Post new topic Reply to topic  [ 16 posts ]
Go to page 1, 2  Next
PostPosted: Thu Sep 06, 2012 7:46 pm
Hi,
I have a UD carbon bike with full Dura-ace 7800 on it. I would like to change the crank to something compact with a 12-23 cassette.
For now, my first choice is the Fulcrum RS which would fit my bike just right and I think it looks really good.
While looking for info, with the forum search, I found people saying (to others) to buy the red crank with after market ring (like Stronglight CT2 5-Arm/110mm Road Chainring - 2011).
Basicaly, I would like some compact UD carbon crank that don't cost more than 400$ and light (well lighter than my 7800) and that look good.
What would you guys do if you were me ?
Is there any other option that I didn't see ?
and if you tell me to go with some aftermarket ring, is it possible to buy only the crank arms ?
Thank you guys.
PostPosted: Thu Sep 06, 2012 8:01 pm
Some of the fsa cranks are ud carbon and chainring choices are infinitely available. Also try SRAM; force and red both have ud carbon cranks, and they will be compatible with your shimano group.
Forget campag; although the high end ones are ud carbon, no amount of fiddling will get them to work correctly with shimano indexing.
Make well sure that the manufacturer states the crank is compatible with your group.
While the big brands may be the obvious choice, some of them make cranks under the name of complete bike manufacturers. I.e. zipp for cannondale, fsa for bianchi etc.
Definately take a look at used items on eBay, but do yourself a favour and don't fall for £100 fsa copies from Taiwan. Best of luck!
PostPosted: Thu Sep 06, 2012 8:04 pm
You may not be able to find crank arms on their own unless it is a second-hand item, the manufacturer will want you to buy their chainrings as well.
The upside is that you get the exact choice of chainring hat is right for you. I would recommend praxis chainrings if you have the coins to spare.
PostPosted: Thu Sep 06, 2012 8:33 pm
If Praxis are out of youre budget TA do rings for all BCD and in all teeth counts (praxis is limited), they are also light and hard wearing and look good.
As for cranks FSA Sl-K or K-force light kick the boxes for me, maybe for you. Plenty about second hand as well.
www.thecycleclinic.co.uk
PostPosted: Thu Sep 06, 2012 10:58 pm
"Forget campag; although the high end ones are ud carbon, no amount of fiddling will get them to work correctly with shimano indexing."
Maybe I misunderstand, but I use a compact Campy 11-spd SR UT crank w/ Shimano DA-7900 derailleurs and shifters (KMC chain & various cassettes: DA, KCNC, Omniracer/Token) and it shifts fine. Before I switched out the DA-7900 crank for the Campy in order to cut 100+ grams and improve looks (IMO), I queried this forum if it would work and everyone said it would w/no problem, which has proven the case. I suspect you can get them in like-new/used condition in your price range, too. Not sure how it would work w/DA-7800, though...
Wilier Cento Uno, 13.25 lbs / 6.01 kilograms
http://weightweenies.starbike.com/forum/viewtopic.php?f=10&t=95887
PostPosted: Fri Sep 07, 2012 12:32 am
I don't really wanna buy used.
So, a red crank (previous or new model?) Would be a good option? If I can, install some after market ring.
Would there be other option?
What about the fulcrum rs?
I don't wan't too go with pure campy 11s though.
PostPosted: Fri Sep 07, 2012 12:40 am
About the fsa crank, I hear too many horror story about them. I don't wan't any creaks or loosening :)
PostPosted: Fri Sep 07, 2012 12:58 am
Hi!
Don;t buy FSA cranks, they are crap.
Fulcrum is fine, and so too is Campagnolo - they are identical except for graphics. There is no problem using a Campy crank with shimano drivetrain, other than aesthetic.
There are about 5 Campy options under $400, and one Fulcrum one around there.
PostPosted: Fri Sep 07, 2012 1:09 am
How about the K force? See a lot of those in the peloton......
PostPosted: Fri Sep 07, 2012 1:37 am
Well the k-force are very cheap on chain reaction these days. But are they really good?
There are the fulcrum r and rs that are in my price range. The old red too and if you really push me into it, the new red are in my range too.
PostPosted: Fri Sep 07, 2012 1:39 am
This could happen to you if you buy FSA cranks:
:D
My Bikes
My Photoblog
PostPosted: Fri Sep 07, 2012 2:18 am
Outch!!!
Forget fsa ;)
PostPosted: Fri Sep 07, 2012 3:14 am
viewtopic.php?f=3&t=103730
^ have a look at come of the comments on that post, there are some extremely good review coming about of the new red crank, and if you mate it with something like praxis rings you could get it to be lighter than a LOT of the more standard cranks out there. Even if you don't you can get the crankset for about 400 and could upgrade the rings later? This is what I'm going to do for sure.
PostPosted: Fri Sep 07, 2012 12:34 pm
Snicks wrote:
http://weightweenies.starbike.com/forum/viewtopic.php?f=3&t=103730" onclick="window.open(this.href);return false;
So, right now, my best choice would be to get a 2012 red crank and update the ring to stronglight or praxis (later).
For the look, the new red would be nice, here is a pic of my bike:
would there be any other crank I am forgetting ?
Also, excuse my ignorance, but I am pretty new in the bike world, but, to replace my 7800 crank and bb, the red crank I have to buy is the GXP model right ? and which bb should I buy ?
PostPosted: Fri Sep 07, 2012 7:14 pm
Red runs on a GXP system so you'd need a GXP BB. Sram do them. Hope and CK do converters so you can use their BBs.
Post new topic Reply to topic  [ 16 posts ]  Go to page 1, 2  Next
Users browsing this forum: Bing [Bot], CarlosFerreiro, darnellrm, Google Adsense [Bot], HakeemT and 61 guests
There are no new unread posts for this topic. 160 Crank?
wiRIDEfast
15
592
Sat Dec 29, 2012 12:20 am
54x11 View the latest post
This topic is locked, you cannot edit posts or make further replies. Attachment(s) Ciamillo Crank V2
[ Go to page: 1 ... 6, 7, 8 ]
elfuinha
111
6869
Thu Dec 27, 2012 3:07 am
Tinea Pedis View the latest post
There are no new unread posts for this topic. red chainrings on FSA crank
digiadaamore
Sat Jan 05, 2013 12:59 am
digiadaamore View the latest post
There are no new unread posts for this topic. What chainrings / crank are these
jcumpstay
10
437
Fri Apr 05, 2013 3:28 pm
superb View the latest post
There are no new unread posts for this topic. Sram red crank puller
ninjanoir78
Sat May 25, 2013 8:42 pm
ninjanoir78 View the latest post
It is currently Wed Jun 19, 2013 12:00 pm
