It is currently Mon Jan 22, 2018 7:50 am
Post new topic  Reply to topic  [ 359 posts ]  Go to page Previous 19 10 11 12 1324 Next
PostPosted: Sun Jun 16, 2013 6:17 am
Apologies if this has been asked/mentioned before but, what's the word on Ultegra Di2 going 11 speed along with the mechanical group. I'm assuming it'll go that way same as DA did but I haven't seen any confirmation.
K2
Do you suffer more when you train, or cannot train?
PostPosted: Sun Jun 16, 2013 11:35 am
viewtopic.php?f=3&t=115279&start=15#p983450" onclick="window.open(this.href);return false;
from
viewtopic.php?f=3&t=115279" onclick="window.open(this.href);return false;
Waiting for official announcement - soonish..
PostPosted: Mon Jun 17, 2013 10:58 am
And likely to be a Hydraulic disc version at the same time .... ;-)
PostPosted: Wed Jun 19, 2013 10:44 am
Here is the solution for using the SM-BCR2 charger with the SM-EW67A-E control box by using the EW-SD50 cable connection.
Cut the connectors off the charger and connect it like this. I have not yet tried to use it for updating the firmware and charge the battery directly on the bike, but that will be the next step this evening.
I'll have connectors made so that it's easy to change between the the two different connector types.
It's online again:The Machinist
My CAAD10:http://weightweenies.starbike.com/forum/viewtopic.php?f=10&t=109014
PostPosted: Wed Jun 19, 2013 11:27 am
It should work with updating firmware as well. IIRC, besides SM-BCR2, only the battery is required for updating firmware, i think i updated components separately that way. However, i didn't want to cut the parts, therefore make my own adapter to connect the cables.
My opinion is that components(shifters, derailleurs, internal battery, junction A etc) that can be updated have electronic chip embedded in them, while others like junction B are simply 2-wire conductors.
PostPosted: Wed Jun 19, 2013 9:06 pm
It works!
PostPosted: Sat Jun 29, 2013 9:42 pm
New firmware is available for the charger and internal battery as of 20th June. Anyone has some insight to what it does? The notes just says Improvement of useability. I guess it's something relating to the charging of the battery as only these two components are included.
PostPosted: Sun Jun 30, 2013 6:39 pm
Thanks Anders for that.
PostPosted: Mon Jul 01, 2013 3:00 am
Anyone noticed the picture in the update screen changed from a 5 arm crankset to a 4 arm crankset?
PostPosted: Tue Jul 02, 2013 11:07 am
I just have to say this.
I had my first ride with my new Ultegra Di2 group today and, even though I can't recall ever being impressed with any piece of electronics I've bought, electronic shifting is awesome. Easily the best money I've ever spent.
K2
PostPosted: Tue Jul 02, 2013 7:04 pm
Hey all, got a DI2 issue, maybe somebody here can help me out.
Sometimes my battery suddenly discharges... For instance I charged it last night, but it on my bike and it was depleted again in the morning just by standing in one of my rooms. Any thoughts?
PostPosted: Wed Jul 03, 2013 3:51 am
As notaero mentioned earlier, the shift button(s) might be pressed. If that's not the case, you can try disconnecting each component one at a time to isolate the problem. Updating to the latest firmware might help as well.
PostPosted: Sun Jul 28, 2013 5:43 pm
Hi
Anyone had any luck getting e-tube to work with Parallels on the Mac?
Can get it to load and the drivers appear to install, but won't recognise the usb connection "Connect the SM-PCE1/SM-BCR2"
I hear VMware works OK but already have Parallel installed.
thanks in advance
JP
PostPosted: Mon Jul 29, 2013 3:35 am
@JP
Maybe there is a setting in parallels that lets you determine which "machine" the USB item is connected to. In other words, perhaps the Mac is "connected" to the BCR-2 and not releasing it to the Windows virtual machine, so Windows VM does not "see" it. There is a setting for this in VMWare. I can only assume that this functionality would also be in Parallels as well.
PostPosted: Mon Jul 29, 2013 9:55 am
Hi,
Mac user and spent ages trying to get parallels to recognise the shimano kit. It never did. Thought it was the BCR2 that was faulty but I had purchased it from Germany and it would have been a pain to return. So I tried VMware and it worked and still does. Got a refund on parallels and purchased the VMware licence.
There are no new unread posts for this topic. Ultegra 6770 Di2 Auto-trim?
Staffan
Sun Nov 05, 2017 1:35 pm
glepore View the latest post
There are no new unread posts for this topic. Need schematic of rd 6770
yumseyo
Mon Jun 05, 2017 8:59 pm
yumseyo View the latest post
There are no new unread posts for this topic. New Ultegra (Di2) ???
stormur
Thu Mar 23, 2017 10:42 am
stormur View the latest post
There are no new unread posts for this topic. Ultegra brake
Timmy269
Fri Oct 13, 2017 1:08 pm
Timmy269 View the latest post
There are no new unread posts for this topic. Does XT di2 fits to Ultegra di2 shifters [11 sp]
johancoenen59
Thu Jun 01, 2017 2:36 pm
PinaRene View the latest post
Users browsing this forum: crux, dalex, Google Adsense [Bot] and 27 guests
cron
