Post new topic Reply to topic  [ 2 posts ]
PostPosted: Tue Sep 11, 2012 8:55 pm
Hi
I would like to know how best to join a section of Shimano to Nokon gear casing.
I have run my Shimano TT gear cables through the bar extensions. They take a steep dive down from their exit of the bars to the barrel adjusters on the downtube and the SIS casing doesn't handle the curve very well unless I use a long length.
I have some old Nokon housing and internal sleeving which would probable manage the radius better. I would like to run a short section of Nokon from the SIS at its exit of the bars to the barrel adjusters.
How should I make the Nokon/SIS connection?
SIS is 4mm and Nokon is 5mm.
I see Jagwire do a double ended connector but I can only find 4/4mm or 5/5mm combination.
Any ideas?
Many thanks.
Alan
PostPosted: Wed Sep 12, 2012 6:40 am
if you find a shimano step-down housing end cap it has a 4mm i.d. and 5mm o.d. then you can use a 5mm junction. you would have to cut or grind the "nose" off. these came with sti down tube cable stops and bb cable guides, so a lot of shops have piles of these sitting in some dusty box.
jagwire also makes 4mm open black brass end caps that happen to be extremely undersized on the outside, at 5mm.
Users browsing this forum: BikeNerd2453, Bing [Bot], Google [Bot], robertg and 47 guests
There are no new unread posts for this topic. Nokon cable refurbish
WW08012010
Sun Oct 28, 2012 4:05 pm
crohnsy View the latest post
There are no new unread posts for this topic. Shimano STi gear cable query?
dieselgeezer
Fri Jan 18, 2013 8:26 pm
dieselgeezer View the latest post
There are no new unread posts for this topic. HELP: Dogma 60.1 - Internal Gear Cable Route Blocked!!!
dotcycling
7
1149
Tue Oct 30, 2012 3:27 pm
bontie View the latest post
There are no new unread posts for this topic. Anyone create their own Di2 connectors?
bartturner
Fri Apr 26, 2013 11:58 pm
goodboyr View the latest post
There are no new unread posts for this topic. DIY Di2 looking for my own connectors to replace Shimano. An
bartturner
Sat Feb 09, 2013 9:50 pm
bonafide View the latest post
It is currently Fri May 24, 2013 2:18 am
