Post new topic Reply to topic  [ 16 posts ]
Go to page 1, 2  Next
PostPosted: Mon Sep 17, 2012 11:12 pm
I have a 2012 Cdale Supersix with ultegra. looking for a replacement FD clamp that is light weight. I'm just starting my journey into this lightweight weenie stuff. I dont have a lot of expendable money so this is all going to take time and in steps. I already have some things on order but was looking into FD clamps and didn't know what would be a good choice. Is there a point of going to light that it takes away from the durability with some of these items?
KCNC
http://fairwheelbikes.com/kcnc-front-de ... -2943.html
I saw a couple other options that were upward of $80-$120 and I just cant allow myself to spend that much on a clamp.
what are some other options that are under $50?
PostPosted: Mon Sep 17, 2012 11:30 pm
Ratio
about 5g, doesn't look all that strong but mine hasn't moved in about 5,000km
I bought mine from Chain Reaction where it seems to be on special at the moment, about $30
http://www.chainreactioncycles.com/Models.aspx?ModelID=61287
PostPosted: Tue Sep 18, 2012 12:15 am
nice. I saw that one but was $50 when I pulled it up. thanks for heads up! the ratio looks to be about 10g lighter than the kcnc one I was looking at.
any other options out there?
PostPosted: Tue Sep 18, 2012 1:41 am
What's the stock clamp weigh? Looking at the cost/weight savings ratio...
Fear is healthy, panic can be deadly
PostPosted: Tue Sep 18, 2012 2:06 am
31g stock to 5g for the ratio clamp mentioned above
PostPosted: Tue Sep 18, 2012 3:01 am
The Parlee clamps are like 80-90 bucks I think, but can usually be picked up on Ebay for around 40-50.
PostPosted: Tue Sep 18, 2012 3:36 am
Second the parlee clamp. It's pretty rigid -- most of the lightweight clamps simply flex when you're shifting and you keep having problems with them. The Parlee has to be mounted just right but clamps tight, and also avoids marking up or crimping the seat tube like the metal clamps.
PostPosted: Tue Sep 18, 2012 5:06 am
I have the clamp by Ratio on my caad 9 and while shifting is still good, the clamp has dropped on me several times. I have now reassambled with carbon paste and a slightly higher torque value. seems to be keeping in place now.
    2011 Cannondale Flash F1
      2010 Cannondale Caad9
        2000 Cannondale Caad 4 aero
          1999 Cannondale Caad1
            ???? Concorde SS
PostPosted: Tue Sep 18, 2012 10:30 am
Administrator
I'll third the Parlee clamp. Plus it looks good! :wink:
PostPosted: Tue Sep 18, 2012 10:31 am
put a little bit of that sticky backed ..like fine sand paper skateboarders use on frame ..so its against the clamp ..combined with a bit of paste nr the bolt & right torque ..et voila !
tcr's rule !
stefanpearce@rocketmail.com
PostPosted: Tue Sep 18, 2012 5:58 pm
eXotic brand on ebay, part # 140814320690. 6 grams for a 34.9 clamp and $30.
PostPosted: Tue Sep 18, 2012 10:10 pm
I have a SMUD one I will sell - unused
http://smud-carbon.eu/fd_clamp.html
PostPosted: Tue Sep 18, 2012 10:31 pm
I guess I am a little confused after looking at my FD clamp. I'm looking at my FD and I see where the bolt tightens the clamp, but after looking at the "ratio" or kcnc or other brands I dont see where the front derailleur actually mounts to the clamp????
Do I need one like this?
PostPosted: Wed Sep 19, 2012 1:07 am
Yours is a clamp-on derailleur, the seat tube clamp is integrated with the FD. Used on bikes that do not have braze-on tabs for FD attachment.
If you have a braze-on FD (one without the clamp), you can buy a clamp adapter for it (2nd pic).
PostPosted: Wed Sep 19, 2012 6:27 am
Hey while we're on this topic, does anyone have a good suggestion for a 31.8 FD clamp I can put on my 34.9 seat tube?
Post new topic Reply to topic  [ 16 posts ]  Go to page 1, 2  Next
Users browsing this forum: bdzero1, BeeSeeBee, Bing [Bot], Exabot [Bot], Leroy424, tharmor and 53 guests
There are no new unread posts for this topic. Light weight daily semi-aero wheels for a light weight rider
dvincere
15
2609
Sun Jun 03, 2012 9:44 pm
numbers505 View the latest post
There are no new unread posts for this topic. 28.6 mm light seat post clamp options (under $30.)
LouisN
Sun Jan 06, 2013 11:19 pm
LouisN View the latest post
There are no new unread posts for this topic. HELP - FSA K Force light chainset stuck in Shimano BB71
chris217
9
511
Mon Dec 24, 2012 3:24 am
boolinwall View the latest post
There are no new unread posts for this topic. Light weight alu tubulars?
cerro
23
1519
Thu Sep 13, 2012 1:32 am
bluhorizan View the latest post
There are no new unread posts for this topic. Light weight brakes that really work!
[ Go to page: 1, 2, 3, 4, 5 ]
rockdude
71
4401
Sun May 12, 2013 3:43 am
pawnii View the latest post
It is currently Mon May 20, 2013 4:17 am
