Post new topic Reply to topic  [ 100 posts ]
Go to page Previous  1, 2, 3, 4, 5, 6, 7  Next
PostPosted: Fri Sep 28, 2012 8:53 pm
I was able to check out the new group prior to interbike and then again at inerbike. It's nice and much improved over the 7900. The throw on the shifters is a bit shorter but some of it is perception as they placed the blades farther outboard so the throw seems shorter than it really is. Front derailleur is one of the best features. With the crank being only in 110bcd, changing combinations would be easy.
The only huge downside is wheel compatibility. Shimano said they are not going to make 11-speed freebody kits for their existing wheels so I would need to purchased all new wheels. Looks like there is a Sram Red grouppo in my near future for next year.
Scott
PostPosted: Thu Oct 04, 2012 3:44 pm
Which are the brands that have wheel sin their range for the shimano 11spd?
Mavic wheels with the shimano m10 body are already compatible.
At FFWD they offer a new 11spd shimano body.
PostPosted: Thu Oct 04, 2012 4:22 pm
madfiber too
PostPosted: Thu Oct 04, 2012 4:52 pm
You could build up a new set of wheels with the White Industries T11 hubs. They are 10 or 11 speed compatible, and they have decently wide flange spacing.
http://www.zencyclery.com
http://www.wheelbuilder.org
Dt Swiss and Chris king will be da11 compatible
PostPosted: Thu Oct 04, 2012 5:33 pm
It has very little DS offset... 15.5mm, with 38.5 NDS. IMO, that is far from ideal.
formerly rruff...
PostPosted: Thu Oct 04, 2012 6:34 pm
I think the DT 240 11 speed hubs have spaing L(33.0mm) and R(16.0mm). All shimano 11 speed wheels will be heavily dished and will require stiff rims. Carbon rims make sense for this drive train.
Campag 11 speed is a bit more sensible for once.
www.thecycleclinic.co.uk
PostPosted: Fri Oct 05, 2012 11:46 am
I've heard from a Campagnolo guy that the Campagnolo (and Fulcrum) will have and 11spd compatible body to use on the normal wheels.
Also Corima will have an 11spd shimano body for all their wheels by the begiining of march.
PostPosted: Tue Oct 23, 2012 6:54 pm
I have a pair of these wheels and am trying to figure out if they will run with the DA 9000 11 speed cassette. I've discussed the issue with a supplier in the UK - they say a freehub update to 11 speed will work - but they don't recommend using the biggest sprocket as the chain gets a bit too close to the spokes! I was told all current LW wheels, bought now, will work fine with DA 11 speed without any issue.
Does anyone here know any different? I'm tempted to maybe swap the freehub and see how it works. If it doesn't I'll have to sell the wheels and get some new ones :-!
Riding my road bike in North Wales
http://www.strava.com/athletes/keith_robertson
PostPosted: Tue Oct 23, 2012 8:18 pm
Going to make this the wheel compatibility thread, given that is a lot of what this boils down to.
PostPosted: Tue Oct 23, 2012 9:45 pm
LAN wrote:
Just measured a 9000 cassette, the total height of the cassette is 39,6mm
But the difference between Campagnolo 11-speed (3,85mm) and Shimano 11-speed is just 0,05mm per gear, so that should work ok.
So Campagnolo 11 speed wheels and cassette should in theory work with the rest of the Shimano 11-speed groupset? Wicked, if so.
becoming a mature cyclist
PostPosted: Wed Oct 24, 2012 2:41 am
a bit off topic but will dura ace 9000 cassettes work with campy 11 speed?
PostPosted: Wed Oct 24, 2012 5:00 am
Scott
Yup, and this is why after 20 years of riding nothing but shimano I refuse to buy anything of theirs again. :evil:
I have an entire new Sram Red group sitting here waiting to go on a new frame. (Also ordering Look keo blades to replace my worn D-A 7800 pedals.)
I honestly wish everyone would just boycott the new 9000. Maybe our collective voices would motivate them to either go back to 10sp or make 11sp compatible on old hubs.
I understand and accept progress, but adding an (unnecessary imo) 11th cog is not progress when you have to replace/rebuild every wheelset you use.
PostPosted: Wed Oct 24, 2012 6:21 am
WMW wrote:
It (WI T11) has very little DS offset... 15.5mm, with 38.5 NDS. IMO, that is far from ideal.
Are these the values you measured? Their website claims 16DS/38NDS offset. Just curious.
Regardless of the exact value, what would be the best lacing pattern for a 24 hole T11 mated to a HED C2?
Would you go for a 1xDS head-in/2xNDS?
PostPosted: Wed Oct 24, 2012 6:46 am
Yes, that is what I measured... but I don't have a real accurate rig. Someone else measured a 16mm DS offset... so it is somewhere in there.
If you never wish to use 11spd, then 1x,2x is probably best. 11 spd might still work anyway. WI flanges have a good record for durability, so can probably take the stress ok. 2x DS, radial heads-out NDS will also work. Using lighter NDS spokes can also help (currently building one with Pillar Mega Lites on the NDS).
formerly rruff...
Post new topic Reply to topic  [ 100 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6, 7  Next
Users browsing this forum: Bing [Bot], darnellrm, Google Adsense [Bot] and 62 guests
There are no new unread posts for this topic. Dura Ace 9000 FD compatibility
TimmS
33
4324
Mon Mar 04, 2013 8:16 pm
Berg View the latest post
This topic is locked, you cannot edit posts or make further replies. Dura Ace 9000 compatibility
insightt47
Thu May 16, 2013 5:47 am
insightt47 View the latest post
There are no new unread posts for this topic. DA 9000 rear derailleur compatibility
lannes
Wed Mar 06, 2013 4:58 am
Doolop View the latest post
There are no new unread posts for this topic. Bontrager Aura 5 - Shimano 9000 compatibility or Swap
drewb
Fri Oct 12, 2012 10:27 pm
drewb View the latest post
There are no new unread posts for this topic. Shimano DA 9000 11sp - any compatibility with Campag 11sp?
[ Go to page: 1, 2, 3, 4 ]
fivethirtyonepm
53
5764
Tue May 21, 2013 4:23 pm
WMW View the latest post
It is currently Fri May 24, 2013 1:27 pm
