Post new topic Reply to topic  [ 4 posts ]
PostPosted: Thu Sep 06, 2012 1:17 pm
Can a DA BR-7900 rear caliper be mounted on the front, or will things blow to pieces? Any problem apart from needing a different length mounting bolt? Thanks.
(Brake shoes will have to be swapped for correct direction, obviously)
Bikes: Raceur, Beateur
PostPosted: Thu Sep 06, 2012 8:08 pm
It should work in theory, if you can find a longer bolt for the front fork. But make sure you can find one before taking anything to bits. I think the only thing making the front and rear caliper different is the length of the bolt. Best of luck!
PostPosted: Fri Sep 07, 2012 4:30 am
On three frames I tried this and the thickness of the front of the fork crown was sufficient that there wasn't enough thread exposed behind it to screw a mounting bolt onto it. Even when I milled a nut down to the right length so it would fit snugly, it simply didn't have enough threads to hold onto. You may have different results with a different fork, but this was the same problem on one steel fork and two carbon ones.
PostPosted: Sat Sep 08, 2012 4:53 am
Check the shimano tech docs, but I'm pretty sure they would be identical apart from the long bolt and associated washers. And brake pad direction, switch them around!
Users browsing this forum: Bing [Bot], Exabot [Bot], Google [Bot], simnorm and 55 guests
There are no new unread posts for this topic. Attachment(s) Convert a shimano front brake caliper to a rear?
dmoneysworks
Mon Feb 18, 2013 1:18 am
ms6073 View the latest post
There are no new unread posts for this topic. 7900 Front caliper pivot bolt damaged. Replacement options?
racermech
Tue Sep 18, 2012 1:18 pm
oysters View the latest post
There are no new unread posts for this topic. 303 rear 404 front
project3
9
1122
Thu Jan 24, 2013 4:55 am
prebsy View the latest post
There are no new unread posts for this topic. Different hubs front and rear?
RMcC
7
416
Wed Jan 16, 2013 3:58 am
jbf View the latest post
There are no new unread posts for this topic. Front/rear brake choice...
mdeth1313
Fri Nov 23, 2012 8:48 pm
mdeth1313 View the latest post
It is currently Thu Jun 20, 2013 5:27 am
