conradsleight
Thu Jun 30, 2016 9:46 am
jeffy View the latest post
There are no new unread posts for this topic. Ultegra DI 2 Dead
FOILOSI
13
1206
Mon Mar 14, 2016 11:41 pm
glepore View the latest post
There are no new unread posts for this topic. Ultegra update?
AW84
15
2675
Sun Nov 20, 2016 7:06 pm
Lelandjt View the latest post
There are no new unread posts for this topic. Dura ace Hub - Ultegra freehub?
damond
Tue Sep 20, 2016 2:31 pm
damond View the latest post
Users browsing this forum: Baidu [Spider], chiumomo, Google Adsense [Bot], mnmasotto and 32 guests
