Post new topic Reply to topic  [ 21 posts ]
Go to page Previous  1, 2
PostPosted: Fri Aug 24, 2012 1:00 pm
redbeard wrote:
I see two wires along the outside in that pic. Where did you put the wire insert point? I almost got EPS but decided to wait for the battery to get smaller or hacked. We will see about that but in the meantime that under saddle mount has a lot of promise.
I too feel it has promise, especially if you can find a way to route the wires thru the seat post and into the saddle. Then there would be few [if any] wires that would be exposed/seen.
PostPosted: Fri Sep 14, 2012 6:58 pm
Calfee is rumored to be bringing to Interbike (in a couple of weeks) a converted Enve stem which will have its battery and the Campy EPS brains and will completely hide the battery. But it won't be cheap.
PostPosted: Fri Sep 14, 2012 7:45 pm
EPS cheap :shock:
PostPosted: Mon Sep 17, 2012 3:33 pm
Does Campy suppy a template for drilling the other holes when retrofitting a non-internal routing bike for internal routing of harness?
PostPosted: Wed Sep 19, 2012 11:22 am
OR attractive ;)
Baum Corretto - Custom built Ti Road Bike - 6.6kg
Baum Corretto - Custom built Ti Track Bike - NAHBS 2012 - 5.9kg
Baum Corretto - Custom built Ti Road Bike - Lightweight Obermayer Gold Ed 07/99
Colnago C50
1975 Richard Sachs track bike
PostPosted: Wed Sep 19, 2012 1:18 pm
mlchang wrote:
Supposedly an under bottom bracket mount as well, using the same mounting kit (not dedicated mounting position as some frames have).
Like this you mean?
Post new topic Reply to topic  [ 21 posts ]  Go to page Previous  1, 2
Users browsing this forum: Exabot [Bot], shimmeD and 50 guests
There are no new unread posts for this topic. best lightweight tubeless clincher option?
fivethirtyonepm
16
1398
Fri Nov 16, 2012 5:16 pm
PSM View the latest post
There are no new unread posts for this topic. LOOK 695 - Zed 2 crank chainring bolt replacement option?
supertight
12
2218
Tue Sep 04, 2012 11:51 am
brycerider View the latest post
There are no new unread posts for this topic. Best option for carbon clinchers >50mm and <$1000
capnc
9
1808
Fri Sep 07, 2012 9:23 pm
eric View the latest post
There are no new unread posts for this topic. 2011 scott spark 10 Chain guide Option HELP!
andreszucs
Thu Apr 11, 2013 6:51 am
andreszucs View the latest post
There are no new unread posts for this topic. Ciamillo Gravitas Cranks with a Power Meter Option
jmocallaghan
Sun Apr 28, 2013 5:53 pm
jmocallaghan View the latest post
It is currently Wed Jun 19, 2013 5:51 am
