It is currently Wed Jan 24, 2018 11:10 am
Post new topic  Reply to topic  [ 179 posts ]  Go to page Previous 18 9 10 11 12
PostPosted: Wed Mar 05, 2014 4:50 pm
Ok i do not love them that much any longer as the plastic on my left pedal broke today :p
I do not know why or if it is a common problem. Just wrote to the company and will see what happens. Luckyly the part is not to complicated and i´ll make my own so i can use my bike. But hope to get some new parts from Ultralite later on.
:arrow: my 36XXg Stevens
:arrow: my Litespeed
PostPosted: Wed Mar 05, 2014 9:09 pm
Well, as a general rule, ultra light is not always ultra durable. All the more so for a weight-bearing part if the rider is heavy (for example, over 90 kg, as Fuchspk admits to be) and/or strong.
You want durable? Get Dura Ace.
PostPosted: Wed Mar 05, 2014 11:17 pm
Yeah that is for sure for some ultra light parts, but not all of them are bad and can hold as long as DA and somebody has to test this to see how far you can go. Otherwise we all would cycle around with DA and there would not be any weighweenie or so ;)
Of course i´m a bit heavy for the titanium pedals but the steel pedals from Ultralite use the same plastic part and they are ok for up to 300lbs - so there should not be that problem with this.
PostPosted: Tue Mar 11, 2014 12:57 am
So... the plastic part (that your cleat attaches to) rotates on a metal shaft... and the in-board piece (with the spring inside) rubs against your cleat... or doe sit rotate along with the cleat?
At any rate that plastic part will wear pretty quickly if you get any dirt in there.
formerly rruff...
PostPosted: Thu Mar 27, 2014 2:16 pm
I'd love to hear any more experiences people have had on these.
Fuchspk, Did Ultralight replace your broken piece and what did they say?
PostPosted: Mon Jun 30, 2014 5:45 pm
Fuchspk, i am looking into this pedal as well. Any updates from the company?
PostPosted: Mon Jun 30, 2014 6:14 pm
The slight performance gains from light weight parts that are cancelled out due to bushing drag don't make any sense to me. Part longevity is another topic.
PostPosted: Wed Sep 10, 2014 3:55 pm
Sorry for my late respons. No i never got an answer to my question about my broken pedal - which is kinda bad as it was still in the warranty time....
They now have these barrels on their shop and i would guess that some more people had the same problem like me?
Anyway i just ordered a pair of barrels and will see how long they will last.
PostPosted: Mon Sep 15, 2014 10:38 am
This is real bad image for the company without responding to customer issue.
PostPosted: Mon Sep 15, 2014 11:56 am
Yeah, from the looks of their website, me thinks these people are a 1-2 man operation and just aren't capable/prepared to handle running a company. No response to basic support issue?
Next, as Bridgeman above points out, bushing bearings??? Not good. There is never any longevity with bushing configurations on parts like pedals, that have massive pressure and high "cycles" (repitition) put on them. As pedals, crank bearings, wheel bearings etc...all do. It requires steel/ceramic.
There is a reason major industrial companies that understand manufacturing with components as such, don't use a bushing if they want it to last.
Lastly, I don't need some suspect pedal when I'm hitting a sprint and pushing high wattage. Maybe OK for a climber who can't go over 500w ever.
PostPosted: Mon Sep 15, 2014 2:45 pm
As a general rule, yes I agree.
Fortunately, it isn't always true.
That's what makes this forum great - we sift through the detritus and marginal products to highlight the exemplary ones.
As a result of the shared opinions here, my WW roadie has been solid - and I suspect that I'm not alone for those who spend the time to read the reviews and follow brands / products here.
5.7kg / 12.7lbs Addict SL w/PowerTap
9.3kg / 20.5lbs Scale 29 Pro ... woefully under-used
Retired: 5.9kg / 13lbs Addict R1 w/PowerTap ... lowest was 5.593kg / 12.33lbs
PostPosted: Mon Sep 15, 2014 3:20 pm
:roll:
Yet plain bearings are used in IC engines and all sorts of highly stressed equipment.
PostPosted: Mon Sep 15, 2014 8:34 pm
FWIW the turcite bushings on my AeroLite pedals spin far more freely than my Look Keo, Crankbrothers Eggbeater or Ultegra pedals. And they have lasted a very long time, doing a lot of climbing under a mashing heavy rider. And have a lot less play too.
Cheers
GJ
PostPosted: Tue Sep 16, 2014 6:47 am
Very often with either a pressurised feed of oil to cool and lubricate, or all but submerged in oil. Or both.
Might make your lightweight pedals a little less lightweight.
There are no new unread posts for this topic. Which cable system is the most weight weenie?
BigPoser
Sat Feb 11, 2017 3:19 am
danbjpa View the latest post
There are no new unread posts for this topic. focus weight weenie e-bike
spartan
Thu Jun 29, 2017 11:37 am
Marin View the latest post
There are no new unread posts for this topic. Weight weenie frame choice
[ Go to page: 1 2 3 4 5 ]
964Cup
64
8596
Wed Jul 19, 2017 2:31 pm
wheelsONfire View the latest post
There are no new unread posts for this topic. Trek domane/emonda seat mast cap - weight weenie clamp
alcatraz
7
881
Sun Dec 24, 2017 1:24 pm
alcatraz View the latest post
There are no new unread posts for this topic. Biggest water bottles on the market?
Shrike
Thu Mar 16, 2017 12:07 pm
Rush View the latest post
Users browsing this forum: BdaGhisallo, benzebub, Google Adsense [Bot], karmaz, Lewn777 and 25 guests
