goodboyr wrote:Works with the older junction just fine.
yes ,it does
bonafide wrote:Hubert, how about chainrings? Will theh 9-10 speed chainrings work or do we have to buy 11-speed?
Thanks
Choco wrote:I think my issue is that I am able to upgrade all firmwares except the EW67.
I have two Di2 bikes, one with an EW67 and another with the new EW90 + BCR2.
I have been upgrading firmware using the EW90/BCR2, but you can't plug another junction (EW67) into the EW90 to upgrade... if that makes sense?
The only solution I see is to use a PCE1? - bugger that.
Hubert wrote:Have you tried using the SMEW90 on the SMEW67 bike? If you had two extra 350mm wires, you could try your EW90 to upgrade the firmware on the SMEW67A bike and then use the BCR2 charger to do the update.
Failing that, you'll need to get your hands on an SMPCE1 and once you've upgraded the firmware on that bike, you can replace the SMEW67 with SMEW90A/B.
dha wrote:Have just upgraded to internal battery and the SM-BCR2. However when I connect the BCR2 with the e tube software I get "connect the SM-PCE1/SM-BCR2." message even though it is connected. Charges fine. Do I have a defective unit?
dha wrote:Yeah running parallels, when I plug the BCR2 in it recognises it and asks if I want to run it in windows or mac OS. I always select the windows option.
415brian wrote:dha wrote:Yeah running parallels, when I plug the BCR2 in it recognises it and asks if I want to run it in windows or mac OS. I always select the windows option.
Seems more likely a problem with parallels than the BCR2. Are you running Windows 8? I recall someone else on the forum having problems with Win8 and the Shimano software. I'm running Win7 on VMWare without issue. Could you borrow a Windows 7 machine from someone else to test?
MisterNoChain wrote:http://www.bikeman.com/DP6203.html
It has article number Y5JD98030 at shimano if you want to look for it on other sites, or order it at your LBS
01.01.1970:Jagwire Elite link cable review | |
01.01.1970:Review: Elite Cannibal Bottle Cages | |
01.01.1970:Giro Trans E70 review | |
01.01.1970:Vittoria Rubino Pro 3 review | |
01.01.1970:Specialized S-Works Power Test |
01.10.2017:Sigma ROX 11.0 Review | |
07.09.2017:DT Swiss RR411 Rim | |
12.05.2017:Campagnolo Update Centaur to 11 speed | |
09.03.2017:New Mavic Open Pro rim | |
05.03.2017:Ding Bike Lights ? a first look |
