Post new topic Reply to topic  [ 9 posts ]
 Post subject: Stem creaks
PostPosted: Tue Sep 04, 2012 9:55 pm
Anyone know why a Tune stem would need frequent degreasing to stop it being noisy? Ti bolts must be greased regularly to sop the annoying creaks.
 Post subject: Re: Stem creaks
PostPosted: Thu Sep 06, 2012 9:36 pm
Sure it's your stem? A mate of mine had what you describe, but eventually found out it was headset bearings. Every time he would lean the bike from side to side applying pressure there would be a clicking / crunching noise. Eventually his headset completely seized up. Just letting you know incase you want to get it checked out.
PostPosted: Fri Sep 07, 2012 8:03 pm
Havinggreased the stem bolts again creak has gone but this is not ideal
PostPosted: Fri Sep 07, 2012 8:31 pm
Seems strange that you would need to continually grease the bolts.
Do you ride in the rain?
Did you torque the bolts to spec?
Do you use waterproof grease?
PostPosted: Sat Sep 08, 2012 6:40 am
Yes to all the above but only occasionally ride in the rain.
PostPosted: Sat Sep 08, 2012 5:28 pm
Make sure you have a good front wheel quick release and that it is snug. They can often be the source of front end creaking and few think to look there. I know I spent the better part of three months checking and changing components and finding that a 1/4 turn snugger on the qr solved all my problems!!!
PostPosted: Sun Sep 09, 2012 2:47 pm
Then it can't possibly be the stem unless it's cracked. Think about it.
PostPosted: Sun Sep 09, 2012 3:11 pm
The bolts may not be tight enough. Or they might be too tight. If you have used a torque wrench each time to tighten up but the problem recurs, dispense with it for this job.
I don't use plain assembly grease with ti bolts, or for that matter any type of bolt, instead preferring an anti-seize assembly lube from Finish Line.
If the forks have a glued-on steerer, ie. not a monocoque carbon fork, that could be your problem. Carbon blades glued to an alloy steerer can make a lot of creaking sounds.
PostPosted: Sun Sep 09, 2012 3:28 pm
Other possibilities can be:
1. Handle bars - clean them up -check for cracks possibly
2, Head set - clean and repack with grease
3. Front skewer as mentioned
4. cleats
5. bottom bracket
6. I'm grasping at straws. :lol:
Users browsing this forum: Bing [Bot], Google [Bot] and 59 guests
There are no new unread posts for this topic. HED GTO Stem/Bar
micropox
Sun Jul 22, 2012 9:39 am
micropox View the latest post
There are no new unread posts for this topic. Which stem?
BeeBee30
Fri Jun 01, 2012 7:52 am
SWijland View the latest post
There are no new unread posts for this topic. look 695 c-stem
triabas
Mon May 20, 2013 8:23 am
triabas View the latest post
There are no new unread posts for this topic. What bars / stem?
mrfish
9
637
Tue Oct 30, 2012 3:12 pm
project3 View the latest post
There are no new unread posts for this topic. FSA stem lengths?
ms6073
Fri Mar 15, 2013 7:14 pm
Valbrona View the latest post
It is currently Fri May 24, 2013 7:40 am
