Post new topic Reply to topic  [ 79 posts ]
Go to page Previous  1, 2, 3, 4, 5, 6  Next
PostPosted: Thu Feb 28, 2013 1:38 am
I can confirm the 31.7 44cm superleggera is 185g.
Colnago C59 TSRD
Colnago Prestige
PostPosted: Thu Feb 28, 2013 2:02 am
By god, what's next? Pinarello coming in at (well, close to) claimed mass?
http://djconnel.blogspot.com/
Fuji SL/1
PostPosted: Thu Feb 28, 2013 3:09 am
My Superzero post was 20g under advertised weight...
PostPosted: Thu Mar 07, 2013 8:42 pm
lol...My 44 came in at 186g. :up: BUT, I'm getting pretty tired of waiting for that stem.... :noidea:
PostPosted: Fri Mar 08, 2013 6:48 am
Me waiting too,will it be out soon?
COLNAGO C59 MATT BLACK
VOLVO FH 12 480 BHP
PostPosted: Fri Mar 08, 2013 7:21 am
Wiggle expects them by March, so I'm assuming other shops as well?
PostPosted: Fri Mar 08, 2013 1:38 pm
HammerTime2 wrote:
Abolutely. It's just that Deda Elementi's listed weights correspond to what the products would weigh on a celestial body with about 20% lower gravitational force than on Earth, and then translated back to what that would be in grams per gravity on the Earth's surface. Now, if you want to call that lying ...
Isn't that what Italy is to cycling....A celestial body?
Why are the best things in life always the ones you start last?
PostPosted: Sun Mar 10, 2013 5:14 pm
Deda is using a 31.7 bar clamp diameter on these new bars. Maybe they are giving up on their 35mm bar clamp diameter?
PostPosted: Sun Mar 10, 2013 5:59 pm
@ winky - they've released both formats. It wouldn't be commercially sensible to close the door on 99.99% of the market format.
PostPosted: Sun Mar 10, 2013 6:31 pm
On Deda's website it only shows the new bars with a 31.7mm diameter.
PostPosted: Sun Mar 10, 2013 7:00 pm
Ribble's trying to sell it...
PostPosted: Sun Mar 10, 2013 7:44 pm
Do these bars have the cable guides on the underside, like the Presa? I really do find them awkward to work with......
Thansks
Rich
PostPosted: Sun Mar 10, 2013 9:42 pm
Try using ilinks - they will get into the bend & guide a lot sharper & you don't end up with the inverse curve that you will do with standard cables. I'm using the outer gear feed route fwiw on ultrashift lever.
On a 42c/c presa std cables were awkward & I had some friction problems pretty soon after fitting.
With ilinks the curve to meet the guide is much easier & as a result no friction problems.
Lighter too...
PostPosted: Mon Mar 11, 2013 12:50 am
The cable guides are grooved as opposed to being tunneled like on the Presa.
PostPosted: Mon Mar 11, 2013 8:31 am
Just what I was hoping for - thank you
Rich
Post new topic Reply to topic  [ 79 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6  Next
Users browsing this forum: Bing [Bot], HammerTime2, MSN [Bot], springs and 36 guests
There are no new unread posts for this topic. Stem and handlebar sanding
Husum
16
1175
Fri Apr 19, 2013 9:12 am
maddog 2 View the latest post
There are no new unread posts for this topic. Stem/handlebar/seatpost combo
cyclistcong
Wed Jan 09, 2013 6:59 am
cyclistcong View the latest post
There are no new unread posts for this topic. Question about integrated handlebar/stem systems (140/-17)?
TVQgolf
Tue Jan 29, 2013 9:35 am
Stolichnaya View the latest post
There are no new unread posts for this topic. Help Identify Handlebar
SGcyclist
Mon Jan 21, 2013 12:04 pm
cllrhodgen View the latest post
There are no new unread posts for this topic. Handlebar compact
physeter
Sat Sep 01, 2012 4:25 pm
em3 View the latest post
It is currently Thu Jun 20, 2013 2:26 am
