Post new topic Reply to topic  [ 90 posts ]
Go to page Previous  1, 2, 3, 4, 5, 6  Next
PostPosted: Tue Dec 11, 2012 1:07 am
I had to order a headset for my Evo Ult. and it came with the new expander.
Therefore if you order KP203 from Cannondale it should include the new expander. My scale says 16g which is a huge improvement over the 50g old one.
PostPosted: Tue Dec 11, 2012 2:50 am
Good to know. Thanks!
PostPosted: Tue Dec 11, 2012 4:03 am
Anyone know if the expander is available separately yet?
Fear is healthy, panic can be deadly
PostPosted: Wed Dec 19, 2012 7:04 pm
I'll answer my own question: "Spring" according to the LBS' Cannondale rep...
PostPosted: Thu Jan 03, 2013 11:48 am
This may be a daft question but can you run the new sisl 2 with the rotor bsa bb30 bb adaptor. I have a bsa threaded frame and I much prefer the sisl 2 to the rotor 3d +
Owl
PostPosted: Thu Jan 03, 2013 4:20 pm
Using the rotor BSA adaptor adds ~10mm per side so you would be moving the chainrings further away from the frame thus altering/pushing out the chairline.
PostPosted: Thu Jan 03, 2013 5:14 pm
... And you'd need a longer spindle to accommodate it. It will not work.
PostPosted: Thu Jan 03, 2013 5:47 pm
Thanks guys, not keen on rotor so thm m3 seems like the most. Sensible option for a stiff light compact crank
Owl
PostPosted: Thu Jan 03, 2013 7:44 pm
Even with the new SiSL2 spindle which is 109 mm versus 104 mm, since Hollowgram was designed around a 68 mm bottom bracket shell width, adding 10 mm on the drive side for the BSA cups, simply pushes a hollowgram crankset/chainrings 10 mm further out from the expected chainline.
PostPosted: Thu Jan 03, 2013 8:05 pm
Don't know about the SISL crank bolt weights but I have just got some replacement SI arms from Cannondale. Was about to use the original SI crank bolts until I bought a pair of the SISL2 bolts off the bay to match the black replacement arms. You can feel the weight difference in the bolts intantly when holding them plus the new bolts have a wider bolt hole and are hollow.
PostPosted: Sat Jan 05, 2013 9:56 am
@shoemakerpom2010
According to Dr Cannondale the new bolts weigh 13g vs 14g for the old ones. Any chance you could weigh them?
I wanted to order black bolts anyway and will probably get the sisl2's.
Btw they are charging €249 for those butt ugly one piece chainrings. I think I'll go with Praxis works, thanks. :P
Edit: Removed quote
    2011 Cannondale Flash F1
      2010 Cannondale Caad9
        2000 Cannondale Caad 4 aero
          1999 Cannondale Caad1
            ???? Concorde SS
PostPosted: Sun Jan 06, 2013 1:29 pm
He has older, original bolts from the first SI cranks. That's why they aren't hollow and use a smaller, 8mm Allen wrench. And that's why the weight difference is greater.
PostPosted: Tue Jan 08, 2013 9:43 pm
Did you have some Hollowgrams that failed?
PostPosted: Tue Jan 15, 2013 4:40 am
Have you installed the HS yet?
This new expander looks like it will provide less support for the clamping forces of the stem versus the previous version. Does this represent new thinking on Cannondale's part regarding how much support the steerer actually needs?
2012 Cannondale Supersix Evo 2 /// 2000 Ritchey Swiss Cross
PostPosted: Tue Jan 15, 2013 5:02 am
Does not look like less support from what I've seen - the difference seems to be the scalloping of the "top cap" vs the current solid design. Looks like an old school plastic bar end plug now with "fins".
Since the clamping forces will be directly against the new "fins" there should be no loss in strength. Similar to the way a cardboard box is extremely strong on one axis but not the other.
Looks smart.
Post new topic Reply to topic  [ 90 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6  Next
Users browsing this forum: Bing [Bot], Google Adsense [Bot], Kam0916, stax and 39 guests
There are no new unread posts for this topic. Help please - FSA compression plug
headwind816
Sun Mar 24, 2013 10:08 pm
DaveS View the latest post
There are no new unread posts for this topic. Enve Compression Plug + Chris King Top Cap?
iamalex
Sun Mar 17, 2013 8:18 am
iamalex View the latest post
There are no new unread posts for this topic. Cannondale Hollogram SiSL2 and SpiderRing
Lou3000
Tue Jun 19, 2012 5:56 pm
Lou3000 View the latest post
This topic is locked, you cannot edit posts or make further replies. SiSL2 + SRM
kentbrockman
Sun Dec 02, 2012 9:01 am
CAFERACER View the latest post
There are no new unread posts for this topic. how many spacers going from SiSl to SiSL2 axle
styrrell
Sun May 19, 2013 4:16 pm
styrrell View the latest post
It is currently Sun May 26, 2013 5:13 am
