Post new topic Reply to topic  [ 3 posts ]
PostPosted: Sat Sep 01, 2012 12:27 pm
I just bought a Felt B2 TT bike, and have to get used to rear facing dropouts. One of the things I stumbled upon was that the rear wheel wasn't alligned when I put it on. If I moved the right side a bit out it was alligned. Is that how it's suppose to be? I actually thought there were some sort of rod that you could adjust
I like Spanish bikes and cars. Riding an Orbea Orca and a Seat Ibiza.
PostPosted: Sat Sep 01, 2012 5:43 pm
Found one of the tensioners, and the other had been screwed all the way in.
So next question. I will be training with 23 mm clincher tires, but probably racing with 22 mm tubulars. Is there an easy way to adjust the screws so that I quickly can change wheels?
Also, how do you get the perfect alignment between the two screws? Trial and error? Or is there a secret?
PostPosted: Sat Sep 01, 2012 6:04 pm
On our Cervelos, I just measured from the centre of the BB to the centre of the skewer on each side to make sure I was straight. For the tire difference, maybe just memorize the number of turns to give the screws to make the tubular close. I never worried about that much detail, nor did my son who won junior nationally TT a few years ago.
Users browsing this forum: Bing [Bot], FastTarik, oreoboreo and 31 guests
There are no new unread posts for this topic. Do Colnago carbon forks need facing?
irongatsby
Wed Jun 13, 2012 6:46 am
irongatsby View the latest post
There are no new unread posts for this topic. Different chain for each rear wheel
wassertreter
Mon Aug 20, 2012 6:46 pm
topflightpro View the latest post
There are no new unread posts for this topic. Rear wheel not centered in frame.......
bicicleta
Wed Apr 24, 2013 8:09 pm
PoorCyclist View the latest post
There are no new unread posts for this topic. Derailleur Hanger Alignment ('12 Trek Madone 6.9 SSL)
baldkingpin
7
508
Thu Jun 14, 2012 6:01 pm
clarkson View the latest post
There are no new unread posts for this topic. Zipp front wheel choice with 404 rear - 404 vs 303
solarider
13
727
Sat Feb 02, 2013 2:43 pm
stormp View the latest post
It is currently Sat May 25, 2013 1:18 am
