Post new topic Reply to topic  [ 90 posts ]
Go to page Previous  1, 2, 3, 4, 5, 6  Next
PostPosted: Tue Oct 02, 2012 6:23 am
Just heard back from Cannondale Experts on the new plugs - they tried to order but were not given a shipping date. Their guess is middle of the month.
I'm keeping an eye out...
Fear is healthy, panic can be deadly
PostPosted: Sat Oct 06, 2012 10:35 am
From some guy on RBR forums:
Quote:
First. The new 109mm set up will accommodate SRM without any modification.
Second. The SISL2 cranks do not require the new spindle. You should be able to mix and match the new arms with the old spindle.
Lastly, still not sure about clearance of the spidering on the old spindle.
Here's a pic of the non drive side of my spindle, it is indeed drilled.
Seeing a photo seals the deal for me. Just gotta get the new BB set then!
CAAD10 Di2
PostPosted: Sun Oct 07, 2012 3:54 am
skinnywellfed wrote:
ms6073;
So for your 170mm SiSL2 arms you just purchased, does it appear that the curvature of the arms is NOT symmetrical when compared to one another?
i was wondering about this and took a look at some sisl2 and standard sisl arm sets.
first, the new arms are symmetric. the offset seems more distinct, less gradual.
second, the old arms are Asymmetric. left arm is more offset.
the new arms have the same offset as the old right arm.
PostPosted: Mon Oct 08, 2012 3:45 am
So now the obvious question is Q-factor. What does it measure out as on the SiSL2 crankset.
Is it 146 with the new spindle? If it is now 146 then using the old spindle would still produce the prior 141 and also show they really are interchangable since arms to chainstays clearance would not be much different.
PostPosted: Tue Oct 09, 2012 4:40 am
Radom question -
Will the Sworks lockring tool work on the SI lockring?
PostPosted: Tue Oct 09, 2012 6:24 am
Yes, exact same thing.
PostPosted: Tue Oct 09, 2012 10:42 am
The old si sl hollowgram cranks with old spindle have a 141mm q factor, my guess is this new one will be more... can anyone confirm?
PostPosted: Sun Oct 21, 2012 5:18 am
Im still waiting for the spindle KP248 to become available... My SRM is running flawlessly though with my modded shoulder lathed off the 104mm on the EVO though.. I would like to get that NDS crank displaced a hair further out...
PostPosted: Sun Oct 21, 2012 11:54 am
Do you have calipers to measure the offset with si sl arms and your modified spindle?
PostPosted: Sun Oct 21, 2012 3:06 pm
Sorry.. don't have.. really in the end the whole thing is only shifted about 1-1.5mm more to DS to clear the SRM...
The current setup is this from Drive to Non drive side:
SRM - SRAM 2.5mm spacer - 2 Cannondale Black Pastic Spacers - SRM KP197 bearing kit - 1 Black Plastic Spacer, Wavy Washer, NDS Crank
Running flawless and turns smoother than it did on my SuperSix....
PostPosted: Wed Nov 14, 2012 7:12 pm
I installed my SRM with sisl2 exactly as discribe here above, but SRM spider instead the SpideRing.
http://media.cannondale.com/media/uploads/blog/files/SISL2_Road_Crankset_Instr_1012.pdf
[url]http://www.weightweenies.com.br[/url]
PostPosted: Thu Nov 15, 2012 12:29 am
Any news on the new compression plug availability? I assume it works much better than some of the alternatives. Looks well designed.
PostPosted: Thu Nov 15, 2012 8:06 pm
So does that mean you were able to obtain an as yet not available in the USA, 109mm SISL2 spindle?
PostPosted: Fri Nov 16, 2012 2:21 am
Same here, any news on availability? I went into my LBS and they were still waiting for Cannondale to reply back with an update on availability.
PostPosted: Fri Nov 16, 2012 3:32 am
I just read the instructions that Vallinotti so kindly posted.
Flowing Loctite 242 into the spline area is weird. I've always used 609 there.
And what the heck is an asymmetric 73mm shell? (mountain bike 73mm shells are symmetric) And what's it doing on a road crank instruction sheet?
Post new topic Reply to topic  [ 90 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6  Next
Users browsing this forum: AndrewL, Bing [Bot], CBJ, dkapp, stax and 42 guests
There are no new unread posts for this topic. Help please - FSA compression plug
headwind816
Sun Mar 24, 2013 10:08 pm
DaveS View the latest post
There are no new unread posts for this topic. Enve Compression Plug + Chris King Top Cap?
iamalex
Sun Mar 17, 2013 8:18 am
iamalex View the latest post
There are no new unread posts for this topic. Cannondale Hollogram SiSL2 and SpiderRing
Lou3000
Tue Jun 19, 2012 5:56 pm
Lou3000 View the latest post
This topic is locked, you cannot edit posts or make further replies. SiSL2 + SRM
kentbrockman
Sun Dec 02, 2012 9:01 am
CAFERACER View the latest post
There are no new unread posts for this topic. how many spacers going from SiSl to SiSL2 axle
styrrell
Sun May 19, 2013 4:16 pm
styrrell View the latest post
It is currently Mon May 20, 2013 2:21 am
