Post new topic Reply to topic  [ 14 posts ]
PostPosted: Tue Oct 02, 2012 12:01 am
reaching into the absurb to get TT bike lighter............anyone have any ideas to take some grams off the shimano dura ace heavyweight pedals?
PostPosted: Tue Oct 02, 2012 8:33 am
Get speedplays! 8)
CARPE DIEM
Colnago C59 Italia GLBK
Up coming custom steel cyclocross :D
PostPosted: Tue Oct 02, 2012 5:56 pm
Or some Looks Keo carbon Ti. Speadplay do have bearings problems apparantly.
www.thecycleclinic.co.uk
PostPosted: Tue Oct 02, 2012 6:00 pm
I've just replaced my speedplays zeros with Dura Ace. If you take into account the all up weight including cleats, the Dura Ace are lighter by 26 grams.
PostPosted: Tue Oct 02, 2012 9:54 pm
DuraAce PD7900 or PD9000 are not that heavy. And taking into account the excellent durability, large contact area and a solid and safe feel, these are the best pedals for serious use.
These pedals last for years, maintainance free.
PostPosted: Tue Oct 02, 2012 10:01 pm
Are you comparing actual weights including cleats? The Speedplays are very light but the cleats are heavier. You can lose weight overall with some ultralight pedals but you risk breakage and they tend to have things go wrong faster. As mentioned many times above and in other threads, the Dura Ace pedals are simply bulletproof. There are a couple things you really don't want to have break on your bike, and your stem and pedals are at the top of the list.
PostPosted: Wed Oct 03, 2012 3:44 pm
Some numbers:
Dura Ace PD7900 weight is something like 250g for pedals plus 75g for cleats and hardware = 325g
Time RXS Titanium 195g plus about 115g for cleats = 310g - later versions a bit lighter but don't work as well IMHO
Speedplay Nanogram 130g plus 85g cleats = 215g
Speedplay Zero 164 plus 118g cleats = 282g
So my recommendation would be to go for the DA or Time pedals on the basis that the Speedplays introduce more hassles than the weight reduction is worth. If you add cafe covers for the Speedplays then they're probably worse in system weight. Also the Speedplays are a bit lighter their non tolerance for walking, dirt and requirement for regular maintenance plus their dubious business practices (search the site for details) put me right off.
PostPosted: Wed Oct 03, 2012 4:14 pm
mrfish wrote:
Some numbers:
Keo Blade Tis plus cleats are lighter than any of the above except the Nanograms, and reliable IME.
Agree re maintenance of Speedplays. Life is too short (if you have a remotely interesting life, and it's not just about cycling)
PostPosted: Wed Oct 03, 2012 4:41 pm
The Nanograms are only for racing. I found I was wearing out the speedplay cleats quite quick and the pedals seem to need a lot of TLC . The cleats cost nearly £40 to replace so I went over to look keos . I did like the double sided entry of the speedplays but they just have to many issues.
PostPosted: Thu Oct 04, 2012 9:08 am
Look cleats identical in weight to Shimano cleats.
Pair of Keo Blade Ti's - ~180...185g. I'd say that Shimano pedals are more durable than Keo Blades, though (also from own experience).
PostPosted: Thu Oct 04, 2012 9:53 am
If you want to save some dollars go for ultegra carbon:
http://www.flickr.com/photos/63001205@N04/6215139348/
PostPosted: Thu Oct 04, 2012 1:29 pm
To save weight and money get Keywin pedals
Success is how far you you bounce back up after being knocked down
PostPosted: Thu Oct 04, 2012 3:36 pm
broke down and bought the xpedo thrust 8 Ti...........however im going to take a grinder and see how much excess fat i can get off of my DA7800 pedals without screwing them up. will post results
PostPosted: Fri Oct 05, 2012 11:46 pm
Online
Time trialing and TT bikes are about efficiency (low watts resistance and of course high power output).......so you bought pedals that from what I understand use one or more bushings instead of actual ball bearing units. http://www.roadbikeaction.com/Product-R ... edals.html" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;
I'd also suggest sticking with the very, very nice DA pedals, NOT grind away to save a few measly grams, and focus on "improvements" to increase overall speed elsewhere - how about a build list and let the group make other suggestions.
Knowing at what speed you TT, the type of terrain, and the rider weight helps a lot too.............I'm a long time WW but I can also save watts and increase speed by more than just focusing on weight of the bike....especially when elevation gain or rapid acceleration is not a major factor....
Users browsing this forum: Bing [Bot], ewwhite, Google Adsense [Bot], tommasini and 48 guests
There are no new unread posts for this topic. New Shimano Dyna-drive Pedals???
CharlesM
Sat Sep 08, 2012 6:03 pm
Permon View the latest post
There are no new unread posts for this topic. Shimano Durace pedals PD-7400 & 105 PD-1050
adrp
Wed Sep 19, 2012 10:59 am
adrp View the latest post
There are no new unread posts for this topic. 10 speed Shimano crank/rings on 11 speed group Shimano
bigcalves
11
1400
Wed Oct 10, 2012 10:06 am
BdaGhisallo View the latest post
There are no new unread posts for this topic. New Look Keo 2 Max Pedals?
SolidSnake03
Tue Apr 23, 2013 11:53 am
SolidSnake03 View the latest post
There are no new unread posts for this topic. Speedplay X1 and X2 pedals
tantra
Sun Sep 30, 2012 9:51 pm
ECT View the latest post
It is currently Fri May 24, 2013 11:37 pm
