Post new topic Reply to topic  [ 3 posts ]
PostPosted: Fri Aug 17, 2012 7:20 pm
Recently purchased a new Cannondale EVO with SRAM red group. Shifting was a bit rough on first ride with chain rub on front derailleur in highest gear with large chain ring/small rear cog or small compact front chain ring mid rear cog. Have ridden about 100 miles since then and brought to LBS yesterday for adjustment. Diagnosis is that front large chain ring is "warped". Recommend getting rid of front chain rings for Praxis and replacing front SRAM titanium front derailleur with steel version. LBS reports lots of problems with these SRAM components. Should SRAM chain rings be covered under warranty? Any suggestions or similar experiences?
PostPosted: Fri Aug 17, 2012 7:47 pm
Yes, SRAM should warranty that if new from the LBS. I used to run a titanium cage Red RD. Going to steel was definitely an improvement. It was flaky/hit and miss when going up to the big ring. I run Qrings also, no problems with Sram Red with a steel cage now.
I thought awhile back I heard if people complained to SRAM about it, they would send them a steel cage for the FD?
PostPosted: Fri Aug 17, 2012 7:57 pm
Sram make of alot of things out of a soft cheese including there MTB rear mech jockey wheels.
www.thecycleclinic.co.uk
Users browsing this forum: Geoff, Google Adsense [Bot], MixMastaPJ, rmerka and 65 guests
There are no new unread posts for this topic. Attachment(s) Need advice: Sram Red front derailleur
poppiholla
31
2057
Sun Jul 22, 2012 11:36 pm
CharlesM View the latest post
There are no new unread posts for this topic. Sram Red front derailleur(non yaw) with Chorus 10 speed shif
digiadaamore
Wed May 15, 2013 10:19 pm
dereksmalls View the latest post
There are no new unread posts for this topic. Campag SR11 Rear Derailleur problems.
Simonhi
9
678
Mon Jun 18, 2012 4:12 pm
Simonhi View the latest post
There are no new unread posts for this topic. Campy Bora front hub problems
dudu
Wed Aug 01, 2012 12:00 am
fdegrove View the latest post
There are no new unread posts for this topic. Is this the end of the front derailleur?
SWijland
23
2006
Sun Dec 23, 2012 2:05 pm
Franklin View the latest post
It is currently Wed May 22, 2013 1:17 pm
SRAM - bike parts & bike components from SRAM at cheap prices
