It is currently Mon Jan 22, 2018 5:15 am
Post new topic  Reply to topic  [ 3 posts ]
PostPosted: Sun Sep 23, 2012 12:30 am
Hi there-
Just installed a gorgeous set of Clavicula cranks with Praxis rings on my Time RXR VIP last week. Drive train is Campy SR 11, BB is THM with full ceramic bearings. Install went fairly smoothly (freezing the cranks did the trick in getting the axle through the bearings).
However, I'm having shifting issues -- chain drop when shifting from 53 to 39 when in the 3 largest cogs. I did the initial adjustment to no avail. Then I took it to a local LBS and that didn't work either. Next step was to another LBS, supposedly one of the major Campy retailers in the area -- no luck with that either. Finally, I took it to the most reputable high-end LBS in the state, which is about a 1.5 hour drive from my house. They're known for their well trained Campy techs -- who worked on the bike for about 30 minutes, test rode it around the block and everything seemed well. Took it out for a 50 miler this morning and it failed on my first "test shift."
Quite juked at this point as I never had this issue with the Campy SR 11 cranks. I'm hoping that a "chain catcher" is not my last option.
Any thoughts and recommendations/suggestions would be appreciated. Many thanks.
PostPosted: Sun Sep 23, 2012 5:18 am
Tim
Bring it over let me take a look at it.
2017 De Rosa King Xs
2017 Colnago C60
2017 Colnago Concept
PostPosted: Sun Sep 23, 2012 5:02 pm
Thanks -- when's a good time for you? Next weekend?
There are no new unread posts for this topic. Sram Etap shifting noise/problems shifting smoothness.
Allen254
10
927
Sat Jan 20, 2018 8:27 am
alcatraz View the latest post
There are no new unread posts for this topic. Attachment(s) THM Clavicula SE installation
adamdoc12
Tue May 23, 2017 2:00 am
audiophilitis View the latest post
There are no new unread posts for this topic. THM Clavicula SE BB86 questions
KaneChang
Sat Nov 11, 2017 7:04 pm
KaneChang View the latest post
There are no new unread posts for this topic. THM Clavicula SE on 2017 Supersix Evo
syvid
10
1525
Tue Aug 01, 2017 3:48 pm
jinnie799 View the latest post
There are no new unread posts for this topic. THM Clavicula SE: Go Matte or Glossy? And what is up with the BB30 version
ecl2k
Tue May 16, 2017 8:02 pm
4ibanez View the latest post
Users browsing this forum: cittris, Denavelo, Drpoomanchu, Gavin929, Google [Bot], Google Adsense [Bot] and 41 guests
