Post new topic Reply to topic  [ 100 posts ]
Go to page Previous  1, 2, 3, 4, 5 ... 7  Next
PostPosted: Sun Sep 23, 2012 8:08 pm
jasjas wrote:
A better one would be Cameras - Canon V Nikon, (Campag v shimano) neither company brings out a new body or lense that has a different fit, everything is backward compatable - Shimano 9000 isnt electronic and wheels arnt either.
Imagine if Canon change their mount and all those EF/s lenses wouldnt fit anymore? their sales would fall through the floor.
Er......
http://en.wikipedia.org/wiki/Canon_FD_lens_mount
PostPosted: Sun Sep 23, 2012 10:48 pm
Also would a longer 11 speed shimano freehub body wrok on a 10speed hub body with flange spacings for 10 speed.The 11 speed hub body has different flange toi centre distances to accomadate the longer freehub body.
Campag even had more than one 8 speed free hub body spline pattern.
www.thecycleclinic.co.uk
PostPosted: Mon Sep 24, 2012 8:11 am
Er......
http://en.wikipedia.org/wiki/Canon_FD_lens_mount" onclick="window.open(this.href);return false;
there were/are adaptors to make a FD lens fit a EF mount :) as there are with the Nikon as well, and that is my last word on it :beerchug:
PostPosted: Mon Sep 24, 2012 10:36 am
My plan is to modify a 10sp cassette to work with 11 speed indexing.
Obviously I cannot modify the space betwen the 3 and 2 cog clusters, but I can change the space between the two clusters and then between all the other cogs.
The tiny difference in the two clusters will not be a problem.
PostPosted: Mon Sep 24, 2012 2:37 pm
does anyone know if the current 10 speed chain tool will work with 11 speed chains
Current Rides:
2010 SWorks SL3/DI2
PostPosted: Mon Sep 24, 2012 4:04 pm
Why not get an 11spd cassette and drop the 11 sprocket? None of us really need that anyway ;)
PostPosted: Mon Sep 24, 2012 4:19 pm
the indexing/spacing is different so you d stil need the sti's/chain/cassette - one the USA top spesh guys did that as he didnt have an 11sp wheel
bit pointless for the rest of us, surely?
PostPosted: Tue Sep 25, 2012 10:58 pm
I have tubular wheels because I live in Colorado and don't trust clinchers descending the mountains. I'd go ahead and get 9000, but it would be a waste to have to ditch all my 10spd shimano wheels, which are nice carbon tubulars. If I could put a 9000-compatible 10-speed cassette on my 7850 hubs then it would make a lot more sense for me. Besides, my biggest interest in 9000 is the improved performance not an extra gear...
___________________________________________________
"Organization is for the simple-minded, the Genius controls the chaos." - Jens
PostPosted: Tue Sep 25, 2012 11:34 pm
KLabs wrote:
borja wrote:
Hi!
I'm considering switching from Dura Ace 7900 to 9000.
I have some old wheelsets which are 10speed and cannot be upgraded to 11. (DA WH78xx 50mm carbon tubs for example )
My question is - will the 9000 work with 7900 10speed sprockets? As far as I get it the spacing between sprockets is the same, on 9000 they just added one more sprocket so the cassete is wider.
So, theoretically, the shifter should work if you limit the deraileur (and of course you'll have one click to much)
Any comments appreciated!
According to another thread I have been reading, the answer is 'yes' you can use a 10spd cassette with the 9000 RD and 9000 STI lever :-)
PostPosted: Wed Sep 26, 2012 7:29 am
Not if you want to use a 10 speed wheel?
PostPosted: Wed Sep 26, 2012 1:52 pm
Has anybody now tried a shimano 10speed cassette with an 11spd groepset?
If so, did you use a 10 or an 11 chain?
@Klasp, where is that other thread saying it would work?
I received an 11spd group of Shimano, but all my wheels are 10spd.
PostPosted: Wed Sep 26, 2012 7:05 pm
viewtopic.php?f=3&t=98373&start=285
PostPosted: Thu Sep 27, 2012 4:12 am
how quickly we forget that shimano went from 8, to 9 to 10 speed for what, about 20 years all while maintaining backwards compatibility. Forwards compatible even!
You couldn't put an 11 tooth cog on the oldest 8 speed hubs... and there was that oddball 10 speed only Dura Ace 7800 spline... but everything else worked fine. I have a 10 speed ultegra cassette on some 1996 Nuke Proof 8 speed hubs!
Personally, I would prefer that Shimano makes "the best" group they can -- even if it means some of my old wheels won't work with the new group. I'm still going to buy it.
Eric
'07 Cervelo R3, '10 Lapierre Xelius
PostPosted: Thu Sep 27, 2012 7:45 am
In the French magazine Le Cycle they were testing a pair of Mavic Cosmic SLE wheels.
They said that you use all existing Mavic wheels with the M10 body with 11spd dura-ace cassette.
PostPosted: Fri Sep 28, 2012 11:07 am
Just measured a 9000 cassette, the total height of the cassette is 39,6mm
So the cassette spacing should be 39,6mm - 1,6mm = 38mm / 10 = 3,8mm
Shimano 10-speed is 3,95, so a difference of 0,15mm per gear. Will not work very well.
But the difference between Campagnolo 11-speed (3,85mm) and Shimano 11-speed is just 0,05mm per gear, so that should work ok.
www.sykkelplaneten.no
Post new topic Reply to topic  [ 100 posts ]  Go to page Previous  1, 2, 3, 4, 5 ... 7  Next
Users browsing this forum: Bing [Bot], carbon337, dgran, Google [Bot], Google Adsense [Bot] and 78 guests
This topic is locked, you cannot edit posts or make further replies. Dura Ace 9000 compatibility
insightt47
Thu May 16, 2013 5:47 am
insightt47 View the latest post
There are no new unread posts for this topic. Dura Ace 9000 FD compatibility
TimmS
33
4331
Mon Mar 04, 2013 8:16 pm
Berg View the latest post
There are no new unread posts for this topic. DA 9000 rear derailleur compatibility
lannes
Wed Mar 06, 2013 4:58 am
Doolop View the latest post
There are no new unread posts for this topic. Bontrager Aura 5 - Shimano 9000 compatibility or Swap
drewb
Fri Oct 12, 2012 10:27 pm
drewb View the latest post
There are no new unread posts for this topic. Shimano DA 9000 11sp - any compatibility with Campag 11sp?
[ Go to page: 1, 2, 3, 4 ]
fivethirtyonepm
53
5788
Tue May 21, 2013 4:23 pm
WMW View the latest post
It is currently Fri May 24, 2013 9:34 pm
