Post new topic Reply to topic  [ 25 posts ]
Go to page 1, 2  Next
PostPosted: Thu Oct 04, 2012 12:15 pm
So, I have a rather annoying squeak emanating from my bottom bracket, it went away for a while but has now returned with a vengeance when I ever I any torque into the cranks (climbing steep hills).
I have a spare set of bearings and also the tool for removing and replacing them bearings but before I do is there anything I can do to remediate the problem of squeaky ceramic bearings ?
The bearings were part of the groupset bought new in 2011 and probably has 3000kms on it. Is this the expected life of the bearings or is there somehting I can do to get rid of the infernal squeaking noise ?
I have been given all sorts of information from lubing the bearings to using graphite dust (sanded down from a pencil) to make things a bit quieter.
I'm planning a long day in the saddle on the weekend and can't bear another 6-8 hours of squeaking !!!
All help / advice gratefully received.
Cheers :-)
Enigma Echo
PostPosted: Thu Oct 04, 2012 12:32 pm
I just serviced my sr bearings 2 wks ago. Past due... I have about 16k miles and I believe service is recommended annually. Anyway mine were more of a creaking noise on steep climbs.
Just pull the cranks and I used a squirt of triflow, blew it out with compressed air, another squirt in each bearing and put it back together. Perfectly simple. And all is quiet.
TIME RXR
PostPosted: Thu Oct 04, 2012 1:11 pm
Hi,
What is triflow ?
Thanks,
Simon.
Enigma Echo
PostPosted: Thu Oct 04, 2012 2:08 pm
Tubbie Guru
Hi,
What makes you so sure it's caused by the bearings?
It may be just some dirt/sand that got stuck somewhere so before actually replacing the bearings (they're made to last like forever) I'd first check and clean the entire crank installation, spray the bearings clean and relube them while I am at it.
Triflow is a synthetic fine oil charged with friction reducing additives. A sewing machine standard fine oil should do nicely. The lube is only there to quieten down the sound of the bearings which a lot of frames tend to amplify somewhat.
Ciao, ;)
PostPosted: Thu Oct 04, 2012 2:18 pm
What type of frame and bottom bracket size are you using ? Regular BSC ?
PostPosted: Thu Oct 04, 2012 3:42 pm
fdegrove wrote:
Hi,
Ciao, ;)
I'm fairly certain the noise is emanating from the bearing, it is definite squeak as opposed to a creack that is quite often found due to badly installed / dirty bearing cups.
Would it be ok to use GT85 to clean / lube the bearings. It is a thin lubricant with PTFE additive.
Frame is an Enigma Echo (Ti) BB is English thread (68mm?)
Enigma Echo
PostPosted: Thu Oct 04, 2012 4:03 pm
Simonhi wrote:
Hi,
What is triflow ?
Thanks,
Simon.
Triflow is a brand of lubricant. It's available at just about any bike or hardware store. It's cheap and doesn't gum up.
KAC
PostPosted: Thu Oct 04, 2012 8:08 pm
Tubbie Guru
Hi,
Sure.
The oil Campa is using is standard lube class LU2116, Triflow adheres to this standard but I don't know of any others. I know wher to find it on the continent, no idea who sells it in the UK though. As said before it is not crucial at all.
Ciao, ;)
PostPosted: Thu Oct 04, 2012 8:58 pm
Is it the bearings or is it the cups? If the cups look polished or show some wear, change them. I have a few bike with UT chainset and some seem more susceptible than others to this feature
PostPosted: Thu Oct 04, 2012 10:54 pm
fdegrove wrote:
Hi,
Sure.
The oil Campa is using is standard lube class LU2116, ... clipped ...
Ciao, ;)
Thanks FDE, it's handy to know :mrgreen:
I'll check this out also, thanks :thumbup:
Enigma Echo
PostPosted: Fri Oct 05, 2012 9:12 pm
Update ...
So, it turns out the bearings were shot on the drive side.
Pulled bearing off drive side axle to clean and inspect, very gravelly feeling, not smooth. I guess maybe at some stage one of the bearings in the race got scored / stopped rolling somehow.
Pressed the new set in both sides and went for a spin, definitely the bearing(s).
I'm gonna accept this as bad luck because I don't want to be buying new Campagnolo ceramic bearings at £120.00 a pop every 3,500km.
Another first, pulling and replacing bearings.
It should make tomorrows ride a ton more enjoyable, and maybe easier !!!
Enigma Echo
PostPosted: Fri Oct 05, 2012 9:43 pm
3,500 km?
That sounds just about right, in my experience. Maybe less with inclement weather riding.
I think pulling them off and adding a coat of a good grease may help.
PostPosted: Fri Oct 05, 2012 10:17 pm
Maybe I need to pull them apart more often to clean through ???
It seems that if the bearing was not faulty maybe a small piece of grit / dirt got in the there and affected the smooth operation I was used to up to about 3000km ?
Either way I think I will have a trouble free ride tomorrow, unless I catch a flat !!!
Enigma Echo
PostPosted: Fri Oct 05, 2012 10:19 pm
shillc wrote:
3,500 km?
While grease could be used....save it for steel bearings (Record level and below) that really need it.....as the SR's are intended to be oiled.
PostPosted: Fri Oct 05, 2012 10:47 pm
Any specific oil ?
I'm thinking GT85 with PTFE (Teflon) to flush through every now and then.
Cheers :thumbup:
Si.
Enigma Echo
Post new topic Reply to topic  [ 25 posts ]  Go to page 1, 2  Next
Users browsing this forum: adhumston, Google [Bot], Tom-s and 64 guests
There are no new unread posts for this topic. Bottom bracket question
BreakfastClub
11
609
Mon Feb 18, 2013 11:13 am
There are no new unread posts for this topic. Attachment(s) Help, SRM FSA K-force - which bottom bracket?
srasmussen
Wed Aug 29, 2012 8:20 am
There are no new unread posts for this topic. Enduro XD-15 Bottom Bracket?
BdaGhisallo
Mon Apr 15, 2013 7:14 pm
rmerka View the latest post
There are no new unread posts for this topic. Dura Ace Bottom Bracket Drag
kulivontot
19
1864
Wed Oct 10, 2012 7:51 am
ticou View the latest post
There are no new unread posts for this topic. Bottom bracket for Rotor 3D with Power2Max PM
Frankie13
9
811
Fri Oct 26, 2012 8:30 am
madmole View the latest post
It is currently Fri May 24, 2013 12:37 pm
