Post new topic Reply to topic  [ 9 posts ]
PostPosted: Tue Aug 21, 2012 2:49 pm
apologies if discussed, could not find a topic using search.
My tires have done about 2,500 miles now, the back one is starting to look a bit square, and with a few little marks (cuts?) in the rubber, the front doesn't look as bad though.
So how often do people replace, at a set distance? when they feel like it? do you move front to back and only by a replacement front?
Scott CR1 - 12.84Ib
PostPosted: Tue Aug 21, 2012 3:51 pm
I swap tyres when I notice a few cuts starting to appear . I use ZX clinchers and I usually start to get a puncture or 2 so I get some new ones. It might be worth saying what tyres you use the WW on here will no doubt blow your mind with there knowledge . :beerchug:
PostPosted: Tue Aug 21, 2012 3:57 pm
Thanks, I am using Continental Ultra Sport Folding, but am looking to go over to Conti GP4000S
Scott CR1 - 12.84Ib
PostPosted: Tue Aug 21, 2012 4:03 pm
I ride my Contis until I can see exposed strips of cord down the center. But I admit that I am very cheap.
PostPosted: Tue Aug 21, 2012 4:20 pm
You may be due for a set if your rear is starting to square, it is probably affecting the ride quality more than anything else though. Swap to GP 4000s and they should last even longer.
PostPosted: Tue Aug 21, 2012 4:56 pm
when...
the wear indicators are just about gone
the puncture rate suddenly goes up
there's any cut to the carcass bad enough to cause a perceptible bulge
they've done a lot of miles and i'm about to go on a cycling holiday
any sign of delamination or other worrying developments
PostPosted: Tue Aug 21, 2012 9:19 pm
2500km out of ultrasports. I ran mine for a few rides and ditched them as they were too puncture prone. The 4000s will feel alot better I think. 4 seasons are a similar price but should be more puncture resistant than the 4000s.
www.thecycleclinic.co.uk
PostPosted: Tue Aug 21, 2012 9:24 pm
Same for training.
For racing you might replace tires a bit sooner.
PostPosted: Wed Aug 22, 2012 3:55 pm
I ride my GP400s until there is a sidewall blowout or an entirely shocking rate of punctures (which, at 1/year, could be something like 2-3 within a few weeks)
Exp001
Users browsing this forum: Bing [Bot], djm, Exabot [Bot], Google [Bot], Google Adsense [Bot], HammerTime2, Majestic-12 [Bot] and 64 guests
There are no new unread posts for this topic. Replace 130 mm axle for a 135 possible ?
LouisN
10
412
Mon Feb 25, 2013 10:26 pm
LouisN View the latest post
There are no new unread posts for this topic. DIY Di2 looking for my own connectors to replace Shimano. An
bartturner
Sat Feb 09, 2013 9:50 pm
bonafide View the latest post
There are no new unread posts for this topic. When to replace chain rings?
Rideuphill
14
985
Tue Mar 26, 2013 2:13 pm
sawyer View the latest post
There are no new unread posts for this topic. replace spoke - tension by sound?
ricorob
7
547
Sun Sep 16, 2012 3:53 am
stella-azzurra View the latest post
There are no new unread posts for this topic. Replace 7800 Dura Ace crank arms?
trysixty
Sun Dec 16, 2012 3:23 pm
sedluk View the latest post
It is currently Sun May 19, 2013 11:53 pm
