It is currently Wed Feb 22, 2017 9:36 am
Post new topic  Reply to topic  [ 13 posts ]
 Post subject: Fizik Arione set up
PostPosted: Wed Oct 03, 2012 4:46 pm
Im about to get my new Arione saddle, and I was wondering what people do for their setup, leveled, nose down, nose up, or what should I start with, level and take it from there, just need little advice, thanks
 Post subject: Re: Fizik Arione set up
PostPosted: Wed Oct 03, 2012 5:02 pm
Been fine with all 3 of mine being setup level.
PostPosted: Wed Oct 03, 2012 5:30 pm
Ive ridden the Airone level for years, you should be fine with it level.
www.cyclingtechnology.com
PostPosted: Wed Oct 03, 2012 8:38 pm
How do people deal with the extra length of the Arione? I'm going from saddles that are 275mm in length to the Arione which I believe is 300mm in length. Do you put the extra length in front, in back, spread evenly fore and aft? Any other Arione tips are appreciated.
I've been riding the Arione for a month. Have mine slightly tilted up, but that's how I've always ridden saddles. I haven't tried it level. Regardless, I'm surprised how much I like this saddle.
PostPosted: Wed Oct 03, 2012 9:17 pm
Don't listen to me because I hate the Arione... but it worked least bad for me slightly nose down. However, I think this is one of those cases to go with conventional wisdom and try it level before messing around. As for fore-aft placement, I'd start close to your normal nose to handlebar measurement, sit on the saddle and see if your weight balance is similar to usual, then adjust from there...
PostPosted: Thu Oct 04, 2012 12:47 am
The Ariones extra length is all in the tail - the distance from nose to sit-point is the same as most standard mens racing saddles. So don't spread the length difference fore-aft
Most people that like them are happy with level or fractionally nose down. Pay attention to whether you get increased hip motion with the saddle - I move a lot of clients off the Arione because the rounded shoulders and wingflex give little support for the hip bones.
http://www.speedtheory.co.nz
http://www.velogicfit.com - 3D Motion Capture and Frame Finder Software
PostPosted: Thu Oct 04, 2012 2:35 am
nothing beats taking an allen wrench w u for a ride and try a few different positions. everyones sit bones r a bit different.
Fast falcons: http://www.youtube.com/watch?v=j3mTPEuFcWk" onclick="window.open(this.href);return false;
www.falcobike.com
Facebook: falcobikeglobal
PostPosted: Thu Oct 04, 2012 10:20 am
In level.
Using 4 Ariones... :)
PostPosted: Sun Oct 07, 2012 5:28 pm
Dead level. I have a standard Arione and a CX carbon-railed version. Positioning is identical, but the CX seems considerably more firm. That being said, the CX is a only couple of months old versus the standard model that is several years old.
PostPosted: Mon Oct 08, 2012 1:42 am
The nylon Arione's do sag a little but I found they're more comfortable than the carbon shell version...I ride level but position for whatever suits you, taking an allen key on rides is handy...
"It never gets easier, you just go faster..." - Greg Lemond
"I enjoy climbing...I enjoy seeing people disappear behind me." - Robert Millar
PostPosted: Mon Oct 08, 2012 2:10 pm
Note. There is CX braided and CX carbone. The later is even more firm than the braided.
Standad Arione is far too soft for me.
PostPosted: Mon Oct 08, 2012 3:56 pm
Not that it matters, but 2 degrees down.
The best set up Ive seen so far though is watching a triathlete use one turned backwards.
charles@pezcyclingnews.com
PostPosted: Mon Oct 08, 2012 6:10 pm
I've been on the Arione Versus for a month now. The one with the channel down the middle. Best saddle I've used. I'm addicted to it. Tilted up slightly has worked best for me. Will be replacing my other saddles with this one.
There are no new unread posts for this topic. Anyone using a Fizik stem?
burglarboycie
20
1833
Sat Apr 09, 2016 2:50 pm
burglarboycie View the latest post
There are no new unread posts for this topic. Fizik R1B Uomo
lw11
12
1477
Sun Nov 20, 2016 8:57 pm
DJT21 View the latest post
There are no new unread posts for this topic. Fizik Antares R1 vs 00
rheosibal
Sat May 14, 2016 5:28 am
Rick View the latest post
There are no new unread posts for this topic. Fizik Bibshorts
lone wheeler
Sun Oct 30, 2016 11:35 am
lone wheeler View the latest post
There are no new unread posts for this topic. Fizik Cyrano R1 seatpost
burglarboycie
13
864
Fri Aug 26, 2016 10:18 pm
nohands View the latest post
Users browsing this forum: Bing [Bot], glam2deaf, Google [Bot], lovemyway, ryanw, Sleepless, wootenlakeguy, Yahoo [Bot] and 22 guests
