Post new topic Reply to topic  [ 3 posts ]
PostPosted: Sat Sep 08, 2012 9:45 pm
I recently moved from a Selle Italia SL XC Flow to a SLR Superflow 145. My LBS setup the saddle height, and since the nose of the SL is longer (7mm longer, according to Selle Italia), we attempted to proactively compensate for this also.
However, since I've been riding, I feel slightly out of position. Hand pressure is slightly more, which for me typically means I'm slightly too far forward or slightly too high. Everything else on the bike feels great.
So, I had two theories:
1. I could just move the saddle back 1-2 mm and see how it feels. And continue to adjust accordingly.
2. I've also wondered if the difference in padding firmness could be part of the problem. The SLR is much harder, and I've wondered if I'm sitting slightly higher, due to less padding compression? In this case, I'd move the seat down 1-2 mm.
Any insights? Is there any reason to try one first, over the other? Moving the saddle down is certainly easier.
Scott
PostPosted: Sun Sep 09, 2012 4:16 am
Saddles definitely differ in length, distance to the "sweet spot" and sag. The sag differential affects the angle and seeat height also.
The only remedy is very careful measurements, or go by feel. I usually try to measure things as best I can, but then feel free to make final minor adjustments by feel. My legs are pretty sensitve to small changes in height, and my arms tell me if my balance is off.
PostPosted: Mon Sep 10, 2012 10:52 pm
Thank you. I may make a minor adjust to height and/or angle prior to my next ride.
I've had to make minor height adjustments in the past due to chamois changes, to this makes sense.
Scott
Users browsing this forum: Bing [Bot], cambrook, elfuinha, Google [Bot], Google Adsense [Bot], uberruby and 65 guests
There are no new unread posts for this topic. To install or not to install: Fenders on winter/commuter
LouisN
28
967
Tue Mar 05, 2013 9:19 pm
motorthings View the latest post
There are no new unread posts for this topic. PF30 install?
audiojan
Tue Oct 16, 2012 5:10 am
elviento View the latest post
There are no new unread posts for this topic. THM Clavicula Install
RudyMontana
Sat Dec 15, 2012 7:29 am
Geoff View the latest post
This topic is locked, you cannot edit posts or make further replies. cannondale si sl crank install
logy
Sat Mar 30, 2013 11:55 pm
There are no new unread posts for this topic. Zipp Vukasprint install
jezza995
25
2465
Tue Aug 21, 2012 12:23 am
refthimos View the latest post
It is currently Sun May 19, 2013 3:37 pm
