Post new topic Reply to topic  [ 7 posts ]
PostPosted: Fri Aug 24, 2012 10:21 am
Hi
I have both the 8x8.5mm and 7x9.6mm clamps for 1-bolt carbon seatposts but none of them fits my Flite Carbonio saddle :?: .The saddle has quite tall carbon rails and it´s a older 2007 model...Is there any clamp kits that´ll fit?
PostPosted: Fri Aug 24, 2012 10:44 am
The 8x8.5 should fit. Newer (last year or so) Selle Italia carbon railed saddles require the Fizik clamps (7x9.6).
PostPosted: Fri Aug 24, 2012 2:24 pm
Turned out that the 7x9.6mm was the right fit!.I did´nt bother to try it as i thought it would´nt fit...Problem solved.Thx :D
PostPosted: Sat Aug 25, 2012 1:37 am
On a related note does anyone know if I am able to use the Aluminium designed head on a carbon post? I have a new seat but the Australian wholesalers have no idea when the correct head units will be delivered. I've ordered a alloy one online and hope I'll be able to use it. Carbon post one is on back order...
Do you dare to dream?????
PostPosted: Sat Aug 25, 2012 3:44 am
Administrator
Are you referring to the clamp? If so I have an extra new one for carbon rails.
PostPosted: Sat Aug 25, 2012 8:28 am
There's two clamps for the carbon rails one for the aluminium post and the second for the carbon post. Nobody seems to be clear as to what the actual difference is. Hopefully I'll be able to use the alloy on the carbon post...
PostPosted: Sat Aug 25, 2012 9:08 am
I´m not sure as i have´nt used the alloy 1-bolt:but i assume that the shape of the contact area is different for the two seatposts...Otherwise it would´nt make sense to make one set of clamps for carbon and one for alloy?
Users browsing this forum: Exabot [Bot], Google [Bot], ipaul, Kermithimself, RussellS, thatdkid, TrekUk, ttakata73 and 57 guests
There are no new unread posts for this topic. Your favorite custom kits (that you can get online!)
iscarrr
11
1575
Fri Sep 14, 2012 1:05 am
TOflat View the latest post
There are no new unread posts for this topic. Santini Sizing for custom kits
ultyguy
Tue Mar 05, 2013 11:46 am
ultyguy View the latest post
There are no new unread posts for this topic. Custom Team Kits - best that's available to Australia?
afie
34
1272
Sat Feb 23, 2013 1:06 pm
BikeTart View the latest post
There are no new unread posts for this topic. Attachment(s) Ti bolt for 1 bolt style seatpost
virenque
Sat Jun 09, 2012 9:20 am
virenque View the latest post
There are no new unread posts for this topic. 30.9 seatpost clamp
SSB
Wed Jul 04, 2012 1:43 am
SSB View the latest post
It is currently Sat May 25, 2013 8:56 pm
