Post new topic Reply to topic  [ 26 posts ]
Go to page 1, 2  Next
 Post subject: Latex failure
PostPosted: Fri Sep 28, 2012 1:21 am
So i was with this girl and....
On a more serious note, today I had quite a frightening tube failure. I was descending and riding with someone not as comfortable going down so I was on my brakes more often. Right as I let off the brakes and leaned into a turn I hear a pop and my front wheel is instantly flat. Of course at this same moment there is a car coming in the opposite direction as I swerve a bit to get my bike under control. :? I'm really pleased I did not hit the guy or go down!
The failure happened near the valve stem at the seam (on the rim side and my rimtape is clean). I've read that latex has some issues with descending but this is the first time I have an issue. I'm usually very precise with my braking so today maybe I had more heat buildup than usual. I don't want to go back to butyl, but if it's a safety thing I don't have much of a choice. The remainder of the ride with a regular tube just did not feel as good.
Anyways I have added some pictures, Seems like even the tire around the valve stem was melted! I rode on it for maybe 50 yards finding a suitable place to stop. The rest of the sidewall looks ok but the spot right next to the valve stem was really sticky when i pealed that tube off. The tube has been used for quite some time, it may just also have been it's time.
My Lynskey R420 with Chorus 11
NEW Developments! If you are interested in a Weight Weenies kit please respond to the thread. I want to make the order happen before long.
 Post subject: Re: Latex failure
PostPosted: Fri Sep 28, 2012 2:07 am
Online
If you want to ride latex, stick with tubulars.
PostPosted: Fri Sep 28, 2012 2:38 am
Is that a Bontrager tube? I've had two fail prematurely, one with a split at the valve that looked similar to yours.
PostPosted: Fri Sep 28, 2012 3:15 am
What he said. Latex tubes can't always handle the pressures (literally) of being stuffed into a clincher.
My drawings:
http://www.facebook.com/andrewlivingstonart
My bike:
http://weightweenies.starbike.com/forum/viewtopic.php?f=10&t=107451
PostPosted: Fri Sep 28, 2012 3:40 am
I used to have the same issues with Michelin latex tubes. They'd always pop right at the seam edge and always on the rim side. I've been running Vittoria latex tubes all summer (knock on wood) without so much as a hint of an issue. I've heard that Vredestein and Challenge also make fine latex tubes, but have never tried them myself. So, before giving up on latex, try the Vittorias.
PostPosted: Fri Sep 28, 2012 3:49 am
If in fact, as you indicate, your tire was slightly melted as well, then I doubt that a butyl tube would have fared any better. EM3
________________
My 2011 Cervelo R5
PostPosted: Fri Sep 28, 2012 4:20 am
yeah i have no clue what happened on that descent. For all I know the tire was damaged after I flatted and the front wheel slid a bit.
I'll give one of the other brands a try. Latex just feels too good, and I'm not in a position where I want to be switching to tubulars.
PostPosted: Fri Sep 28, 2012 4:46 am
I've had two rear and one front failure with Mich latex tubes, all on descents. I'm not sure if the brake tract is overheating and causing the failure. Additionally, its only happened during the summer months. I've also gained a few extra lbs. So maybe all these factors have contributed to my failures. For the time being, I've gone back to butyl. I miss the latex ride tho.
The Vittoria tubes sound interesting. Where are you sourcing them?
PostPosted: Fri Sep 28, 2012 8:31 am
You can get Conti Supersonics at 60g's, so why bother with latex? I use slightly heavier Conti's, repaired a large twin spike puncture, and it's back at 130psi.
PostPosted: Fri Sep 28, 2012 8:52 am
ticou, I feel as though you miss the point of riding with a latex tube. And try riding with about 30 less PSI.
To the OP,
Failures happen. Thankfully you were not hurt. Latex tubes are bonded at a certain point and there are inherent flaws with that.
PostPosted: Fri Sep 28, 2012 10:03 am
The sole advantage tubsies have, is to run at 130 psi, and the steel frames to massage it on the road.
PostPosted: Fri Sep 28, 2012 10:37 am
Administrator
I could have been age too. Most of use ride tubes until they fail but over time both with harden with age and eventually fail. Maybe an annual replacement might be cheap insurance. I've already gone almost 6,000 miles this year on the same Michelin latex tubes and not one single flat.
PostPosted: Fri Sep 28, 2012 10:47 am
Wired...
I have done 2 Vredestein latex in that way. I mean punctures almost in the same spot as you described.
Checked tire, rim tape, plenty of talc. No idea what caused it.
The only difference, in my cases, deflation wasn't that dramatic. Slow enough to stop and still have an air in the tube.
Cervelo R5 VWD 5637g/12.43lb
Cannyon Ultimate slx 5592g/12.33lb
Pronghorn XC SW Race 8284g/18.26lb
PostPosted: Fri Sep 28, 2012 1:48 pm
It appears the failure was at a joint. The challenge latex tubes are constructed differently, with no overlapping join like that. I've had punctures/flats, but no big hole like shown in your pic.
“Tuco” in The Good, The Bad and The Ugly, “If you save your breath I feel a man like you can manage it. And if you don't manage it, you'll die. Only slowly, very slowly old friend.”
PostPosted: Fri Sep 28, 2012 2:28 pm
12 years ago this happen to me, except it was on the rear with a michelin superlight butyl tube. It did not end as nicely as the rear tire ended up unseated and got caught on the rear brake sending my flying on the road and ended in a ditch. Luckily no cars we around. I have been riding tubular almost exclusively ever since.
Post new topic Reply to topic  [ 26 posts ]  Go to page 1, 2  Next
Users browsing this forum: Bing [Bot], dgran, Google [Bot], Google Adsense [Bot] and 77 guests
There are no new unread posts for this topic. Trek 6.9 bb90 failure?? Anyone experienced this?
dane476
12
1594
Tue Oct 23, 2012 9:36 am
aratchet View the latest post
There are no new unread posts for this topic. Campagnolo EPS Super Record Titanium Failure
jameskack
20
4056
Wed May 15, 2013 8:05 pm
snappypants View the latest post
There are no new unread posts for this topic. Super Record 11 Rear Mech Failure - any others out there ?
lycralout
21
1510
Mon Sep 24, 2012 5:11 pm
Powerful Pete View the latest post
There are no new unread posts for this topic. Latex tubes with Dura Ace 9000 c24 wheels
Horacio
7
879
Tue Jan 01, 2013 3:38 am
Horacio View the latest post
It is currently Mon May 20, 2013 8:45 pm
