Post new topic Reply to topic  [ 4 posts ]
PostPosted: Mon Sep 24, 2012 8:37 pm
I can't use my NG brakes with my Zipp FC clinchers due to little slack between brakesurface and brakeshoe in widest position.
Zipp's are 26.5mm wide on brakesurface
Would kcnc be a possible option ?
Sram red is also a contender nevertheless the weight penalty.
They must be black.. :?
PostPosted: Mon Sep 24, 2012 8:54 pm
What size of brake pad shoes are you using?
Ciamillo makes both standard profile, low profile and ultra low profile.
The latter should give you those couple of mm's needed. Might be better than buying a new set of brakes, if you are satisfied with your NG's.
2012 Canyon Aeroad CF 8.0 Di2 (6.250 grams)
2010 Canyon Grand Canyon F6
2012 (2013?) Canyon Speedmax Evo (is ordered)
PostPosted: Mon Sep 24, 2012 9:01 pm
Hi,
Didn't know ciamillo had these other brakeshoes. I presume I have the standard ones.
Thanks for the input !
And yes I"m satisfied with these brakes. Would be a shame to drop them fwiw.
PostPosted: Mon Sep 24, 2012 9:30 pm
Have a look at cycling.ciamillo.com...
Other wise most of their retailers can tell you exactly which shoes (if any?) are suitable for your Zipp wheels.
Users browsing this forum: Bing [Bot], Dammit, ichobi, xis and 36 guests
There are no new unread posts for this topic. keep the zero gravity og-07 , or planet x cnc brakes
deermatt
19
1010
Fri May 10, 2013 2:18 am
totoboa View the latest post
There are no new unread posts for this topic. alternative of 404s
project3
9
893
Fri Feb 01, 2013 7:18 pm
NGMN View the latest post
There are no new unread posts for this topic. vittoira pave alternative.
canbakay
26
2899
Sat Nov 17, 2012 3:01 am
SpinnerTim View the latest post
There are no new unread posts for this topic. Alternative to Quarq putty
Martin.F
7
350
Sat Apr 20, 2013 1:14 pm
Martin.F View the latest post
There are no new unread posts for this topic. Alternative seatpost for Scott Foil
kampiakseli
Sun Oct 21, 2012 6:37 pm
Omiar View the latest post
It is currently Wed May 22, 2013 8:30 am
