It is currently Fri Dec 15, 2017 7:13 pm
Post new topic  Reply to topic  [ 4 posts ]
PostPosted: Mon Sep 24, 2012 4:39 pm
Hello.
For those that have a 695, can you tell me the height of the carbon spacer that goes under the C-stem? Also whats the gap between that carbon spacer and the rubber cover? I guess what I need to know is the height from the bottom of the c-stem to the top of the headtube.
Thanks!
PostPosted: Tue Sep 25, 2012 6:13 pm
About 25mm
15mm for carbon spacer and another cm give or take for the rubber gasket.
PostPosted: Tue Sep 25, 2012 6:34 pm
Spacer is 15mm. Rubber cover is nothing. You can push the stem towards it or remove it off if you like. I have cut the fork pipe those 15mm and removed spacer. Also my c-stem is -9 degrees position.
Is it possible to cut 2mm more, but that's all you can do.
Pics in my signature. But here is one full res.
http://www.pellossalo.fi/content/uploads/images/full/20120513_003.jpg
Tumppi
Team KAS-RAK: http://www.pellossalo.fi/pellossalonnousu/
My Look 695 SR + EPS : http://www.pellossalo.fi/content/uploads/images/medium/Look695EPS.jpg
http://www.pellossalo.fi/content/uploads/images/medium/20120513_003.jpg
PostPosted: Tue Oct 02, 2012 4:52 pm
Thanks for the measurements. It seems like that carbon spacer is not "load bearing" because the c-stem camps directly on the steerer tube and the compression of fork is done in the headset. Is the carbon spacer, therefore, just secured by the rubber spacer pressing down on it? Can you wiggle the carbon spacer with your hands because of this?
With that being said, could you theoretically cut the carbon spacer to say 10mm (grinding down 5mm) and cut the steer tube the down the same 5mm?
Also if you were to run a standard stem in the future, would you need a compression plug or can you still use the proprietary headset compression method, install a standard concial headtube cap/spacer, then mount a standard stem without using a compression plug inside the steerer tube?
Thanks!
Steve
There are no new unread posts for this topic. I've got a question for supersix evo owners
evan326
Thu Feb 16, 2017 4:18 pm
evan326 View the latest post
There are no new unread posts for this topic. Calling all BMC TMR or TM owners
addictR1
Thu May 25, 2017 4:30 am
addictR1 View the latest post
There are no new unread posts for this topic. Venge ViAS Owners
morganb
10
1196
Fri Sep 08, 2017 9:36 pm
pyrahna View the latest post
There are no new unread posts for this topic. FYI Australian stages owners
NiFTY
Tue Apr 18, 2017 8:01 am
sp3000 View the latest post
There are no new unread posts for this topic. Addict Owners...Questions
1spd
Tue Apr 04, 2017 7:35 pm
oreoboreo View the latest post
Users browsing this forum: FilmAt11, jmagoulas, kookie, Monkeyfudger, PinaF8, Rick, rsantos450, slowK and 49 guests
