Post new topic Reply to topic  [ 6 posts ]
PostPosted: Fri Sep 28, 2012 3:35 pm
Hello,
I'm changing my cranks from 172.5 to 175,must i drop the saddle 2.5mm or less or not change it at all?
all advice :welcome:
Thanks a lot guys!
PostPosted: Fri Sep 28, 2012 5:08 pm
Don't change your saddle height at first. Mount your new cranks and only adjust the height if needed to smooth out your pedal stroke. No number, angle or calculation can predict what saddle height/crank length will allow you to produce the smoothest pedal stroke your capable of.
PostPosted: Fri Sep 28, 2012 7:01 pm
Why? Go for an extreme drop, more aero and looks cool .
PostPosted: Fri Sep 28, 2012 8:37 pm
I would drop it 2.5mm. Maximum leg extension is the primary factor in setting saddle height and you will increase it unless you drop the saddle.
PostPosted: Fri Sep 28, 2012 9:28 pm
Online
Try it first without dropping your saddle. You might find that there is no need to change.
As an experiment, I recently tried going from 165mm to 172.5mm and found that my regular saddle height worked best. (Since swapped out to 170mm cranks, again same saddle height as before.)
PostPosted: Fri Sep 28, 2012 11:57 pm
A tiny drop is most likely but if your hip angle is compressed this may be more of an issue (ride with a REALLY flat back??).....just try it ;) (I'd raise the 2 ish mm and get on with it...shoe height stack differences make more difference than 2mm BTW)
Used to race....got too wrinkly and old ;) Updated: Racing again! Thought this was unlikely! Eventually, I may even have a decent race!
Users browsing this forum: addictR1, bigkraig, Bing [Bot], dalex, deek, rmerka, sanrensho, TrekUk and 87 guests
There are no new unread posts for this topic. Attachment(s) ISP saddle height adjustment
rgamble
15
1273
Wed Nov 21, 2012 3:03 pm
There are no new unread posts for this topic. Attachment(s) Tune Speedneedle owners out there!! Saddle Height? :) :)
Estuche
Mon Oct 08, 2012 5:37 pm
Estuche View the latest post
There are no new unread posts for this topic. Bike fit question - saddle set back and stem length
Tubby531
10
668
Mon Jan 28, 2013 12:10 am
neeb View the latest post
There are no new unread posts for this topic. Attachment(s) Changing hubs.
jeza
11
630
Tue Feb 05, 2013 11:57 pm
jeza View the latest post
There are no new unread posts for this topic. HELP! Changing Look 695 ZED 2 bearings
Graysk
Fri Sep 21, 2012 7:52 am
Graysk View the latest post
It is currently Tue May 21, 2013 10:01 pm
