Post new topic Reply to topic  [ 4 posts ]
PostPosted: Tue Aug 28, 2012 3:25 am
the bb is a token and was supposed to go on a ridley helium ('09 bsa threaded), but i made a mistake and bought the mtn version.
i am thinking that it should fit without the plastic middle sleeve, but what do you guys think?
according to the seller the dimension are
68x73mm
PostPosted: Tue Aug 28, 2012 6:20 am
I believe you can, but will need to run 2 2.5mm spacers; you can still run the sleeves. The road gxp bbs are wider than the mountain ones.
The nice thing about the GXP system is that if the bolt tightens fully without the bb binding, then you're golden.
PostPosted: Tue Aug 28, 2012 9:32 pm
yeah it'll run without the sleeve.
The mtb versions run a wider sleeve (usually, can't say for sure on a token) as they are designed to run with 3 spacers (again, usually) whereas road setups are spacer-less. So if you ran a MTB BB (with sleeve) on a road setup it would be too wide. So just take the sleeve out...
Shimano road and MTB cups are very slightly different widths, but it's no problem in practice to use them interchangeably.
PostPosted: Wed Aug 29, 2012 1:01 am
thanks
maddog and socratease
Users browsing this forum: Bing [Bot], Doolop, Google [Bot], Oswald, russianbear and 54 guests
There are no new unread posts for this topic. Delta7 Road Bike
KLabs
15
1194
Wed Nov 21, 2012 8:06 am
SWijland View the latest post
There are no new unread posts for this topic. MTB Clavicula on road bike
wassertreter
Tue Jul 24, 2012 10:15 am
wassertreter View the latest post
There are no new unread posts for this topic. Attachment(s) My FRM Frame Road Bike
FRMMan
Wed Jul 18, 2012 1:56 pm
FRMMan View the latest post
There are no new unread posts for this topic. Road TT bike on the track?
Tokyo Drifter
24
1422
Wed May 01, 2013 1:53 pm
There are no new unread posts for this topic. 6.5kg Full Carbon Road Bike
vastus
Sun Sep 09, 2012 8:27 pm
bm0p700f View the latest post
cron
It is currently Sat May 25, 2013 7:15 pm
