It is currently Fri Aug 18, 2017 12:06 pm
Post new topic  Reply to topic  [ 16 posts ]  Go to page 1 2 Next
PostPosted: Mon Oct 01, 2012 10:19 pm
Hello all,
I am on the lookout for a computer which i can use on my rear wheel, i would like to have a really accurate reading since the rides i usually do are hilly and twisty, so will involve my front wheel flailing around a bit. Any recommendations? Cadence or not, butit must be wireless, only trouble is the normal range is 80cm tops, and i need about 95 comfortably.
Thanks
No, I am not trying to sell you something.
PostPosted: Mon Oct 01, 2012 10:39 pm
Velomann 16 fucntion with cadance. Mount on the rear stays and the one sensor picks up the pedal and spoke magnet. I use one.
www.thecycleclinic.co.uk
PostPosted: Mon Oct 01, 2012 10:42 pm
A Bontrager Node 2 has a range of 1.5M/5'. It works fine when paired with a Garmin GSC-10.
PostPosted: Tue Oct 02, 2012 12:35 am
cat eye has a computer that gets set on the chainstay and has an inner and outer sensors. i believe is called the v3. my friend has it and it seems reliable, compact and a clean installation.
PostPosted: Tue Oct 02, 2012 12:56 am
My old Polar CS600X with the WIND transmitters used to work fine with the speed sensor mounted right at the hub of the rear wheel. About as far away from the computer as you can get.
PostPosted: Tue Oct 02, 2012 3:11 am
cateye strada digital wireless can have the speed sensor mounted at the fork or chainstay. its small, clean, intuitive, robust, etc.
PostPosted: Tue Oct 02, 2012 9:56 pm
Garmin Edge 500 or 800 has the speed/cad sensor on the back wheel
PostPosted: Thu Oct 04, 2012 9:15 pm
I couldn't get my Strada Wireless to work consistently when the sensor was mounted on the chainstay. That was after checking the batteries in the head unit and sensor were okay.
The manual says the max transmission range is 70cm. I was running it close to 90cm so it may work on smaller frames.
PostPosted: Thu Oct 04, 2012 9:37 pm
the strada digital wireless is a completely different beast from the standard strada wireless. the manual actually states it can be used for front or rear wheel. its compatible with their 2.4g speed/cadence sensor when purchased separately, and you can activate a field on the screen for cadence. it also does heart rate and comes with a heart strap, 2.4g digital of course. quite a value IMO at a little over a hundred bucks.
oh, and powerful LED lights dont affect its readings.
PostPosted: Fri Oct 05, 2012 11:45 am
Cateye Micro Wireless definitely would not do it. I tried to set one up on my motorbike - no good.
You can't be a real country unless you have a beer and an airline. It helps if you have some kind of a football team, or some nuclear weapons, but at the very least you need a beer.
-- Frank Zappa
PostPosted: Fri Oct 05, 2012 5:30 pm
i think you'll find the front and the back wheels do the same distance, well it may be very very slightly different due to the different lines they take. Any way dont you what to know how far you have been not the wheels so really you need one on the front and one on the back then you could average the readings (-;
PostPosted: Sat Oct 06, 2012 10:49 pm
Maybe not, remember the cinelli laser?
PostPosted: Sun Oct 07, 2012 9:45 pm
wheel size affects rotating speed of the wheel not distance traveled so my comment is correct (-;
PostPosted: Thu Oct 11, 2012 5:31 pm
you may have won the battle!...
PostPosted: Fri Oct 12, 2012 3:49 am
what if the bike had a reeeaaaaallly long wheelbase? and i get the idea of averaging the two wheels out, but i would find the distance from my... waist ... to the front wheel axle, and from my waist to the rear wheel axle, and use that to weight the importance of each wheel's distance. i mean, if youre gonna go through all the trouble, might as well go all the way.
There are no new unread posts for this topic. Sram etap range
wootenlakeguy
Sat Nov 05, 2016 9:39 am
Nefarious86 View the latest post
There are no new unread posts for this topic. Shimano di2 wireless patent
ooo
10
1406
Tue Sep 20, 2016 2:19 pm
Ritxis View the latest post
There are no new unread posts for this topic. FSA K-Force WE Wireless Electronic groupset
Miller
Thu Jul 13, 2017 6:50 am
There are no new unread posts for this topic. How long u'r saddle last?
3Pio
29
1507
Thu Aug 10, 2017 10:00 am
kgt View the latest post
There are no new unread posts for this topic. SRAM Long-Pin/GXP and Short-Pin/BB30 Chainrings
Valbrona
Sat Jan 21, 2017 3:21 pm
darnellrm View the latest post
Users browsing this forum: Bing [Bot], CarlosFerreiro, Discoverspeed, Exabot [Bot], gmarsden, HaroldC, leej88, Monkeyfudger and 50 guests
