Post new topic Reply to topic  [ 4 posts ]
 Post subject: spoke length
PostPosted: Sat Aug 18, 2012 12:18 pm
Hey guys,
could someone give me the correct answer on this annoying question?
rims dt swiss r250 hubs shimano ultegra 32 holes 6700.
What is the correct length of the spokes?
thx mates!
 Post subject: Re: spoke length
PostPosted: Sat Aug 18, 2012 1:03 pm
May I suggest that you get hold of two j bend spokes and cut to 200mm in length. Then screw nipples on so the driver flats are flush with the top of the spoke treads. Place the cut spokes with nipples in the rim at opposite end and pull tight and measure the distance between the ends. Add 400mm and this is the ERD.
Then get a pair of calipers and following the instrutions on this site to measure the hub.
http://lenni.info/edd/howtomeasure
Then download this and plug in the measurements and bingo you have your spoke lengths. http://sheldonbrown.com/rinard/spocalc.htm This what wheel builders do and I think it is good pratice to get used to how to do it your self.
An ultegra rims and DT 250 hub (do you mean a 240?) is not a normal combination so maybe some has done it before maybe not.
www.thecycleclinic.co.uk
PostPosted: Sat Aug 18, 2012 5:21 pm
I am sure he meant DT R250 Rims and ultegra hubs. There are many resources online nowadays for wheelbuilders, for example;
http://www.dtswiss.com/SpokesCalc/Welcome.aspx?language=en
That should have the DT rim's ERD.
Look around and I'm sure you can find the measurements for the Ultegra hubs.
Plug it into the DT spoke length calculator and you're golden.
My drawings:
http://www.facebook.com/andrewlivingstonart
My bike:
http://weightweenies.starbike.com/forum/viewtopic.php?f=10&t=107451
PostPosted: Sat Aug 18, 2012 9:10 pm
Im gonna test that dt calculator.
It where dt r520 rims my fault :oops:
Users browsing this forum: fezi, Google [Bot] and 32 guests
There are no new unread posts for this topic. Bontrager Aeolus 5 16/16 spoke vs newer model 18/24 spoke
reason
Wed Oct 10, 2012 8:17 am
reason View the latest post
There are no new unread posts for this topic. Rotor 3D spindle length?
thencameyou
Sun Mar 24, 2013 2:54 am
There are no new unread posts for this topic. Sram chain length
neverwasbeen
10
401
Mon Feb 25, 2013 5:34 am
deek View the latest post
There are no new unread posts for this topic. A crankarm length question...
veloflyte
21
849
Mon Jan 14, 2013 5:46 pm
Pantani View the latest post
There are no new unread posts for this topic. Attachment(s) Dogma 2 seatpost length
ParisCarbon
Fri Jun 15, 2012 9:23 pm
cycleboyco View the latest post
It is currently Sun May 26, 2013 9:34 am
