Post new topic Reply to topic  [ 17 posts ]
Go to page 1, 2  Next
 Post subject: Ultegra Di2 New Firmware
PostPosted: Thu Sep 13, 2012 8:14 pm
I got the Ultegra Di2 system checker and after install, there was new firmware available for the shifters, battery mount and front derailleur. I upgraded them, but without a changelog, not sure whats changed. Sure would be nice if there was a changelog for the firmware.
PostPosted: Thu Sep 13, 2012 9:58 pm
Where did you get the new firmware from?
Scott Foil Di2 2012
Scott Scale 35 2010
PostPosted: Fri Sep 14, 2012 1:30 am
The checker works by connecting to the usb port of your pc. It requires you to install the shimano "e-tube" software to work. That software automatically looks for updated firmware for each device and then downloads and installs it. The software shows what version of firmware is in each of the components.
PostPosted: Fri Sep 14, 2012 1:45 am
So is your problem that you know what version of the firmware you have in each component now (after any updates were installed) but you don't know which versions you had before updating?
If you had been aware before updating of what you are now, could you have used/set the software in such a manner as to report the versions of firmware without updating?
PostPosted: Fri Sep 14, 2012 1:57 am
No. My problem is that there's no descriptive log of what has changed. When you update firmware in a Garmin for example, they tell you all the things that have been fixed/ changed in the new firmware version. In. The case of Di2, there's no file or text that describes what's changed.. I assume the updated firmware addresses some issues in the original firmware. What are those issues?
PostPosted: Fri Sep 14, 2012 2:13 am
You don't have a need to know. I am Shimano and I have spoken.
PostPosted: Fri Sep 14, 2012 2:21 am
:mrgreen:
I guess since this is weight weenies, and since firmware doesn't change the weights, who cares, right?
PostPosted: Fri Sep 14, 2012 5:13 am
goodboyr wrote:
:mrgreen:
But he who gets the most performance for the same weight, wins! :smartass:
:D
PostPosted: Fri Sep 14, 2012 6:22 am
Ok, thanks for the info.
Do you happen to know it the SM-PCE1 works/will work for the new Di2 9000 too?
EDIT: found the information myself already:
http://fairwheelbikes.com/cycling-blog/ ... a-ace.html
The last part of the article makes me want to buy a SM-PCE1 :)
Scott Foil Di2 2012
Scott Scale 35 2010
PostPosted: Fri Sep 14, 2012 3:41 pm
The SM-PCE1 PC Conector for Ultegra Di2 will also be used with all future E-Tube Di2 systems including the new Dura Ace 9070 Di2. It will also allow you to make some pretty cool midifications to the 9070 shifting.
PostPosted: Fri Sep 14, 2012 3:56 pm
Could you please describe these cool modifications it will allow you to make to 9070 shifting? Thanks.
PostPosted: Fri Sep 14, 2012 4:27 pm
It allows you to set the number of gears shifted on a long lever push. It's also theorized to allow 6770 to upgrade to 11-speed. If they'd confirm that, I'd get it at the start of next season, but it's purely conjecture at this point.
PostPosted: Fri Sep 14, 2012 4:34 pm
Well, I've heard that, but is that it, or is there other stuff that can "openly" be done using published information (as opposed to unauthorized/unsupported hacking)? Can you at least specify how long (and to what time resolution?) is long?
PostPosted: Fri Sep 14, 2012 5:15 pm
No, I have no idea how long the "long" press is - I haven't played with Di2 at all yet, and I've never read the definition of "long" in a review. There's also been talk that it's possible to repurpose each lever if you want to change which one shifts which derailleur which way, and I believe that's confirmed. Those are the only settings I'm aware of.
PostPosted: Fri Sep 14, 2012 6:05 pm
The present software on the ultegra di2 and system checker does not have the option to go to 11 speeds. Only customization is what each button does. And its a full customization, so you could make each button do whatever single shift you want.
Post new topic Reply to topic  [ 17 posts ]  Go to page 1, 2  Next
Users browsing this forum: Bing [Bot], Google [Bot], Google Adsense [Bot], Majestic-12 [Bot] and 37 guests
There are no new unread posts for this topic. updating Powertap G3 firmware...
neeb
Sat Jul 07, 2012 3:34 pm
neeb View the latest post
There are no new unread posts for this topic. looking for details on Campy's EPS firmware upgradability
Eric Marshall
Tue May 22, 2012 4:24 am
xuelan View the latest post
There are no new unread posts for this topic. Hacking Di2 firmware to do single-lever shifting
freeloader
7
1225
Fri Jan 04, 2013 6:20 pm
Squint View the latest post
There are no new unread posts for this topic. Shimano Ultegra 12-30 Cassette With Ultegra Di2?
SpeshK
Tue Feb 05, 2013 5:13 pm
SpeshK View the latest post
This topic is locked, you cannot edit posts or make further replies. Dura Ace Di2 from Ultegra Di2
DamoRider
Sun Jan 27, 2013 8:36 pm
DamoRider View the latest post
It is currently Sun May 19, 2013 5:14 am
