Post new topic Reply to topic  [ 61 posts ]
Go to page Previous  1, 2, 3, 4, 5  Next
PostPosted: Mon Sep 24, 2012 2:27 pm
The frame is resting upon the hub's axle, not the skewer. You can actually ride a bike without skewers. It won't be safe, but it's entirely possible.
The skewer just secures the hub to the frame, that's it. But if the skewer is too tight/powerful in its clamping force it will in affect compress against the axle/bearings and hinder their movement.
Why would you want a skewer that applies too much force? :noidea:
Exp001
PostPosted: Mon Sep 24, 2012 2:44 pm
I use Tune DC14 and they work great.
They are a litte tuff on your hand during install but stay secure!
Quit light and look great as well but not cheap.
Pfeiffer's Rennrad Camp and Cycling Coach
Independent HED Wheels/Powertap Dealer
PostPosted: Mon Sep 24, 2012 2:53 pm
I agree. They don't need to be clamped super tightly. Over tightening doesn't achieve anything good.
They have to be structurally sound though. I've been using the cheapo Ti offerings and I'm a little nervous about them. I'll keep using them but I check them regularly.
r o y g b i v
PostPosted: Mon Sep 24, 2012 3:10 pm
Online
New style Zipp ti. They are relatively light but quite solid in feel and clamp force.
I am done with pure WW skewers. Not worth the hassle and risks involved- esp. on front. I ride dirt too.
I had a bad experience with Carbon-ti skewers. One day, I drove to the mountains to do a big ride and the front skewer broke when putting front wheel on. It was a huge waste of time for me and I didn't get to ride that day as a result.
-Deacon Doctor Colorado Slim
PostPosted: Mon Sep 24, 2012 3:26 pm
I have had good experiences with KCNC. Also the cheap China Aerozine skewers I picked up have been great. They look the same as the ones Berk posted but rebadged. Low cost, and mine weighed in at 41g.
PostPosted: Mon Sep 24, 2012 5:20 pm
munk93 wrote:
A pair of DA's. I like the feeling in my head, that no matter what, they will keep the wheels in place. And then I like the looks of them.
+1.
My Bikes
My Photoblog
PostPosted: Mon Sep 24, 2012 11:49 pm
DA for road and XTR for offroad. I bought them new from eBay.
PostPosted: Mon Sep 24, 2012 11:54 pm
Online
Better than failing when hitting a pothole at 50 mph*.
* Note: this is hypothetical. I have never had a QR fail while riding.
PostPosted: Mon Sep 24, 2012 11:58 pm
as said before, DA 7800 and 7900 skewers are my favorite. close cam is definitely the way to go after having had some incidents with open cam skewers.
PostPosted: Tue Sep 25, 2012 1:11 am
Tubbie Guru
Hi,
IMO there's more to it than just that alone.
A good skewer effectively couples the wheel to the frame so that not only it is well secured but moreover it also serves as a crossing point for vibrations (road buzz etc.) to be sunk into the frame's mass and subsequently dissipated as heat.
While the absolute weight of the skewer is of little relevance to achieve this, design details such as choice of materials, clamping area and of course clamping force are relevant to this.
Ciao, ;)
PostPosted: Tue Sep 25, 2012 1:23 am
been using Token TK223 for the past 4 years, never had a problem, 38g for the pair and price just as good
would never consider DA firstly the price but most importantly they weigh a tonne!
PostPosted: Tue Sep 25, 2012 2:26 am
DT Swiss RWS ratcheting skewers. First used this on one of my MTB disc rims to make getting the disc centered in the caliper more reliable when removing front wheel for transport (it works for this). I have them on my road bike as well but they are more bling than function for me on the road, they are quite secure and of reasonable weight. My second choice would be Dura Ace or XTR which were in use prior to switching to the DT.
PostPosted: Tue Sep 25, 2012 3:34 am
Ciao, ;)
This is an interesting point, and I think valid, however looking at some of the skewer pics posted by others in this thread, I don't see much difference between clamping areas. This is dictated by the side of the fork dropouts, which is pretty standard, and skewer ends are thus fairly standard so that people don't whinge that their expensive new skewers don't fit their forks.
Given that Titanium has pretty good tendencies to absorb and dampen down vibrations, would a Ti skewer be better than a steel one then?
Forks are fairly stiff laterally. The amount of play (pulling the blades apart) is pretty minimal, and requires a lot of force. If it didn't the fork wouldn't be worth a cracker round a corner. ~2-3000N of force to stop the fork blades pulling apart laterally ought to be plenty. Also, figure that the skewer stops the wheel falling downwards and out of the eyelets if the wheel is lifted off the ground momentarily. Anyone running >200kg front wheels? Of course this can be complicated off-road, for example if something hits the wheel from the top. But in road scenarios (this is a road thread), I doubt that's ever an issue except in a crash, then who cares.
For vibrations to transmit from the skewer to the fork blade, I doubt there would have to be much force involved. Lets halve those Newtons, so, say 1000N on each side. That's 100kg of weight. That's a lot of weight or force over a very small area. That's right, high pressure! Think that road buzz won't be transmitted to the fork blade? Hell yes! Whats a standard skewer end diameter, I dunno, lets say 1cm^2 (didn't ride my bike to work today...naughty boy...so can't measure it). That means that 1000N is pressing on 1cm^2. Or, in tyre pressure terms, ~1450psi.
Which is plenty of pressure to transmit road buzz!
:D
PostPosted: Tue Sep 25, 2012 7:16 am
if you look at the clamping area of a KCNC skewer and compare it with a campy one, the campy one is larger with a bigger contact area with the dropouts. The aluminium use is also much firmer and wider. The KCNC looks very cheap and yes it is much lighter too :D
PostPosted: Tue Sep 25, 2012 10:20 am
I tried to use kcnc on my master x-light and I just couldn't. The wheels were slipping no matter what. They worked fine on any carbon frame I had.
Wilier Cento Uno
Colnago Master X-light
Wilier 18carati
Post new topic Reply to topic  [ 61 posts ]  Go to page Previous  1, 2, 3, 4, 5  Next
Users browsing this forum: Bing [Bot], handler, micky, TrekUk and 87 guests
There are no new unread posts for this topic. Your favorite custom kits (that you can get online!)
iscarrr
11
1573
Fri Sep 14, 2012 1:05 am
TOflat View the latest post
There are no new unread posts for this topic. Favorite stem length for road biking?
[ Go to page: 1, 2, 3, 4 ]
jever98
50
2421
Sun Oct 28, 2012 4:55 pm
aermet View the latest post
There are no new unread posts for this topic. whats my next upgrade between these choices
Bianchi10
Tue Sep 25, 2012 1:10 am
Bianchi10 View the latest post
There are no new unread posts for this topic. CAAD 5.. with BB30???? whats going on?
Dimitri
Mon Jul 09, 2012 6:22 am
There are no new unread posts for this topic. Whats your take on pre set torque wrenches?
NGMN
10
657
Wed Apr 10, 2013 1:20 pm
euan View the latest post
It is currently Tue May 21, 2013 9:05 pm
