Post new topic Reply to topic  [ 12 posts ]
PostPosted: Wed Sep 05, 2012 9:06 pm
The new 2012 Sram red front derailleur only has one mounting hole, unlike the old models which had two. Because of this, I can't get it low enough on my Cervelo S5 to be able to work with the chainring i have on there now (45t). Is there such a thing as an extender or adapter for this reason? I can barely get away with using a rival der. on the lowest setting.
PostPosted: Wed Sep 05, 2012 9:42 pm
Never seen one but surely a machine shop could knock on up quickly an d cheaply.
www.thecycleclinic.co.uk
PostPosted: Thu Sep 06, 2012 3:56 am
gotta ask- cervelo s5 with a 45t? junior?
if i was going to go to a machine shop to have an extender made, i would just ask them to make a revised front derailleur mount altogether. the one on the s5 bolts on.
PostPosted: Thu Sep 06, 2012 3:58 pm
Knock the existing bracket off with a lump hammer, and fit a clamp-on front mech.
What monkeys made your frame? Contact them and explain to them that some of us who ride bikes are not pro's, live in mountainous areas, or are juniors and have to, by default, use a small outer chainring.
PostPosted: Thu Sep 06, 2012 5:18 pm
Kidding... Right?
Just in case youre not, the mount is bolted on, hammer not needed. S5 seat tube is about as non-round as it gets too.
PostPosted: Thu Sep 06, 2012 6:22 pm
Yes, junior.
I called both the shop and Cervelo themselves, no such thing. Clamp-on is not an option for this frame. I might be able to get away with it if my FD had two mounting holes, but of course Sram with their new Red decided to put only one. :noidea:
PostPosted: Thu Sep 06, 2012 6:38 pm
Just run the old force and call it a day then.
Cervélo S2 2012 Red
Great minds think alike... sadly, so do the mediocre ones.
PostPosted: Thu Sep 06, 2012 8:51 pm
Yea, use an old red steel, or a force FD. I've heard good things about the new Yaw type Red FD, but my '10 or '11 Force FD shifts absolutely perfectly with my compact, couldn't be happier. Add a chain catcher if you want (I did), and you have a FD that is about the same as the new REd in function.
PostPosted: Thu Sep 06, 2012 9:19 pm
I'd get a metal shop to make you a new mount for the front derailleur, the bolt on area can then extend further down the frame for your smaller chainring. Personally, I wouldn't take any chances with your expensive SRAM fd. Alternatively, you may be able to buy a new mounting plate online.
PostPosted: Thu Sep 06, 2012 9:47 pm
http://www.moruyabicycles.com.au/conten ... lleur.html
This may be helpful.
PostPosted: Thu Sep 06, 2012 10:28 pm
I'm reading through all these suggestions to fashion a braze on hanger, but using an old Force or Red steel FD is going to be the most inexpensive and quickest way to deal with your FD. At the junior level the weight savings are negligible unless the kid is a couple seconds off from hitting the podium.
Cervélo S2 2012 Red
PostPosted: Thu Sep 06, 2012 10:44 pm
It's more of the fact that I already bought the FD not knowing i'd have this problem :?
To be honest even with the older sram FD it still is a lot higher than it should be, but at least it isnt rubbing against the bottom of the cage...
Users browsing this forum: Bing [Bot], mvacolnago, nigel379, shimmeD and 46 guests
There are no new unread posts for this topic. SRAM Red steel cage braze on FD + Q-Rings = poor shifting
Getter
Sat Dec 15, 2012 8:56 am
bura View the latest post
There are no new unread posts for this topic. Best adapter BB30 for Campy UT
fifarafa
32
1132
Wed May 15, 2013 12:49 pm
bikerjulio View the latest post
There are no new unread posts for this topic. Cassette adapter kits
alexh
7
275
Sun Jun 09, 2013 4:18 pm
alexh View the latest post
There are no new unread posts for this topic. SRM 7900 + Wheel Mfg PF30 adapter
ipenguinking
Wed Sep 05, 2012 3:19 pm
TurboKoo View the latest post
There are no new unread posts for this topic. Removing PF30 adapter, need the wisdom of WW!
audiojan
Sun Apr 14, 2013 6:22 pm
audiojan View the latest post
It is currently Tue Jun 18, 2013 7:33 am
