It is currently Sat Apr 29, 2017 9:01 pm
Post new topic  Reply to topic  [ 107 posts ]  Go to page Previous 14 5 6 7 8 Next
PostPosted: Wed Sep 05, 2012 2:32 pm
sounds like nonsense. Heat comes from braking, not 'riding', so discs will be much better in this respect.
PostPosted: Wed Sep 05, 2012 3:43 pm
The arguments are running around in circles as we all have little experience of disc brakes on bikes.
Salsa are bringing out disc brake frames. Enve forks are used on these. I think all the models in 2013 can be had with disc brakes. This one manufacturer who is commiting. I want a to try a Salsa now.
www.thecycleclinic.co.uk
PostPosted: Wed Sep 05, 2012 4:11 pm
I had a Cannondale Cyclocross Disc back around 03-05, with BB7's. Phenominal braking compared to Road Brakes, worked awesome in the wet.
At the time I was about 105KG - Definitely good for those of us with larger frames. I never tried it on big hills though so no idea if they shed enough heat with prolonged use.
PostPosted: Thu Sep 06, 2012 1:37 pm
Salsa Colossal ti, ENVE tapered disc fork and 140/140 rotors. Quite nice.
PostPosted: Thu Sep 06, 2012 3:34 pm
That looks like a pretty cool frame. Is Lynskey still manufacturing the frames for Salsa?
PostPosted: Mon Sep 10, 2012 11:56 am
Just spotted another disc-braked bike for 2013. Shame it's a dog. Ladies and gentlemen, I give you the Silverback Scalera Pro. The b@astard child of a BMC, a TT bike, a 80s horizontal top tube and a hideous headtube&fork combo, plus yellow stickers to top it off. My word.
PostPosted: Mon Sep 10, 2012 4:17 pm
Maddog
Please take it off, my eyes.
Sent from my PG86100 using Tapatalk 2
Change the paint scheme and it would look better than you initially thought. :wink:
PostPosted: Mon Sep 10, 2012 4:23 pm
I really can't understand how people are worried about disc's overheating.. I mean.. They are used on motobikes in roadracing - The brake forces on motobike is much greater than on any bike.. Granted if the disc brake is not designed for the forces at play - but I doubt it will add significantly to the weight in order to get a disc system that is much more safe than the current rim brakes..
However even though I would never go back to rim brakes on my MTB - I actually don't feel the need for disc's on my roadbike.. Maybe if I did a lot of mountain decending at high speeds, but I dont....
Parlee Z5 ML
PostPosted: Mon Sep 10, 2012 4:29 pm
I initially thought it looked utterly terrible, so you may be right.
PostPosted: Mon Sep 10, 2012 6:51 pm
Just more stuff for consumers to consume.
My feeling about discs on road is this: Braking power is not your limiter on road bikes- the limiter is traction. Traction will give at a certain speed that is lower than when the brakes give. Also, discs add complexity and are not without problems. You gain a wheel where the sideway does not get worn away- but you will go through a set of disc pads on a really wet day.
PostPosted: Mon Sep 10, 2012 8:17 pm
Disc pads will always greatly outlast rim pads in equal circumstances.
As mentioned a thousand times, (and it still doesnt soak in,) its not about braking power. Its about control. With flexier systems, when you need to suddenly threshold brake, you hit the brakes with a medium amount of force and then increase that until youre at the limit. With better brakes like discs, once used to it, you can quickly apply a force closer to the ideal, then increase it as necessary. It saves precious meters into a corner or before the car door.
PostPosted: Mon Sep 10, 2012 9:20 pm
Amen to that. Pads don't wear out on wet days like they do for CX/MTB applications. Mine are still going strong after many thousands of km
PostPosted: Mon Sep 10, 2012 9:30 pm
This duff logic comes up time and time again. The limiting factor is not traction - the limiting factor is your ability to control what traction you do have. And discs are better at this, because they have better modulation, controllable power, consistency and reliability. Simples.
PostPosted: Mon Sep 10, 2012 10:06 pm
I'm not sure chainging the paint on the silverback helps. It is not a elegent design.
There are no new unread posts for this topic. Weight difference between F8 and F8 Disk....
mile2424
15
1179
Fri Sep 23, 2016 2:16 pm
dadoflam08 View the latest post
There are no new unread posts for this topic. Hyrdaulic Disk Brakes
[ Go to page: 14 5 6 7 8 ]
bikebike
105
5357
Fri Aug 26, 2016 4:05 am
bikebike View the latest post
There are no new unread posts for this topic. Attachment(s) Venge Vias Disk is here....
[ Go to page: 1 2 3 4 5 6 ]
mile2424
82
10927
Mon Sep 19, 2016 8:14 am
endershan View the latest post
There are no new unread posts for this topic. Heat Shield for Disk Brakes?
krtassoc
11
656
Thu Oct 06, 2016 9:44 am
mattr View the latest post
There are no new unread posts for this topic. Dogma F8 hydro disk brakes/ Di2 Ultegra vs Cannondale SuSix Di2/Ultegra
bikebike
Sat Oct 29, 2016 4:41 am
Users browsing this forum: AZR3, Google [Bot], ooo, RussellS, trimenc and 60 guests
