Post new topic Reply to topic  [ 6 posts ]
PostPosted: Wed Aug 22, 2012 11:47 pm
I saw that Gumgardener removed the paint from his THM crank but I cant find how he did it.....Maybe I read something about using a razor blade? Im not sure. Any help would be appreciated
PostPosted: Thu Aug 23, 2012 1:01 am
Start reading here viewtopic.php?f=10&t=98607&start=240#p864974 , and for the next page or so. That may not tell you to the level of detail you want, but it's something.
Note this post from andy2, who is still actively posting here.
In that thread at viewtopic.php?f=10&t=98607&start=240#p865105 , andy2 wrote:
I used steel wool on two sets, they came out great. I avtuslly like the sanded ones better than factory matte. The shiny clearcoat is better quality. The reason Parlee do their matte (not waxed) finish like this.
PostPosted: Thu Aug 23, 2012 4:58 am
Hmm something about steel wool, that's weird, I'll check into that thanks!!
PostPosted: Thu Aug 23, 2012 6:54 pm
Just use some very fine wet and dry paper , Its very easy and you will see the coat start to come off . I did the same to my Helion crankset . I then used some areo 303 to give it a finish and some protection against the suns rays . I would not use a razor blade as that is more for getting the paint off a frame which can be quite thick.
PostPosted: Fri Aug 24, 2012 5:04 am
What are you trying to achieve?
Do you want the satin/matte finish or are you planning to re-paint the crankset?
I used wet&dry sandpaper. I contacted THM and told them that I was planning to re-paint my Clavicula's myself and they sent me new decals :)
Be careful not to take too much off the pinch bolt holes. It's easy to do.
2012 Scott Foil Premium
PostPosted: Fri Aug 24, 2012 8:34 am
I tried a small spot with some 600 grit and it worked pretty well. It actually looks ok on my Colnago in gloss so I may leave it like that for a while. Once I get my Zero.7 ill probably do it
Users browsing this forum: Bing [Bot] and 56 guests
There are no new unread posts for this topic. Removing/Reinstalling Campy Crank
dhendriksen
Sat Jun 23, 2012 2:51 am
There are no new unread posts for this topic. Removing tyre brand graphics
lo5707
18
1023
Mon Dec 24, 2012 1:38 pm
artray View the latest post
There are no new unread posts for this topic. Removing Di2 internal wiring harness
nelson
14
634
Fri Dec 28, 2012 2:49 am
maxxevv View the latest post
There are no new unread posts for this topic. Removing PF30 adapter, need the wisdom of WW!
audiojan
Sun Apr 14, 2013 6:22 pm
audiojan View the latest post
There are no new unread posts for this topic. Removing Logos From FSA Alloy Bars
Valbrona
Wed Jan 02, 2013 2:41 am
Valbrona View the latest post
It is currently Wed May 22, 2013 11:45 am
