Velocity Velo plugs
kavitator
by kavitator
Are there any similar hole covers for rims?
And are they good?
weight is pretty low
Thanks
jdp211
by jdp211
Those are the only ones I know of. I don't know why you'd want anything else though, cost-weight ratio is about the best out there and I haven't read a bad experience with them. Make sure you get the right size though.
kavitator
by kavitator
Thanks
mvogt46
by mvogt46
I have them on my wheels and they are good. The only additional recommendation I'll give is to use a piece of rim tape over the valve hole, I learnt the hard way by going through a few latex tubes. Since I've put a small piece of rim tape over the valve hole with a small hole cut for the valve to stick through I've had no more flats.
kavitator
by kavitator
good point . now i put carbon/kevlar composite covers. but veloplugs weight just little more. on kinlun rims valve hole is very tight and no flats for now. but i will put some soft tape on edges of the hole.
cheers
