advice needed on best UCI legal TT bars for Cervelo P4
by williamsf1
As the title suggests!!!
seems to be soooooo many choices, and it is very hard to find out the best???
I want to fully integrate the Di2 into it also!!!
have the frame/fork and internal di2 to fit.... just looking at bars!
by CarlosFerreiro
USE R1 would be up there, but expensive. ... 012-35176/
by Epic-o
3T Aduro?
by williamsf1
well both those you cant buy.. so NEXT ;)
3t aura is di2 compatible for something more budget
Pro Missile Evo, is expensive as hell but looks aero, works with di2 and has good range of adjustability
Felt's UCI legal basebar is UCI compatible and looks pretty sleek(but obviously then you're clashing brands): ... roBar.aspx" onclick=";return false;
by mrlobber
I'd also vote for Pro Missile Evo. They're indeed expensive, but actually not that far (or even cheaper) than some top offerings from other competitors (like 3T Ventus, for instance, which isn't UCI legal, though).
by williamsf1
yeah I am leaning towards brezza II or the PRO missile....
I want to be able to hide everything!!!
will be running one of these new brakes that TRIRIG have come up with on the front, so this should be an aero machine!!!
basics :
rotor 3D+ cranks with P2M and Q rings
enve 6.7 front wheel
zipp 900 disc" onclick=";return false; front brake
P4 is a 51cm and will be getting nuded up, with some matte clear and gloss clear for logos only "CERVELO" and that is it....
saddle not sure yet, but might just stick with the specialized romin evo
by eigner
Best bars I ever owned: Pro Missile Evo
Current: Colnago CX Zero Di2 Disc, Cannondale F29 carbon3
Previous: Scott Plasma 3 premium, Parlee Z3SL, Parlee Z4, Argon18 E112, TREK TTX7.0, S-Works Transition, Pinarello F4:13
by thisisatest
vuka bull base bar and vuka clip
