Post new topic Reply to topic  [ 21 posts ]
Go to page 1, 2  Next
PostPosted: Mon Aug 20, 2012 4:13 pm
I am getting ready to bite the bullet and purchase a SR EPS system and I have yet to find any pictures of the under saddle mounting option. Yeah, I know about the wires and what not, but it does not appear that anyone has posted pictures of the power unit mounted at the saddle.
Any of you know?
PostPosted: Mon Aug 20, 2012 4:43 pm
Curious about this too. Or just anywhere besides at the bottle cages.
WTB: MTB hubs, 29'er carbon rims
My 7.3kg/6.4 kg 29'er project buildthread!
My Bianchi Oltre XR
PostPosted: Mon Aug 20, 2012 5:32 pm
Supposedly an under bottom bracket mount as well, using the same mounting kit (not dedicated mounting position as some frames have). Have only seen photos of the brackets, etc, but no photos of it in use...
Also wonder if they mounting options are compatible with Athena EPS as well as Record and SR EPS
PostPosted: Mon Aug 20, 2012 6:27 pm
Formerly known as PezTech
Here's to hoping Fairwheel hack EPS and make a reasonable sized brain and battery pack versus what's there now... Will it even fit under most saddles?
The reason I haven't bought one yet is down to it looking like Campy just gave up on developing.
charles@pezcyclingnews.com
PostPosted: Mon Aug 20, 2012 8:56 pm
I actually think it was overdeveloped. They were too afraid of the weather out there.
PostPosted: Mon Aug 20, 2012 10:08 pm
Is it actually any bigger than the Shimano one though? I haven't seen a side by side comparison.
PostPosted: Tue Aug 21, 2012 10:25 am
They made it to work even if the bike is underwater (very useful feature :lol: ).
PostPosted: Tue Aug 21, 2012 10:37 am
I tried one Sunday, it's just perfect ...
the battery is not too big, it looks ok on the seat tube.
PostPosted: Tue Aug 21, 2012 2:33 pm
If parking a Fiat 500 on your top tube looks OK :lol: .
The campy unit is bigger than the Shimano but I dont like the Shimano set up either (TOTALLY A PERSONAL THING ON MY PART for both units). I wouldnt build a bike with either one without getting rid of the exterior electronics other than the actual mechs. I think both groups should have done a bit more to find their way inside frames.
PostPosted: Wed Aug 22, 2012 12:59 pm
Pictures?
PostPosted: Thu Aug 23, 2012 8:02 am
i've installed eps on a specialized venge, it installed pretty neatly, drilled one hole in the SP and that was it. if you get the correct cable kits there is plenty length for any frame. they make two mounting kits, i mounted the one designed for seatposts on a metal plate and simply attached this to the saddle rails.
PostPosted: Thu Aug 23, 2012 11:03 am
Pictures?
Sorry , I meant the down tube
PostPosted: Thu Aug 23, 2012 12:48 pm
Thanks a.davis12 for the picture, that is exactly what I was looking for.
PostPosted: Thu Aug 23, 2012 4:19 pm
I see two wires along the outside in that pic. Where did you put the wire insert point? I almost got EPS but decided to wait for the battery to get smaller or hacked. We will see about that but in the meantime that under saddle mount has a lot of promise.
I miss the Jerk because your stem is still too short.
Your saddle is probably too high as well.
Oh, and your cleats too far forward.
PostPosted: Fri Aug 24, 2012 6:32 am
drilled a hole in LHS of the venge sp and the wires went in there.
Post new topic Reply to topic  [ 21 posts ]  Go to page 1, 2  Next
Users browsing this forum: No registered users and 40 guests
There are no new unread posts for this topic. best lightweight tubeless clincher option?
fivethirtyonepm
16
1348
Fri Nov 16, 2012 5:16 pm
PSM View the latest post
There are no new unread posts for this topic. LOOK 695 - Zed 2 crank chainring bolt replacement option?
supertight
12
2011
Tue Sep 04, 2012 11:51 am
brycerider View the latest post
There are no new unread posts for this topic. Best option for carbon clinchers >50mm and <$1000
capnc
9
1688
Fri Sep 07, 2012 9:23 pm
eric View the latest post
There are no new unread posts for this topic. 2011 scott spark 10 Chain guide Option HELP!
andreszucs
Thu Apr 11, 2013 6:51 am
andreszucs View the latest post
There are no new unread posts for this topic. Ciamillo Gravitas Cranks with a Power Meter Option
jmocallaghan
Sun Apr 28, 2013 5:53 pm
jmocallaghan View the latest post
It is currently Thu May 23, 2013 6:46 am
