It is currently Sat Apr 29, 2017 8:48 pm
Post new topic  Reply to topic  [ 5 posts ]
PostPosted: Tue Sep 11, 2012 2:10 am
We are talking Time Impact carbon with titanium axles.
I am guessing I might have broken a pedal axle, but how do you know if you have? Does the pedal fall apart at some point? I am about to dismantle the crankset to rule out any problems there.
If I do a hand/wobble check off the bike everything seems normal, but riding over a road defect and I get a 'click' as if something is wrong. It's as if my cleat clicks into place, but my cleats and shoes are fine.
Thanks in advance for any help.
PostPosted: Tue Sep 11, 2012 2:44 am
if the pedal axle was broken, the pedal would be in your hand, not on the crank.
the pedal can develop play between itself and its bearings. the bearings can also be allowed to shift slightly within the body. i would also check the hinge pin, springs, all the little screws holding the top decks and the wire piece near the back...
and you say your cleats are fine, but did you check the screws holding the brass part to the plastic part?
PostPosted: Tue Sep 11, 2012 6:19 am
Do you mean RXS or Impact? The Impact didn't come in carbon...
"It's not the destination...it's the ride!"
PostPosted: Tue Sep 11, 2012 3:35 pm
Sorry ... iClic Titan/Carbon version 1.
PostPosted: Tue Sep 11, 2012 6:57 pm
+1
How do you know it is the pedal or cleat interface that is actually creaking?
Have you tried another set of pedals to see if the the sound still appears. It is possible that creak is coming from BB or other area as well.
EM3
______________
My 2013 Cervelo R5
There are no new unread posts for this topic. Are my hairline cracked or broken carbon fibre handlebars broken or useable? Can they be easily repaired?
ponyopo
10
1617
Wed Nov 02, 2016 3:52 pm
AJS914 View the latest post
There are no new unread posts for this topic. How will the introduction of Hydraulic Disc Brakes impact value of non-disc brake bikes within the next 5 years?
JunkyCollegeBiker18
32
3374
Thu Dec 01, 2016 10:39 pm
There are no new unread posts for this topic. Campagnolo Ultra Torque Crank/Axle Tool
Devon
26
1267
Thu Jul 21, 2016 12:13 am
Calnago View the latest post
There are no new unread posts for this topic. Broken 10spd Campy Record FD Clamp?
brianwchan
Mon Oct 10, 2016 5:37 pm
brianwchan View the latest post
There are no new unread posts for this topic. Ultegra 6800 Reach Lever Screw broken
probertsqbe
Tue Feb 14, 2017 12:09 pm
probertsqbe View the latest post
Users browsing this forum: corky, Google Adsense [Bot], roadieboy and 51 guests
