Post new topic Reply to topic  [ 34 posts ]
Go to page 1, 2, 3  Next
PostPosted: Thu Aug 23, 2012 1:54 pm
Has anyone tried to match the new dura ace 9000 fd to a sram force groupset?
The long arm and low weight seem like a two in one upgrade
thanks in advance...
PostPosted: Thu Aug 23, 2012 4:41 pm
Hopefully it's at least going to work with 7900.
I got to ride the new group this week and the front shifting is best on the market for mechanical. No questions about that.
Blog: http://glorycycles.blogspot.com/" onclick="window.open(this.href);return false;
Flickr: http://www.flickr.com/photos/glorycycles/" onclick="window.open(this.href);return false;
PostPosted: Thu Aug 23, 2012 6:22 pm
Unless I leave a bit of slack in the cable to the front deraileur on her road bike, the wife has a heck of time shifting into the big ring with 7900 and I have yet to figure out the setup for 7900 for her to get successful front shifts on her cross bike!
Assuming you meant the 9000 front deraileur with 7900 shifters, anbyone know if shifting improvements are due only to the longer lever arm of the 9000 front mech or is the imrpovement require both the 9000 shifter and front deraileur?
PostPosted: Thu Aug 23, 2012 6:43 pm
Theres no way the 9000 fd will work with older systems, unless they carefully matched the arm length/pinch bolt placement to allow you to run the cable under the pinch bolt instead of over it. But then, what's the point?
As far as needing to leave slack in the fd cable on 7900, yes, you have to do that, esp if youre using non-shimano cranks. Thats just how it is, nothing wrong with that.
PostPosted: Thu Aug 23, 2012 7:07 pm
The crank looks more businesslike from that angle than earlier preview shots. No complaints here, visually.
PostPosted: Thu Aug 23, 2012 9:54 pm
Sorry, not following. From the image above, it looks to me as if the lever arm on the derailleur is a bit 'taller' than for 7900 but I dont see why that would require a different cable routing for the pinch bolt.
PostPosted: Thu Aug 23, 2012 10:53 pm
I like those new cranks visually, never like the last generation of shimano cranks.
www.thecycleclinic.co.uk
PostPosted: Fri Aug 24, 2012 2:01 am
to effectively shorten the arm. it's a common trick when trying to match up, say, a road shifter with a mtb front derailleur. normally the shifter would not move the der far enough.
just looked at the pic more closely, interesting that it looks like the fd cable does go under the pinch bolt as it is.
PostPosted: Fri Aug 24, 2012 1:39 pm
If it works for 7900 it will also work for sram force right?
I couldn't find a compatibility charge for 7900 and 9000.
Otherwise i will try the new sram red fd
PostPosted: Fri Aug 24, 2012 2:45 pm
Why not try the new Sram RED Yaw FD since you're running a Sram group set. I have it set up with the original Force shifters on a force crank with Rotor q rings and shifting is perfect.
PostPosted: Fri Aug 24, 2012 4:17 pm
I was planning to give the new red a try which is a little porky, then I saw the weight of de 9000 fd at 66gr claimed, afterall this is weightweenies...
PostPosted: Mon Aug 27, 2012 10:25 pm
Sort of topic drift but intrigued by the descriptions of effortless shiting, over the weekend, I modified a Speen Umlenker 7800 so that instead of converting from a bottom pull, it effectively increased the length of the arm on the 7900 front deraileur on the wife's cross bike. While it took some 'fine tuning' with a flat file to get it right, my wife can now shift the Wickwerks 44/34 chainrings like butter.
PostPosted: Mon Oct 08, 2012 1:31 pm
Is the Sram RED Yaw FD compatible with Dura-Ace 7800 shifters and 7900 compact crank?
I have had problems with my 7800 FD ever since I added a 7900 compact crank, it was supposed to be compatible but it has been a dropped chain nightmare.
From what I can tell the 9000 FD is not compatible?
PostPosted: Mon Oct 08, 2012 3:26 pm
Agreed on that crank looking much improved. I never cared for the 7900.
:noidea:
I'd still run the YAW FD if it weighed a pound... this thing performs fantastic.
PostPosted: Tue Oct 09, 2012 2:28 am
7800 fd with 7800 shifters is not compatible with 7900 cranks. in general, the derailleur wont move far enough to get the chain to the large ring. there will be rubbing in the hardest gears in the big ring and/or in the easiest gears in the small ring.
this chart does not list 7800, but does still list 5600 (105). it shows that 5600 is compatible with 7900 front derailleurs (but not the other way around) and 5600 is compatible with 7901 chains. that's basically the extent of cross compatibility for the front shift systems.
Post new topic Reply to topic  [ 34 posts ]  Go to page 1, 2, 3  Next
Users browsing this forum: Google [Bot], maquisard, motch and 33 guests
This topic is locked, you cannot edit posts or make further replies. Dura Ace 9000 compatibility
insightt47
Thu May 16, 2013 5:47 am
insightt47 View the latest post
There are no new unread posts for this topic. DA 9000 rear derailleur compatibility
lannes
Wed Mar 06, 2013 4:58 am
Doolop View the latest post
There are no new unread posts for this topic. Attachment(s) DuraAce 9000 10 speed wheel compatibility
[ Go to page: 1 ... 5, 6, 7 ]
borja
99
12490
Thu May 16, 2013 4:41 am
There are no new unread posts for this topic. Bontrager Aura 5 - Shimano 9000 compatibility or Swap
drewb
Fri Oct 12, 2012 10:27 pm
drewb View the latest post
There are no new unread posts for this topic. Attachment(s) Dura Ace 9000 hubs
upside
26
4800
Wed Feb 20, 2013 7:52 am
eric01 View the latest post
It is currently Wed Jun 19, 2013 10:39 am
Shimano Dura-Ace components & groupset at reasonable prices
