Post new topic Reply to topic  [ 26 posts ]
Go to page Previous  1, 2
 Post subject: Re: Latex failure
PostPosted: Fri Sep 28, 2012 3:15 pm
Horacio wrote:
The Vittoria tubes sound interesting. Where are you sourcing them?
Wiggle (UK) sell them, if it makes any differance, they are red in colour.
Focus Izalco Pro
PostPosted: Fri Sep 28, 2012 3:26 pm
A couple things:
A tube that is properly encased in a tire/rim is under very little stress (like almost zero).
Either the tube was improperly installed or hole was suddenly created in the tire/rim.
If the later did not occur, then revisit your installation procedure. The tube may not have been properly seated at the valve, causing the tube to fold under itself and stretch at that point. The tube must be installed with adequate pressure for it to have shape, and you must ensure that the sits straight (not twisted or folded), and the valve area must be pressed against the rim before inflating.
formerly rruff...
PostPosted: Fri Sep 28, 2012 8:36 pm
ticou wrote:
The sole advantage tubsies have, is to run at 130 psi, and the steel frames to massage it on the road.
If you are running tubulars at 130 PSI you are missing the point of running tubulars in the first place.
EM3
________________
My 2011 Cervelo R5
PostPosted: Fri Sep 28, 2012 10:16 pm
Tubbie Guru
Hi,
WMW wrote:
A couple things:
Agreed 100%.
The problem with the Michelin latex inner tubes however is that they're just too long making correct installation nigh impossible.
One possible solution to that is to opt for the smaller 18/20 model if you can find it.
Yet an other option is to cut the inner tube, remove whatever amount of slack there is and glue it back together. It's not that hard to do.
Of course the easiest way of all is to avoid those green latex inner tubes (which really are inferior latex tubes to begin with) and get yourself the real thing as used in top quality tubular tyres namely Vredestein latex inner tubes. They're way lighter too.
@szculdo: From looking at the pic of your inner tube I can assure you that it was neither heat, nor excessive braking that made it blow up.
Ciao, ;)
PostPosted: Fri Sep 28, 2012 10:48 pm
I've had great experience with the Champion tubes, poor with the Michelins. They don't age well, but if you trust Al Morrison's tests, the reduction in rolling resistance is substantial, and they likely reduce the rate of flats due to their increased suppleness.
You do need to take care installing them.
http://djconnel.blogspot.com/
Fuji SL/1
PostPosted: Sat Sep 29, 2012 6:41 am
EM3
No, I'm just riding standard ZX's with light inner tubes.
PostPosted: Sat Sep 29, 2012 12:49 pm
Champion tubes? Is that a typo were you meant to type Challenge latex tubes?
PostPosted: Sat Sep 29, 2012 7:58 pm
I use Michelin latex inners only.
Once I was taking off the outer Michelin Pro 3, because it was worn out.
I found that I had installed the inner incorrectly, it was pinched between the rim and the Pro 3.
It did not flat for thousands of kilometers. Must have been very lucky, or maybe they are not that fragile.
PostPosted: Sat Sep 29, 2012 8:37 pm
I too have been using Michelin latex for about 15 years, with thousands of miles of trouble free and reliable service, and not one single failure. I can't find anyone in US who stocks them anymore...been relying on Ribble in UK for spares.
EM3
________________
My 2011 Cervelo R5
PostPosted: Mon Oct 01, 2012 8:45 pm
ave wrote:
I use Michelin latex inners... it was pinched between the rim
I know first hand that Challenge and Michellin latex tubes are not overly fragile having had similar experiences for both manufacturers latex inner tubes with narrower Reynolds Assault/DV46/SDV66 carbon clincher rims but was not as fortunate. Unfortunately on a couple different occasions the tubes did finally flat, typically in a very spectacular fashion with a loud report which shredded the sidewalls of Veloflex and Challenge open tubular tires. Since switching to wider Zipp 303 Firecrest wheels, although I have had a flat due to staples on the road surface, I have yet to observe a single instance of pinching of the latex tubes with either Challenge or Michellin latex tubes.
PostPosted: Tue Oct 02, 2012 5:14 am
I have had the same happen to my michelin tube,just after
fitting them i pumped it up to 120 psi and it started to leak.
It went down quite quick,i then took it out and it had a hole
in the same place as shown in your pic :noidea:
COLNAGO C59 MATT BLACK
VOLVO FH 12 480 BHP
Post new topic Reply to topic  [ 26 posts ]  Go to page Previous  1, 2
Users browsing this forum: Exabot [Bot], Google [Bot] and 43 guests
There are no new unread posts for this topic. Trek 6.9 bb90 failure?? Anyone experienced this?
dane476
12
1600
Tue Oct 23, 2012 9:36 am
aratchet View the latest post
There are no new unread posts for this topic. Campagnolo EPS Super Record Titanium Failure
jameskack
20
4096
Wed May 15, 2013 8:05 pm
snappypants View the latest post
There are no new unread posts for this topic. Super Record 11 Rear Mech Failure - any others out there ?
lycralout
21
1512
Mon Sep 24, 2012 5:11 pm
Powerful Pete View the latest post
There are no new unread posts for this topic. Latex tubes with Dura Ace 9000 c24 wheels
Horacio
7
890
Tue Jan 01, 2013 3:38 am
Horacio View the latest post
It is currently Thu May 23, 2013 7:39 am
