Post new topic Reply to topic  [ 35 posts ]
Go to page 1, 2, 3  Next
PostPosted: Tue Sep 25, 2012 3:46 pm
I have Dura-Ace 7800 pedal and I was looking to reduce weight by going to Look Keo Blade Carbon/Ti axle.
Is that the best option?
 Post subject: Re: New Pedals
PostPosted: Tue Sep 25, 2012 9:01 pm
Or you could do Keo blade or Keo2Max carbon and put aftermarket ti spindles in them.
My Keo2Max carbons are like 185 grams/pair and cost way less than a set of Ti Blades.
PostPosted: Tue Sep 25, 2012 9:20 pm
I found them online for $299 US Dollars with TI.
PostPosted: Tue Sep 25, 2012 11:21 pm
Check out Keywin if you want light weight and a solid design.
http://www.keywinpedals.com/
PostPosted: Wed Sep 26, 2012 1:39 pm
I would rather go with Look since they weight almost the same and are the company that invented clip less.
PostPosted: Wed Sep 26, 2012 2:14 pm
Look are great, I had then previously. But to discount Keywin, in favour of Look, on the logic you gave isn't really the best way to go about it.
If we all did that, we'd be on one type of wheel, frame and groupset.
PostPosted: Wed Sep 26, 2012 2:24 pm
I think the logic is pretty sound because Look pedals are ubiquitous and we are talking about a part that has consumable component. You can go into any bike store and get new cleats or get warranty service.
PostPosted: Wed Sep 26, 2012 2:51 pm
i have a pair of these, and are great !
http://www.tririg.com/articles.php?id=2 ... t_8_Review
PostPosted: Wed Sep 26, 2012 4:04 pm
I love my 7900 DA pedals. If you are coming off of the last generation DA pedals don't forget about them.
Pretty light, great durability.
PostPosted: Wed Sep 26, 2012 5:50 pm
I'm excited about the new UltraLites, although the cleat doesn't look very good to walk in.
http://djconnel.blogspot.com/
Fuji SL/1
PostPosted: Wed Sep 26, 2012 5:55 pm
The 7800 and the 7810 pedals are really worlds apart in performance and feel. Even though they are of similar part number.
7800 pedal:
7810 pedal:
Their weights are remarkably similar but feel and overall durability is quite different as the 7810 uses steel wear plates. And they are significantly wider, you can actually feel it. The 7900 is about 10% lighter than the 7810. So its still probably the best pedal they have due to the Alu body.
Other than weight, Keo2Max and SPD-SL pedals function quite similarly. But the main difference being the Shimano cleats will typically outlast the Look cleats 3:1. Especially if you stay/live in a city area that requires plenty of start / stops, over and above the normal coffee/drink stops.
If you're not in a big hurry, maybe you can hang around a bit and give the new Time Xpresso pedals a try. They are light and the iClic2 system its based on was pretty good as far as feedback on its useability went.
PostPosted: Wed Sep 26, 2012 6:09 pm
If you're looking for best function, stick with DA 7900.
For decent weight and function, I'd try some Time RX-series titanium. They are a bit old now, but the cleats work for years, don't snap and the pedals have none of the problems which the iclics had. The expressos might work, but then they might not.
PostPosted: Thu Sep 27, 2012 11:20 am
Found the Looks for $300 and they should be coming today. Thanks for your help and comments. I will give you my review of the Looks in a few weeks.
Thanks!
PostPosted: Thu Sep 27, 2012 12:09 pm
After 5 yeras with KéO Carbon and the problem getting in them I decided to try D-A 900. I do not regret that.
Simply far better pedals than KéO. More solid. Easier to klick in. Go D-A.
PostPosted: Mon Oct 01, 2012 3:35 pm
The Looks tend to hang sideways so clicking in is a little harder.
They less than half of the old 7800's and are very easy to clip out of.
Post new topic Reply to topic  [ 35 posts ]  Go to page 1, 2, 3  Next
Users browsing this forum: Anders, darnellrm, Exabot [Bot], fletch62, Google [Bot], motch, russianbear, simnorm and 51 guests
There are no new unread posts for this topic. Dura Ace 7800 Freehub body (al 10s only) alternative
styrrell
Tue Dec 11, 2012 5:45 pm
Mackers View the latest post
There are no new unread posts for this topic. Replace 7800 Dura Ace crank arms?
trysixty
Sun Dec 16, 2012 3:23 pm
sedluk View the latest post
There are no new unread posts for this topic. Black outer & inner chainring for SRM 7800 Dura Ace crank?
el condor
Sat Sep 22, 2012 10:23 pm
el condor View the latest post
There are no new unread posts for this topic. 7800 & 6600 crank-arm differences
verycreativeusername
Mon Jul 16, 2012 5:05 am
User Name View the latest post
There are no new unread posts for this topic. Bianchi 928 lugged carbon after a few rides. 7800 DA
skiezo
Sat Mar 16, 2013 9:02 am
Ride-Fly View the latest post
It is currently Wed Jun 19, 2013 11:37 am
